Old 04-23-2013, 07:16 PM   #183
warman
warman's Avatar
Drives: WRB BRZ
Originally Posted by xjohnx View Post
Likely. SoloStorm is $200 though on android. Harry's Lap Timer is only $27 on iOS. I'm working to see if he can add AppRadio support.
That is quite the difference. I have all iOS devices as it is, but I don't think they'll come out with a head unit since it's not open source. I think the Ipad Mini is the perfect size, but I'd much rather have an indash unit than something mounted to the dash.
warman is offline   Reply With Quote
Old 04-23-2013, 07:21 PM   #184
xjohnx
Grip>Slip
xjohnx's Avatar
Get a Pioneer head unit, either an AppRadio, or an AVH series unit. You can then mirror your iphone apps to your head unit and control them through your head units touchscreen. That's what I've got in my car. Was working great with my iPhone 4, just waiting on a firmware update to support that iPhone 5 cable. Should be any day now.
[ame="http://www.youtube.com/watch?v=NrcP7-DjKRs"]AppRadio- The Revolution Continues.mp4 - YouTube[/ame]
Check out the 2:00 mark of that video
warman (04-24-2013)
Old 04-23-2013, 08:14 PM   #185
VoiD
Drives: 13 WRB BRZ
Originally Posted by Blown_xa View Post
what was camber?
-1.5 front -1.7 rear 0 toe
VoiD is offline   Reply With Quote
Old 04-23-2013, 10:21 PM   #186
UncleFester
Are those settings what you wanted? Or are you limited by equipment?
Originally Posted by davtbaum View Post
Had a great time - although punctured coolant pipe led to this on my friend's e30
Sorry to hear you guys didn't make it back. Was fun chatting with you two during the day and in grid.
UncleFester is offline   Reply With Quote
Old 04-23-2013, 10:38 PM   #187
VoiD
Drives: 13 WRB BRZ
Wanted -1.5 front and -2.0 rear but ended up with those numbers. I can run more up front with camber bolts in kw upper holes, rear seems limited up to -1.8 or 1.9 without LCAs.
Old 04-23-2013, 11:21 PM   #188
ptuning
ptuning's Avatar
Drives: White FR-S
If you plan on autocrossing more often, then definitely try to dial in more negative camber up front. Your current settings will cause the car to understeer quite a bit.
Unlike cars with double wishbone front suspensions, the front struts on the FR-S/BRZ have very little negative camber gain under compression. For your street driven car, you may want to start at -2.5 up front and go from there.
For this past autocross, we really wanted to run -3.5" camber up front on our shop car, but could only muster -1.6" because of clearance issues with the 255 tires and the factory struts (our coilovers didn't arrive in time).
Anyhow, the result, which was no surprise to us, was fairly heavy understeer. This really killed our speed through the two skidpad sections. I had to try extra hard to make up the time through the other sections of the course.
If you'd like to pick our brain about alignment settings, please feel free to stop by or give us a call.
- Toan
ptuning is offline   Reply With Quote
The Following 3 Users Say Thank You to ptuning For This Useful Post:
kanundrum (04-23-2013), leon78 (04-24-2013), VoiD (04-24-2013)
Old 04-24-2013, 10:05 AM   #189
warman
warman's Avatar
Drives: WRB BRZ
That is sweet.. I'm going to have to check this out. Thanks.
Old 04-24-2013, 11:20 AM   #190
warman
warman's Avatar
Drives: WRB BRZ
Here's a video of one of my runs. Not the best quality, but I thought it was cool that you can see most of the course from the grandstands.
[ame]http://youtu.be/PnvUjufFwfY[/ame]
Old 04-26-2013, 07:56 AM   #191
xjohnx
Grip>Slip
xjohnx's Avatar
If any of you are interested, try this time trial on May 11th. It is run like an autocross (standstill start, one lap).... but it is around a 2.5 mile road course.
It isn't too much further south than VMP!
I'm considering signing up for this. Do they have you work the corner stations when not driving, or does the track/organization provide their own corner workers?
Anyone else considering it?
Old 04-26-2013, 09:05 AM   #192
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I am. Its not that far away and it looks like tons of fun.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 04-26-2013, 09:40 AM   #193
kanundrum
Drives: 2013 Whiteout FR-S
Any other weekend I would be down dang already made a commitment I don't want to change.
Old 04-26-2013, 10:44 AM   #194
UncleFester
This is exactly what I was thinking as well. Unless you are trying to overcompensate for steer conditions with alignment, which you shouldn't be, I would never run more camber in the rear on this car. I think -2.5 front and -1.5 rear is the sweet spot on these cars, and you can adjust for driver preference from there. On the twins, you will need to invest in adjustability parts in order to get a proper racing alignment; IE camber plates, LCA's, bushings, bolts, etc.
Old 04-26-2013, 10:55 AM   #195
thejevans
Rugger Extraordinaire
thejevans's Avatar
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
I'm in!
1994 Plymouth Acclaim - Engine died and went to cash for clunkers
2001 Dodge Neon R/T- Hydro-locked engine and parted out
2003 Nissan Sentra SE-R Spec-V - Traded for next car
2013 Scion FR-S - Got taken out by a distracted driver while I was sleeping. Total loss.
1997 Mazda Miata - Current
thejevans is offline   Reply With Quote
Old 04-26-2013, 04:05 PM   #196
xjohnx
Grip>Slip
xjohnx's Avatar
First run of the day in my car, before we got tire pressures sorted out. Codriver was driving,but needless to say, thing was a bit of a handful.
PTUNING: 2013 Scion FR-S R&D Car Mrc@ptuning Member's Car Journals 67 04-18-2015 08:42 PM
Ptuning Spring Cleaning Meet March 23, 2013 Events@Ptuning Mid-Atlantic 58 05-09-2014 12:26 AM
Brakes unless at high speed - what to tackle? empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 10-12-2012 05:06 PM
Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) Levi BRZ Photos, Videos, Wallpapers, Gallery Forum 43 05-16-2012 12:37 AM
Casey Stoner high speed cornering at 1000fps tranzformer Off-Topic Lounge [WARNING: NO POLITICS] 6 08-01-2011 04:20 PM
