Old 04-23-2013, 09:26 PM   #15
Driveshaft Shop
Drives: 31 Ford, Viper GTS,65 Riviera,Cayen
Thanks for all the posts guys, we actually have been making this for some time now. it lists for 999.99 and is done with the new style ends. What will set this apart from the others is we are using Billet Aluminum ends, a smaller 2.75 outer diameter that was custom made for us by ACPT. its a High Modulus carbon tube. this and also the fact that the shafts are actual speed balanced. What do i mean by that ? most balancers will spin at a lower speed. We had a custom unit that will spin a shaft with in 10% of critical speed or 9600rpm.
here is a video, not the best but i think you will get the idea.
[ame="http://www.youtube.com/watch?v=3fCzP7YL3-k"]Driveshaft Shop high speed balancer .mov - YouTube[/ame]
look at the perfectly machined billet ends, this shaft has been tested by some very high profile drives in many forms of racing.
We also have a Aluminum version for 449.99, there some questions about clearance under this car. The WRX and STI has its small tunnel but the FRS/BRZ I'm happy to say has allot more room so no more clearance issues.
Driveshaft Shop is offline   Reply With Quote
The Following User Says Thank You to Driveshaft Shop For This Useful Post:
DAMotorsports (08-30-2013)
Old 04-23-2013, 09:28 PM   #16
Driveshaft Shop
Originally Posted by TRD_07 View Post
Weight and price?
as i recall its about 14lbs, 999.99
Old 04-23-2013, 09:29 PM   #17
Driveshaft Shop
Originally Posted by Captain Insano View Post
And... Will this be available for the Automatic Trans cars?
Product looks great. Thanks for posting all the information.
i dont see why not, i have only done the manual so far but if some one were to send me a sample i would make the ASAP.
Old 04-23-2013, 09:30 PM   #18
tisb0b
Drives: Grey GT86 MT
How much does the aluminium weigh? How much does the stock drive shaft weigh?
tisb0b is offline   Reply With Quote
The Following User Says Thank You to tisb0b For This Useful Post:
Calum (04-24-2013)
Old 04-23-2013, 09:35 PM   #19
Driveshaft Shop
Originally Posted by tisb0b View Post
How much does the aluminum weigh? How much does the stock drive shaft weigh?
ill have to pull the sample out of the sample room tomorrow, i have the one from the factory FRS road race car. ill post them up tomorrow with some shots of the aluminum shaft under a car at Dynosty.
Pete (04-24-2013)
Old 04-23-2013, 09:36 PM   #20
FT_Monk
Drives: Over the hill WRX
Originally Posted by swift996 View Post
Not trying to incite a war but do you compare to expand on why?
I don't want to create trouble neither. To make a long story short: for $1200 I purchase a 800hp rating advertised horse power rating custom axles for my WRX as I was installing a bigger diff. The axels did not have any provision for dust shields. But that was nothing compared to the axels making clunking noises. I kept complaining to DSS but no solution. One day I tugged on the shaft and the splines were already broken off due to metal fatigue. My car was a daily driver and has like 210 horse to the wheel. DSS did replace the broken axle with a new one, I sold the axels cheap and return to stock and everything is fine until today.
FT_Monk is offline   Reply With Quote
The Following User Says Thank You to FT_Monk For This Useful Post:
swift996 (04-23-2013)
Old 04-23-2013, 09:59 PM   #21
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
@Driveshaft Shop When do you expect these to be available?
Old 04-23-2013, 10:17 PM   #22
nonicname
Drives: it has 4 wheels and a motor
how much is the factory shaft?
We are all interested in knowing the weight savings as this is rotational weight.
nonicname is offline   Reply With Quote
Old 04-23-2013, 10:21 PM   #23
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
It sounds like there was a problem, and it was taken care of once the problem was diagnosed. Sometimes there are mistakes in the manufacturing process. It happens to every company large and small. Still, it's hard to forgive vendors when problems do occur.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 04-23-2013, 10:53 PM   #24
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Looks awesome!
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 04-23-2013, 11:00 PM   #25
nonicname
this, shaft + all lightweight pulleys+ lightweight flywheel+lightweight wheels BUM!
can you imagine all the rotational mass you would take off that engine!
I bet the ECU would go crazy with this. I'm sure all this would require a tune.
Old 04-23-2013, 11:17 PM   #26
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Originally Posted by nonicname View Post
this.
He already said he'd post it tomorrow. Chill.
Chewie4299 is offline   Reply With Quote
Old 04-24-2013, 09:58 AM   #27
Driveshaft Shop
Give us a call, it takes us about 1-2 weeks to build the driveshaft
Old 04-24-2013, 10:10 AM   #28
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
PM sent
Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! F-T Exterior Parts - The Rest 285 08-24-2015 04:42 PM
Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) master345 Cosmetic Modification (Interior/Exterior/Lighting) 56 05-04-2014 11:10 AM
The Driveshaft Shop Custom Axles and Shafts Sportsguy83 Engine, Exhaust, Transmission 26 01-11-2013 04:55 PM
Automatic Carbon Fiber Driveshaft? Yes! RallySport Direct Engine, Exhaust, Transmission 13 12-15-2012 12:40 AM
