Old 04-27-2013, 02:58 PM   #7869
BRZ_Driver
BRZ_Driver's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Supermassive View Post
9.5" Rays Gramlight 57 Xtremes...they actually measure 10.5 lip to lip though.
18's?
Christian
1977 280Z(Fidelity) L28ET powered at 10psi
2013 Subaru BRZ w/6M(Vader) BWR Turbo Kit in the works
BRZ_Driver is offline   Reply With Quote
Old 04-27-2013, 02:58 PM   #7870
Supermassive
Supermassive's Avatar
yeah my bad
Supermassive is offline   Reply With Quote
Old 04-27-2013, 02:59 PM   #7871
Supermassive
Who parked next to me at kohl's in Mesa?
Attachment 35365
Me...lololol! J/k
Ok that was terrible...I promise to never J/K anyone ever again...
Old 04-27-2013, 03:10 PM   #7872
BRZ_Driver
BRZ_Driver's Avatar
yeah my bad
Tread life and grip usually don't go hand in hand lol But compromises can be made.
Don't know if you can find BFGoodrich Sport Comp 2's in the size you need but those were some of the best tires I've ever bought!
I had them on my GTO and after countless burnouts and some drift runs they seemed to last for ever. Of course I had a box setup up so rotating them was a breeze. Those tires had plenty of grip and held together rather well.
Christian
Old 04-27-2013, 03:19 PM   #7873
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
I'm hoping that switching to something a little grippier...aka softer will actually improve tire life. I know that sounds counter intuitive, but these Invo's are so bad at gripping they just spin which i think may be eating them up prematurely. Kinda crappy, I know...but it will give me an excuse to run the Dirrezza Z2's...I might have to run a not so optimal setup until I can gather some more money to buy fronts but the rears are most important.
I have the z2s, buy BF Goodrich rivals.
Evil86 is offline   Reply With Quote
Old 04-27-2013, 03:33 PM   #7874
Supermassive
The problem is that the Invo's are 260 wear rating but I got maybe 10k miles out of them. I'm only running maybe 1.5-2 degrees camber in the rear and toe is neutral at the moment.
Old 04-27-2013, 04:01 PM   #7875
BRZ_Driver
BRZ_Driver's Avatar
Camber at any degree will kill tires over time, especially on the tires being driven. I understand the need to run -camber if the tires don't fit or if it's done for looks. But as a daily driver, 0 comber would GREATLY prolong the life of tires.
You have fully adjustable suspension in the rear right? I know looks are important but adjusting camber for daily use then switching back for shows/track days would help.
Stretched tires will also have negative impacts of tread life and traction.
It's really finding a balance between form and function.
Christian
Old 04-27-2013, 04:20 PM   #7876
kos
Drives: 04 UCF30 / 05 GDA-E / 06 GDA-F
0* Camber I wouldn't recommend, because what happens when you turn/corner? It's gonna roll over and eat the outside sidewall. Car load weights will affect it as well. Do -.2 Camber, and 0 toe. Toe will murder tires as well.
2005 RS Impreza Airlift Bagged
2006 WRX Street AWD Time Attack
kos is offline   Reply With Quote
Old 04-27-2013, 04:39 PM   #7877
BRZ_Driver
BRZ_Driver's Avatar
Wouldn't the tires sidewall stiffness also play a role at 0 camber?
I would think a non-stretched tire with a good side wall wouldn't give as much, no?
The stock tires on our cars give so much its not funny.
I know you know your stuff Markos lol so if I could learn from this as well, that would be a plus!
Christian
Old 04-27-2013, 04:50 PM   #7878
kos
Sidewall will play into it a little, but with the wheel turning its going to change how much of the tire is used.
As the car is turning hard, the outside suspension becomes loaded and the tire tends to roll under the wheel rim. With a zero camber setting, the tire would be aggressively pulled under and the car would actually be riding on the outside of the tire with a reduced contact patch. As a double-wishbone suspension is loaded, the camber angle becomes more negative tilting into the turn and effectively pulling the tire back under the wheel through the turn. The end result: With negative camber the contact patch will be larger through turns.
I couldn't get my wording right in my head, so I gleaned that from this article in Honda Tuning: http://www.hondatuningmagazine.com/t...e/viewall.html
Some really good info in there, and you can apply it to every car.
Old 04-27-2013, 04:55 PM   #7879
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
ill be at the pavs to show new setup. havent dropped the rear yet to my liking, might get to it before hand. Car will come bugged up tho, too lazy to go wash it. Maybe a wip down if i feel like being outside in the oven. might be a little late due to dinner plans. coming after tho
SMOKETREES is offline   Reply With Quote
Old 04-27-2013, 05:16 PM   #7880
BugeyedWagon
Suby Specialist
BugeyedWagon's Avatar
I'm not going to make pavs or the flats run tomorrow morning. I'm going out boating and camping tonight.
Old 04-27-2013, 05:56 PM   #7881
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
I have the BF Goodrich Rivals, buy the BF Goodrich Rivals.
To elaborate a bit: The ZIIs probably won't be the winner of the current "tire war" that's shaping up. They're a modest improvement over the ZIs (my former tires) in most numerical categories (lateral grip, tread life, etc). However, many drivers have been reporting that they are difficult to extract the full potential from. The prevailing opinion on the ZIIs is that they have a very narrow operating window where maximum grip is generated, and fall off quickly outside that window. I haven't driven on them personally, but @Evil86 can probably attest to setup difficulties with the ZII. With that in mind, it probably wouldn't be an ideal street tire.
BF Goodrich Rival: The Rivals are an all-new design from BFG, and they seem to be the hot tire right now. My experience with them has been that they have very high levels of grip which is produced at a much higher slip angle than the Star Specs. They seem to be wearing very well on the shoulders, which would suggest they're more forgiving and durable on camber-challenged cars. It probably helps that the tread blocks extend down the sidewall. Be aware that these tires like to talk. They'll make all sorts of squealing noise as you push them, but they aren't actually giving up any grip when they do. The Rivals are more comfortable for street driving than the Star Specs (and I suspect the ZIIs as well). Also, I wouldn't expect great traction in standing water from this tire, given the tread pattern.
Bridgestone RE-11A: The latest entrant to the tire war, the RE-11A has received praise as a significant improvement over the old RE-11. Pricing is also much more reasonable than it's predecessor. The RE-11A is reported to have excellent wet and dry grip. The significant downside is that 18" sizes are currently limited to 245/40R18, which would be a bit stretched on a 9.5" wheel (but within spec for the tire, barely).
Yokohama ADVAN Neova AD08R: I don't know when this replacement for the AD08 will be available in the US, but expect it to be along the lines of the RE-11A, a tread compound update to an existing tire design. I haven't seen any independent reviews of the AD08R yet, but even if it's a fantastic tire, the AD08s are ridiculously over-priced, probably won't be worth the extra money.
I would also consider the Michelin Pilot Super Sport, it's been around for a couple years now, but it's still a good daily driver tire that retains the ability to track or auto-x. Also reasonably priced.
Old 04-27-2013, 06:11 PM   #7882
thesleeper
thesleeper's Avatar
Drives: Asphalt FR-S
Ignore the fact that the white outer circle on the second one is a little bolder, I'll adjust that later...
Let me know if you guys have any suggestions since this is for all of us!
Also, Radium catch can group buy is ending in three days!
http://www.radiumauto.com/Radium-Cat...osit-P291.aspx
thesleeper is offline   Reply With Quote
