#841 |
Drives: 2006 Scion tC
I completely forgot about SS brake lines. I may look into getting those at least.
#842 |
Drives: 13 brz, 06 STI
Got on the dyno today, here are the results. I am very happy with 176 whp and 140ft/lbs of torque. Had lots of others dyno, here are their results.
-BRZ with a Ecutek tuneand drop in filter put down 174whp 142tq -FRS with TRD exhaust and TRD intake put down 178whp 144tq -FRS with a Ecutek tune, over pipe, drop in filter and APR catback put 180whp 146tq.
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car) 1988 CRX si- b16A1 (Sold) RIP 2003 WRX |
#843 |
Drives: '13 FRS
Ours finally arrived last night. There's a little flaw in the 3M clear bra on the hood, so that will have to be fixed. Otherwise it's beautiful. I dropped in the arm rest, I love it, but we'll see what the wife thinks. I also compared my aftermarket door sills to the OEM ones and couldn't help but laugh... I just can't get into the OEM boy-racer door sills and pedals.
Boosted - nice build thread. Lots of great ideas in there... You drive a lot! Where did you get the hood dampers? Are those pedals anodized black or is it just the lighting? When I searched for the pedals I couldn't find them in anything but a plain aluminum finish.
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135 |
#844 |
Yes, they are SRPracing pedals. They are anodized. I love them they extend the gas pedal just enough to better heal toe. Have you done the clutch adjustment DYI yet? If not I can get you a form link its huge in making the driving experience better.
Here is the link, for the pedals website I have the grid pattern and black finish. Its once you go to the buy options that you can change the finish or pattern. http://www.srpracing.com/pd-surface-finish.cfm -Alex
#845 |
Drives: Ultramarine Scion FR-S
Hey Alex can you give me the link to the dyi for the clutch adjustment.
Sent from my DROID RAZR HD using Tapatalk 2 |
#846 |
Drives: 13 BRZ
Started the process to getting a BRZ today. If it all goes to plan i'll be moving over from a stage 3 legacy (already detuned to stock lats week) and an even faster '87 Grand National. Excited to have a simple car for a while...
#847 | |
Drives: '13 FRS
Thanks for all the info, Alex.
I remember reading about synchro issues and replacing the factory transmission fluid. Was a consensus reached on the best fluid to use?
#848 |
Drives: '13 FRS
Any build threads or anything you care to share on the GN? :happy0180:
#849 |
[ame="http://www.youtube.com/watch?v=OPJi3OAsax0"]How to adjust the clutch height for a BRZ / FRS / GT86 (The man pedal) - YouTube[/ame]
There is a video link to the clutch adjustment. This is to make the clutch more in line with the brake. In stock format it is much closer then the brake making one to have a more ackward seating posture. Just adjust what he says and make sure to hold the piece with the wires so that you dont snap them. It is super easy and takes 5-10mins. The clutch engagement automatically moves since it is only effecting the angle and not the actual engagement level. If the link or video doesnt show just youtube search brz frs clutch peddle adjustment. Very step by step, great video. I have had no shifting issues, sometimes when is cold 2nd can be a pain. I also have the whiteline trans bushing and perrin throwout bushing which tighten and make it much better. -Alex
#850 | |
Drives: '13 FRS
Thanks again. Are these the hood struts you used? http://www.ft86club.com/forums/showt...ght=gt+86+brah
#851 | |
Drives: 13 BRZ
#852 |
Drives: 13 BRZ
.... but it's no 10 second VR-4. I bet that is a blast on a good day!
#853 |
No I got mine long ago. Not sure on thr brand at this point. Grim speed makes great stuff I have their battery tie down and master cylinder brance. If this had been around when I was looking I would have bought their product.
-Alex
#854 |
Drives: '13 FRS
When I was regularly going to San Antonio Raceway, half the time there'd be this GN running 9's, very consistently. The owner was very friendly and knowledgable - buzn1/2duzn or something like that was his user name on local forums, if that rings any bells.
