Old 12-02-2011, 07:21 PM   #15
Dimman
Kuruma Otaku
Dimman's Avatar
Anyone know where to find the ratios for an IS250 6M box? Could be a decent starting point and then we can sort out final drive.
And I've noticed in more than one review now they've talked about different gear ratios? Could there be an optional rear diff maybe? I believe the domestics still offer 'digger' low (big number) FD's on some of their products. And Toyota has offered different ratios on different spec in the past (Mk3 Supra had at least 4 different rear diffs available).
Because titanium.
Old 12-03-2011, 11:37 AM   #16
Dalexxx
Drives: invisible
where is this video? can anyone point me to it?
Dalexxx is offline   Reply With Quote
Old 12-03-2011, 03:40 PM   #17
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Originally Posted by Allch Chcar View Post
All of the gearing is a bit tall IMHO. I like it but I dunno if it's right on. The top speed gearing in 5th is around 3.7 which is on the tall side.
Again they're only guesses, and 4th-6th are tall based on the video showing a somewhat tall 3rd (I initially had 3rd-6th all shorter before I noticed 3rd was on the video).
Originally Posted by carbonBLUE View Post
top speed will be more due to the fact its got a good drag raito
my car has less hp less tq and its drag ratio is .32 and i can hit 150
more tq and hp with a drag ratio of .27 should hit 150 prob topping out after 2-3 miles at 160-165
I previously read that it would top out at 140 (presumably due to a governor). I've since read top speed reports of 140 again, 143, and 136 (that last number supposedly due to fuel cutoff, which doesn't make sense to me).
Originally Posted by ahausheer View Post
Suppose you can hit 61 at the top of second. This is interesting since they say the car was not designed for spec sheets. If your estimates are true it would make the 0-60 time look good on paper. Perhaps sub 6 sec to 60 mph if you beat the hell out of it and are a very very good driver.
I'm sure that's part of it, but to be fair they said they interviewed enthusiasts at track days and autox, who may have asked to be able to go above 60 MPH in 2nd (can be advantageous for autox).
Originally Posted by serialk11r View Post
Those ratios don't seem very close, about 1.44 between gears :O by contrast an STi transmission is 1.386 (looking at 4th and 5th at least, assuming equal "spacing"). I think first is going to be a little more than 40 since that would put it more in line with the 2nd-3rd ratio.
FWIW, I based my guesses on cars like the RSX-S, which (according to what I read - please correct me if these numbers are wrong) hits redline at 40, 62, 86, 114, 142, 178 MPH. Because the video shows 3rd's redline speed as being ~1.5% higher than the RSX-S', I set 4th-6th to also be ~1.5% higher than the RSX-S'.
Note that the RSX-S's gearing is still taller (since it has a higher redline). Also the FT's jump from 2nd to 3rd is a bit higher than the RSX-S' (~42%-45% vs ~40%).
Top gear is always taller than necessary for MPG, NVH, etc. 5th gear is the top speed gear.
It is? Why wouldn't you upshift to 6th? (this car should make enough power after upshifting to continue accelerating)
If the engineers were using 5th to determine the reported top speed of 220km/hr, that actually explains the discrepancy (and would mean 5th tops out at 136 MPH). Yesterday, I asked @EdLoh about that:
@EdLoh Hope everything is OK in Japan with the quake. Back to the BRZ, is it possible they meant 220 km/hr is its top speed in 5th gear?
@deslock I'll ask and then you'll be the first to know. Likely that my Twitter dump could put the kibbosh on any more detail tho.
I added it to the original post.
Deslock is offline   Reply With Quote
Old 12-03-2011, 04:43 PM   #18
Eldorian
Drives: 04 RX8
Oh hey Deslock. Nice job on the calculations, I'll run some of mine here if you don't mind. Given the wheel RPM is known, 844 RPM @ 60MPH, I figure this car would need a 3.75 or so Final 5th gear ratio to pull 141MPH. That puts 6th gear around 0.78-0.80 if the 2500RPM at 60mph is true. Not exactly tall but it's not nearly as short as the MX-5/RX-8 gearbox.
Yeah, those gears are much taller than my RX8, which honestly could use a taller 6th for highway fuel economy. It goes to shit when you get above 3300 rpm, which you do when you get above around 63 mph.
Eldorian is offline   Reply With Quote
Old 12-03-2011, 07:48 PM   #19
Dimman
Kuruma Otaku
Dimman's Avatar
Because the rpm drop of the overdrive gear(s) usually puts top gear rpm/hp too low to fight the aero drag at that point.
Top gear would be top speed provided you have the power to fight drag. FFIW the last Celica's top speed was redline-limited in 6th, I believe.
Because titanium.
Old 12-03-2011, 09:12 PM   #20
serialk11r
Drives: '06 AM V8V Coupe
Oh you're probably right then, about the 1st gear. I guess you'd want a shorter 1st to make starts easier. I think for performance cars they either need to add another gear or have an "overdrive" unit or something, as I think you really need 6 to keep power at a good place. I applaud Porsche for their 7 speed manual
Old 12-03-2011, 09:26 PM   #21
Deslock
Deslock's Avatar
According to the spreadsheets at http://www.rx7club.com/showthread.php?t=541682, the FT has plenty of power to overcome air and rolling drag at 136-144 MPH after upshifting to 6th. I guesstimated 5800 RPM/135 HP at the wheels after the upshift, CoD = 0.27, frontal area approx 19.5-20.5 ft^2, sea level, and 65 F.
Even if you drop down to a slightly lower RPM, or if those spreadsheets aren't quite accurate (because they ignore increased losses due to internal friction or other factors), it seems there is enough of a margin to continue accelerating in 6th.
However, I have no experience calculating top speed and I've not driven more than 135 MPH, so I'm far from an authority on this. And I don't care about top speed anyway... I'm just curious because of the comments that it's limited by redline rather than the computer (perhaps it was a mistranslation).
Old 12-04-2011, 03:39 AM   #22
cossey
Drives: Reanult Megane R26
It will almost certainly do 62 in 2nd. Everywhere but the US and Canada now use 0-100km/h (0-62mph) as the benchmark so I would be very surprised if they made the car need a gearchange. Even the UK no almost entirely uses 0-62 (well the manufacturers do anyway)
Has it been confirmed that the red line is the same in all gears as it is quite common to have a higher redline in 1st and 2nd now?
Edit: EVO confirms that it does 62 in second:
"Taken all the way to the redline the BRZ should be capable of dispatching 0-60mph in just under second (typo seven?) seconds (I guessed 6.7 and my chaperone just smiled), but it feels like the gearing has been very carefully chosen for the benchmark – the manual transmission (just) allows 100km/h in second gear. Actually getting a sub-7 0-60 would mean interfacing with the rev limiter a couple of tenths afterwards."
cossey is offline   Reply With Quote
Old 12-04-2011, 09:01 AM   #23
Deslock
Deslock's Avatar
I've assumed since seeing the video's 7300 RPM upshift at 97 km/hr that you'd be able to hit 100 km/hr before fuel cutoff (though at least one report puts that at 7450).
Old 12-04-2011, 03:19 PM   #24
Dimman
Kuruma Otaku
Dimman's Avatar
I did a quick scan of the RX7 post and didn't see anything on wheel or tire friction losses.
I guess it will depend on how much of a fuel-economy gear they want 6th to be.
I did a gearing spreadsheet using the GenCoupe V6's transmission gear ratios (all I had handy) and a 4.10:1 final drive (GenCoupe's is 3.54:1) giving the 86 a theoretical top speed of ~167mph in 6th with 215/45R17 tires and the 5-6 shift putting the car at 5800rpm. Redline top speed in 5th would be ~132mph. From that it looks like it could break 132mph in 6th, especially if it's as slippery drag-wise as they claim.
(More real data on this car would be nice...)
Because titanium.
Old 12-27-2011, 09:32 PM   #25
DSPographer
DSPographer's Avatar
Drives: '13 BRZ Lmtd
Gear Ratios From GT5
From the GT5 game the GT-86 has the following gear ratios:
3.626
2.188
1.541
1.213
1.000
0.767
The Differential ratio is listed as 4.1 which would give the following redline speeds with 215/45R17 tires:
35.6
59.0
83.8
106.4
129.1
168.3
The video in the first post implies that for the 2nd and 3rd gear ratios above the differential ratio should really be about 3.92.
Using this value results in the following redline speeds:
37.2
61.7
87.6
111.3
135.1
176.1
Last edited by DSPographer; 12-27-2011 at 09:35 PM. Reason: Edited for more readable formatting
DSPographer is offline   Reply With Quote
Old 12-27-2011, 11:01 PM   #26
Deslock
Deslock's Avatar
Thanks for the info... I'd noticed that GT5's gearing is shorter, but hadn't yet looked it up (I cut my hand and haven't been able to play GT5 since initially trying out the GT86).
It's also noteworthy that someone posted that the top speed they were able to attain in GT5 is 137 MPH.
Anyway, I hope the real-world production gearing is closer to the game rather than what's in the Subaru promo video.
Old 02-17-2012, 12:38 AM   #27
serialk11r
Hey guys I noticed that on the S2000 for example they list primary reduction ratio for the gearbox, but on Toyota cars you can't find this...
Is primary reduction something that varies a lot? Between all AZ6 transmissions, is it likely that any gearset or primary reduction gearset would interchangeable? I'm trying to think of ways to lower the 6th speed ratio.
Old 02-17-2012, 09:55 AM   #28
old greg
Rocket Surgeon
Drives: PSM GGA OMG
I'd imagine that's because there isn't one. I'm assuming that the S2000's primary reduction is at the gearset that links the input shaft to the countershaft. On most transmissions it's simply a one to one ratio and if more reduction is needed it happens at the ring/pinion. I'd assume that a 1:1 gearset with the 9000 rpm redline would have caused some bearing or shaft to spin faster than the engineers were comfortable with.
old greg is offline   Reply With Quote
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 12:22 AM
Guesses about Gear Ratios and Wheel Torque Deslock BRZ First-Gen (2012+) — General Topics 4 12-01-2011 06:15 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
Top gear USA 4agze Off-Topic Lounge [WARNING: NO POLITICS] 25 12-08-2010 11:01 PM
Toyota FT-86 weight -- take your guesses JDMinc Scion FR-S / Toyota 86 GT86 General Forum 51 03-24-2010 06:57 PM
