Old 04-20-2013, 07:28 AM   #43
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Originally Posted by N_I_N View Post
Silly question. Would this setup be MORE prone to rubbing without lowering the car? I have no intentions of doing any suspension work on mine but I want to go as wide as possible with a square setup. Do these tires clear only because the car is lowered or would it be ok even if it weren't?
one big thing is that lowering springs and coilovers have springs that are smaller diameter than stock so the tire has more inner clearance
if it will rub out side? don't know.
dori. is offline   Reply With Quote
Old 04-20-2013, 08:07 AM   #44
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
it's generally only coilovers that give more room because of smaller springs, Even if replacement springs were smaller, the spring perch would still be in the way.
86•BRZ is offline   Reply With Quote
Old 04-20-2013, 05:10 PM   #45
djjd42
Drives: Whiteout MT now, Alfas in the past.
When lowering I did install the camber plate in the negative camber position, putting me at roughly -2 degrees. That surely helps keep the top of the tire tucked under the fender. As such, installing coilovers will help with inner clearance but it may very well require camber plates to get outer clearance like mine.
If you aren't going with coilovers then I am honestly not sure how wide you can go but doubt it ill be anywhere near 255.
djjd42 is offline   Reply With Quote
Old 04-23-2013, 02:43 PM   #46
N_I_N
N_I_N's Avatar
Drives: FR-S [Hot Lava]
I ordered mine today. I wanted black but needed a 35 offset so it looks like 10mm spacers are in my future.
I did 17x9 +45 with 245/40/17 Dunlop Direzzas
N_I_N is offline   Reply With Quote
Old 05-07-2013, 05:21 PM   #47
TheFirstScion
Early Adopter
Drives: Admins, please delete this account.
I'm in the same bucket. Don't know if I want ET35 or ET45. I have eibach springs that lower me an inch, not sure if that will make it more inclined to rub. I don't care about poke. I like the wide tire look.
I really don't want to install camber plates, and I don't want to use a spacer. I have never had a good experience with coilovers either, for any of my previous cars.
Maybe I should stick with a 17x8 :-(
TheFirstScion is offline   Reply With Quote
Old 05-04-2015, 05:28 PM   #48
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
I assume this was on stock suspension, any rubbing? did you put 5mm spacers on this one?
BRZ RN is offline   Reply With Quote
Enkei RPF1 17x8 Gold + Dunlop Star Specs 255/40/17 on SWP Premium Mitch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 01-08-2014 10:50 PM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
Yokohama ADVAN Neova AD08 vs. DUNLOP DIREZZA Star Spec z1 gmookher Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-13-2012 10:18 AM
