Old 04-20-2013, 10:22 PM   #1
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Spring rates for Super charged FRS
Does anybody else think it's a good idea to increase the front spring rates for a Vortech super charged car.
Gregg
jdzumwalt is offline   Reply With Quote
Old 04-20-2013, 11:06 PM   #2
wootwoot
Drives: FRS
I would suggest a brake and suspension upgrade. You need to make that thing stop and turn fast now that it has all that extra power.
At minimum: brake fluid, brake lines, pads, springs, shocks/struts, tires, and maybe a front sway.
Just my opinion.
Old 04-20-2013, 11:31 PM   #3
fatoni
i dont think a supercharger is really heavy enough to warrant a change in the spring rate. however, i think you may have upset the balance between the many aspects of the car and it might be in your best interest to bring the suspension and brakes up to par.
Old 04-21-2013, 12:04 PM   #4
Racecomp Engineering
Are you talking for coilovers or just lowering springs?
- Andy
Old 04-21-2013, 12:14 PM   #5
jdzumwalt
Motor Sports slut
Sorry Guess I should had been more specific. I already have AP brakes and Fluids. I swapped the springs from Front to rear from my KW kit. I think this may have upset the car and made it slower. I do know however it's good with more HP to have more weight transfer to allow the rear tires to hook up. I was thinking about running the setup in a 7.1F, 7.1R.
Gregg
Old 04-21-2013, 02:15 PM   #6
fatoni
Gregg
the springs dont really do anything to weight transfer. its the weight transfer that does things to springs.
Old 04-21-2013, 07:32 PM   #7
jdzumwalt
Motor Sports slut
I'm just trying to make sure the car hooks up. Too much spring no squat spins tires.
Old 04-21-2013, 10:32 PM   #8
wparsons
wparsons's Avatar
Do you want fast in a straight line, or fast on a track? The spring rates need for either are going to be different, as will the alignment settings.
flickr
Spring Rates - Track / Autocross Dave-ROR Tracking / Autocross / HPDE / Drifting 83 05-16-2023 05:56 PM
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 03:56 PM
BC BR coilovers standard spring rates for toyota 86 fiveoneone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-19-2012 01:16 PM
Weird GT 86 factory spring rates in GT5? Spec-Al Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 03-27-2012 03:30 PM
