Old 04-23-2013, 03:39 PM   #29
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Originally Posted by shu5892001 View Post
Yep no need to lower, 35 to 40 offset you should be fine
If I go with 17x9 +35..can I still use the stock tire from the car?
Old 04-23-2013, 03:43 PM   #30
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
you probably don't want to... 215 is too skinny for a 9 inch rim. I would do at least 245/40/17
shu5892001 is offline   Reply With Quote
Old 04-23-2013, 03:51 PM   #31
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
ok. good to know.
Old 04-23-2013, 03:53 PM   #32
g0lden
Drives: 2013 Scion FR-S Argento
Lots of good info in this thread :-)
thanks
g0lden is offline   Reply With Quote
Old 04-23-2013, 07:34 PM   #33
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
I don't know why ppl want to run a nice fat rim and then run a skinny tire.
DAN_BRZ is offline   Reply With Quote
Old 04-23-2013, 08:03 PM   #34
CSG David
CSG David's Avatar
We have a 235/40/17 on a 17x9 +35. By the look of it, I'd say we wouldn't go any narrower. A 245/40/17 will retain similar rolling revolutions as the 215/45/17 tire.
Old 05-02-2013, 10:45 AM   #35
DAN_BRZ
DAN_BRZ's Avatar
im having such a hard time with this decision.
i like the idea of going square 18x9.5 255/35r18, but i dont want the front to poke, and im trying to go against going staggered. anyone know of any non aggressive 18x9.5 front setups?
Old 05-02-2013, 12:14 PM   #36
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
35-40 you should be golden, not sure about 40+
+42 is perfect, in my opinion. We run 255/40R17 on our car, no spacers. It clears the suspension.
They have to, because they selected too low of an offset, so their tires will run into the fender if they choose a tire that matches the wheel width.
To my way of thinking, if you can't run a wide enough tire to match your wheel width, you might as well choose a narrower wheel, and save some weight...
...anyone know of any non aggressive 18x9.5 front setups?
As I detailed in this thread, our 18x9.5" Wicked Awesome will just clear the front suspension, although when we fit it with a 265/35R18 the tire rubbed the strut until we added a 3mm spacer. With a narrower tire, it might clear without a spacer.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
The Following User Says Thank You to Mach V Dan For This Useful Post:
shu5892001 (05-02-2013)
Old 05-02-2013, 12:39 PM   #37
DAN_BRZ
DAN_BRZ's Avatar
[QUOTE=Mach V Dan;906365]+42 is perfect, in my opinion. We run 255/40R17 on our car, no spacers. It clears the suspension.
what suspension is your car on?
Old 05-02-2013, 12:44 PM   #38
DAN_BRZ
DAN_BRZ's Avatar
a lot of ppl running staggered are going with a 225 front, would a 245 not fit with the 18x8.5 up front with an offset of +33?
Old 05-02-2013, 01:13 PM   #39
Mach V Dan
Mach V springs, stock struts.
--Dan
Mach V
Old 05-02-2013, 03:59 PM   #40
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
How much stiffer are the Mach V springs than stock on a BRZ? Don't want to go crazy stiff as we like the feel of the stock car's springrate. Those Awesome wheels are, well, awesome! Clean, light, fat - what more could you ask for!
boarder1995 is offline   Reply With Quote
Old 05-02-2013, 09:27 PM   #41
Mach V Dan
28% stiffer than stock in front, 30% stiffer rear.
--Dan
Mach V
Old 05-03-2013, 11:25 AM   #42
DAN_BRZ
DAN_BRZ's Avatar
mach, im really liking the flushness of this setup, how much of a drop are your springs?
Wheel Directory: ESM 004 17x9.0 +38 Scott Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 06-26-2017 04:54 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WEDSSPORT TC105N 17x8.0/17x9.0 and 18x8.5/18x9.5 *** with Special. Ed Sticker *** RavSpec Wheels and Tires 47 06-22-2013 11:49 AM
FS in FL: Drag DR-31 17x9" Square setup 5x100 (or 5x114.3) +38 GTB/ZR-1 Wheels and Tires 1 12-06-2012 07:22 AM
