#16 |
Personally I'd like to see the limits of a Vortech SC kit on the track, with no other supporting mods to it. For the car, perhaps pads/fluid, street tires, and suspension. Curious whether the kit will hold up and what kind of heat problems you'd run into in a 30 minute session, especially the way you drive (no offense!).
2022 BRZ Build 2013 FR-S Build |
#17 |
Drives: SSM LT MT BRZ
@CSG Mike: you know how it is man, I'm a perfectionist, it HAS to be just so...prefer to deal with heat concerns now rather than later....you'll be the first to know I assure you
| The Following User Says Thank You to SkullWorks For This Useful Post: | CSG Mike (04-25-2013) |
#18 | |
Drives: B9 S4/ND2
#19 | |
...was hoping for a bit more durability than that.
#20 |
Drives: Subarus
| The Following 5 Users Say Thank You to EarlQHan For This Useful Post: | Anthonytpt (04-25-2013), CSG Mike (04-25-2013), Racecomp Engineering (04-25-2013), Ro_Ja (04-25-2013), SkullWorks (04-25-2013) |
#21 | |
Would not recommend without: - Vented hood of some sort - Aftermarket Radiator - Radiator shrouding - Oil cooler I'll try it again if someone offers to let me drive their car. |
#22 | |
#23 |
Brake ducts, radiator shroud testing, vented hook testing (removal of rubber at glass)
#24 |
Drives: frs
ever test 255 on 18x9.5?
and... Aero! wings and then splitters! |
#25 |
Drives: 2013 SWP BRZ
Have there been any oil temp readings w/out oil cooler vs. oil temp reading w/ oil cooler? do the temps on track really necessitate an oil cooler (280+)?
From what I've seen it's only been on dynos that people saw oil temps go high enough to sacrifice some HP, but theres a whole lot more airflow at speed on track. I haven't seen anyone say they NEEDED an oil cooler after a day on track. |
#26 |
Drives: Nevermorange FRS
I 2nd that motion.
PRO86 | WTCC | STL
#27 |
Drives: 4 wheels & some metal bits
An set of options to test for a bunch of folks looking at not dropping a ton of cash on suspension...
- stock springs + OEM shock vs: - RCE Yellow Comps + Koni - Swift Sport BRZ Springs + Koni - STI Pink + OEM |
#28 | ||
Drives: White MT FR-S
I wonder if the oil cooler placement is contributing to the heat problem. IIRC the AZ car mentioned above no longer had the oil cooler in front of the radiator and intercooler. |
| T1R Oil Cap - Product Release | FT-86 SpeedFactory | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 10-07-2013 06:55 PM |
| P&L Header Dyno and Fitment test-With my Vortech Test Kit | Huehuecoyotl | Engine, Exhaust, Transmission | 118 | 07-07-2013 10:26 PM |
| New Cusco product | ahaghshenas | Engine, Exhaust, Transmission | 5 | 05-27-2013 02:44 PM |
| Product Testing : FREE Dyno Baseline? | Drift-Office | Northwest | 12 | 04-10-2013 07:45 PM |
