Old 11-17-2012, 01:06 PM   #29
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Ok thanx guys...going to try and see what i get
brichard0625 is offline   Reply With Quote
Old 11-25-2012, 06:12 PM   #30
ANTI_LAG
ANTI_LAG's Avatar
Drives: Ones with Big Turbos
We just finished another local customers car fitted with our turbo kit and wouldn't you know, this problem is showing its ugly face... P0017 along with a random misfire once it gets too rich.
ANTI_LAG is offline   Reply With Quote
The Following 2 Users Say Thank You to ANTI_LAG For This Useful Post:
cobrabyte (11-26-2012), eurospeed (11-26-2012)
Old 11-26-2012, 12:06 AM   #31
BRZranger
What was the solution? Remove turbo and bring to dealer? I can't imagine the turbo is causing that code which is showing up / being repaired under warranty for stock cars.
BRZranger is offline   Reply With Quote
Old 11-26-2012, 02:52 PM   #32
AVOturboworld
Yes, in our case it happened about 2000 miles before the turbo kit.
Old 11-26-2012, 04:12 PM   #33
Synack
Boosted
Synack's Avatar
Drives: Sideways
Is it possible this came up in my car as well?
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 11-26-2012, 06:58 PM   #34
ANTI_LAG
ANTI_LAG's Avatar
No your car did not have any idle issues like that.
Old 11-26-2012, 08:08 PM   #35
Synack
Boosted
Synack's Avatar
Drives: Sideways
Not yet **knocks on every piece of wood within 10 miles**
I'm only at less than 3000 miles still. I'll be switching to 10W-40 when I get the car back, that's for sure.
Old 11-26-2012, 08:56 PM   #36
FirestormFRS
Speaking only of another manufacturers VVT pulleys.....
They are both electrically and hydraulicly acuated. Basically the Oil Control Valve (electrical) is given the command to increase oil flow or decrease flow to the VVT. The oil then either advances the timing or the lack of oil causes the VVT to slow down and retard timing.
Not going back to zero could mean the OCV isn't controlling the VVT properly or that the ECU isn't getting the right information from the Cam Angle Sensors. Sooooo long story made longer. The culprit could be ECU, Flash, OCV, VVT, Cam Angle Sensor, Wiring harness from ECU to OCV or CAS, or a partially blocked oil passage that doesn't allow the oil to escape the VVT fast enough.
There are so many variables involved you'd have to start at one point and change parts until the problem went away. That's the reason the problem has been so hard to solve.
TL;DR There are many different things that could cause this issue.
FirestormFRS is offline   Reply With Quote
Old 01-11-2013, 03:31 PM   #37
choi0706
Drives: t
any update avo?
choi0706 is offline   Reply With Quote
Old 01-11-2013, 05:07 PM   #38
AVOturboworld
My apologies, I updated our turbo thread, but overlooked this one.
Once the very latest Ecutek ROM came our way and we redid the maps to use it, the issue with the cams went away, or at least appeared to. So to confirm, I drained out the 10w40 oil and put in 0w20 as per manufacturer specs. It still has shown no signs of the issue on the logs, so at least in our case we can say it's ecu-software based.
That said - looking at the live logs, the cams react much quicker on the heavier oil than on the lighter. It also idles much more rock solid on the 10w40, once the 0w20 went back in, it gets a little bit of a dip/bounce once in a while. I'll run on the 0w20 and continue to log to see what the overall reaction is.
The Following User Says Thank You to AVOturboworld For This Useful Post:
BRZranger (01-11-2013)
Old 04-23-2013, 12:41 AM   #39
R2
Has there been any more discoveries or observations regarding this issue over the last few months?
R2 is offline   Reply With Quote
Old 04-23-2013, 01:06 AM   #40
AVOturboworld
None, I've not had a single issue since.
Old 04-23-2013, 11:53 AM   #41
jesperswe
Drives: GT86
I wonder what would happen to my stock GT86 if id put 10w40 oil in it, instead of the factory 0w20. Noticed you wrote that it idles more solid. Mine idles kinda harsh when it's cold.
jesperswe is offline   Reply With Quote
Old 04-23-2013, 11:56 AM   #42
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I currently have Amsoil Signature 5W30 in my engine that is Vortech supercharged and I still get idle dips from time to time. Otherwise it feels the same as 0W20.
F1point4 is offline   Reply With Quote
My BRZ Saga touge-n00b BRZ First-Gen (2012+) — General Topics 23 05-21-2012 10:17 AM
