Old 04-17-2013, 12:11 PM   #71
dc50818
Drives: 2013 scion frs
http://auto-blip.com/auto-blip
dc50818 is offline   Reply With Quote
Old 04-17-2013, 12:25 PM   #72
jamesm
I've noticed that the fr-s, even with its near-perfect (for me) pedal placement, is very hard to heel-toe. It seems the first 10-15% of the the throttle is 'laggy' so to speak. I think the drive-by-wire is a bit less than perfectly linear.
Old 04-17-2013, 12:30 PM   #73
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by dc50818 View Post
fail
auto blip is an accident waiting to happen. Heel Toe, downshift blip etc etc is not difficult to learn it just takes practice. I'm sure clutch-less down shifting is also easy to learn... it's just the learning process that scares me because when you get it wrong it frags the synchro's or gear teeth (not sure which and perhaps both).
I think that is the essence of the whole debate. Shifting with the clutch protects the trans from improper rev matching. Shifting without the clutch does not.
Old 04-21-2013, 10:43 PM   #74
Nezz
86DESU
Nezz's Avatar
Drives: 86 GTS, S13, CB9
Blipping the throttle in my Silvia prevents wheel slip. It has functioning synchromesh but it wasn't really built for a tiny flywheel and enormous rear tyres, either. Probably overdue for an upgrade in the box.
Careful. It's contagious!
Nezz is offline   Reply With Quote
Old 04-21-2013, 11:31 PM   #75
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Originally Posted by ft_sjo View Post
You mean apart from 2nd gear synchro which is too small, too heavy, and is the biggest culprit for it not wanting to go into 2nd when cold. Oh and the huge gap between 1st and 2nd doesn't help either. I'd be surprised if anyone really knows the true reason for that big gap, though.
Gear ratio, and "Because race car"
LeeMaster is offline   Reply With Quote
Old 04-22-2013, 01:12 AM   #76
ft_sjo
Drives: GT86
No.
Mix 'n Match and Misc. Limit Scion FR-S / Toyota 86 GT86 General Forum 3 04-12-2013 04:45 PM
Color match question cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 5 02-06-2013 05:30 PM
White out paint match ?? xpicer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 10-11-2012 01:04 PM
Proper way to Rev Match pinoyplaya Engine, Exhaust, Transmission 46 09-05-2012 02:09 PM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 12:05 PM
