Old 04-19-2013, 04:32 PM   #99
Sonolin
Originally Posted by midnight23 View Post
It's growing in NorCal and SoCal decently, and they just opened a station in fresno, I wouldn't suggest a trip to vegas on it though. but LA <> SF is possible now on it.
That's news to me! I'll have to look into this - I have a road trip to northern california this year and I'd love to be able to run e85 the whole way!
Sonolin is offline   Reply With Quote
Old 04-19-2013, 04:44 PM   #100
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Jesse@JDLAutodesign View Post
You can't load the car on a dynojet...you can on the street. Dynapacks, mustangs, dyno dynamics, maha dyno can all simulate various load points. There may be an option for load control on new model dynojets but all the ones we have in the PHX area are older models and dont' have load control.
Dynojet has been doing load control for quite a few years. You could state that while all Mustang, Dynapack, and Muststang dynos have load control as standard, it is optional on the Dynojet.
Old 04-19-2013, 04:53 PM   #101
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Thats why i mentioned the ones we have around here are all older non load control ones. We have a dynapack across the parking lot so thats what i'm most familiar with.
Jesse@JDLAutodesign is offline   Reply With Quote
Old 04-19-2013, 04:58 PM   #102
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Hawaiian View Post
I LOVE it when people automatically proclaim any given dyno a "heartbreaker", especially when they have never run a vehicle on it simply on the word of the parts manufacturer saying their dyno is even lower than all other mustang dynos, or Dynojets.. or whatever. If I were a manufacturer I would want people to assume that my dyno ran low too.
The older dynodynamics software (that spits out plot like those in this thread) are very accurate when you use a 1.0 correction factor, so accurate that they are often proclaimed to be heartbreaker dynos because in that mode they read about 12 - 15% lower than dynojet and lower than most mustangs... That said.. they are also the easiest to inflate.. pick up the keyborad, hit the x key, enter desired correction factor, do another run . To combat this, dyno dynamics offers shoot out mode, which is a standardized mode that is not user correctable and prints out all the correction data on the plot. It produces numbers that are VERY close to crank HP numbers though.
@skatery1989
Amazing numbers man, im sure it pulls like a freight train. Still not sure what the issue was with your orginal tune when you dynoed it, it was either pulling timing or had not learned the timing advance. Regardless, looks very happy now on the corn juice, new compressor and pulley :happy0180: . Have you talked to vortech or perrin about running a wastegate to get more boost earlier in the rpm range?
Old 04-19-2013, 06:30 PM   #103
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Originally Posted by SnapOv3st3r View Post
Dyno Dynamics are called Heart Breaker dyno's for a reason. They are the only ones I use to get my numbers with. Mustang Dyno is low reading also.
This car would break 400whp easy on a dynojet, and probably 430whp on a Dynopack.
This is true only if the runs were done in Dyno Dynamic's shootout mode which locks the user from changing any settings or playing any games. If the dyno runs were done in Shootout mode it would say it on the chart. Shootout mode reads very low in comparison to say Dynojet, probably lower than a Mustang by a bit.
That being said since the dyno was not done in shootout more there is a correction factor that can be adjusted by the dyno operator. We find most Dyno Dynamics run with a .15 correct faction which makes them read similar to a Dynojet. However without knowing what correction factor was used for this it is tough to compare this to other dyno's numbers as it could be high or low. We had this same style Dyno Dynamics dyno for many years here.
OP skatery1989 Awesome I bet the car flys! No matter what factors are in use, I have no doubt this car makes good power. However I would love for you to ask the dyno operator what correction factor they use, or even better if you could go back and do some pulls in "shootout mode" to get a solid baseline to judge your cars power against.
Great job,
Adam
No Limit Motorsport is offline   Reply With Quote
Old 04-19-2013, 06:55 PM   #104
SnapOv3st3r
Drives: 400whp Scion tC
^That's my whole point. Trying to compare dynos from 3 different cars on 3 different dynos is pointless.
SnapOv3st3r is offline   Reply With Quote
Old 04-19-2013, 07:19 PM   #105
liteyouup
Drives: 2013 Scion FRS
Yeah, 365 at altitude is amazing...even more powwuhhhh at sea level.
Ususally numbers are corrected.... so it would make same numbers but would actually be a shit ton faster at sea level. Someone correct me if I'm wrong.
liteyouup is offline   Reply With Quote
Old 04-19-2013, 07:20 PM   #106
charged86
charged86's Avatar
I knew this was capable with the vortech kit ( I had hoped). Will have the same setup. Sadly skatery beat me. But I'm am very happy for him and extremely excited to get mine done. Maybe I will have the same results at @Dustin@Dynosty also I will be near sea level
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 04-19-2013, 08:07 PM   #107
cmss2000
Drives: 2013 BRZ Premium 2012 Acura TSX
Originally Posted by charged86 View Post
I knew this was capable with the vortech kit ( I had hoped). Will have the same setup. Sadly skatery beat me. But I'm am very happy for him and extremely excited to get mine done. Maybe I will have the same results at dynosty. Com also I will be near sea level
Hurry up!
cmss2000 is offline   Reply With Quote
Old 04-19-2013, 08:17 PM   #108
charged86
charged86's Avatar
Originally Posted by cmss2000 View Post
Hurry up!
As soon as @Dustin@Dynosty is available can afford to tune 93 pump injectors 12.5 psi and supporting mods. I need moneyyyyyyy. And good job skatery. Did he provide full mod list?
Old 04-19-2013, 08:43 PM   #109
Dustin@Dynosty
Great numbers! Looking forward to getting charged86's car on the dyno
Dustin@Dynosty is offline   Reply With Quote
Old 04-19-2013, 08:46 PM   #110
charged86
charged86's Avatar
Any day after may 1
Old 04-19-2013, 08:48 PM   #111
OrbitalEllipses
Drives: Attitude
Originally Posted by Coheed View Post
The majority of us will take perception over reality any day. Perception is more fun anyway.
The truth of the matter is that perception IS reality.
Old 04-19-2013, 09:11 PM   #112
charged86
charged86's Avatar
Originally Posted by 2forme View Post
What is this cars character? I would love to know.
honey badger on corn alcohol
When in doubt, shop around.. Jigga AUSTRALIA 9 09-06-2012 06:47 PM
Can anyone read Dutch? Buggy51 BRZ First-Gen (2012+) — General Topics 14 12-28-2011 09:48 PM
without a DOUBT how i want my BRZ to look dorisaru BRZ First-Gen (2012+) — General Topics 33 12-15-2011 07:31 PM
