Old 02-24-2013, 04:51 AM   #281
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by DriftEightSix View Post
ah... 1275kg's is like dry weight written on the spec sheet.
Anyone weight a fully laden car full trim with full tank, all liquids and a driver?
1650kg be my best.
By your logic, the same goes for the other heavier cars. Compare the curb weights of cars via spec sheets not by options, gas, driver. Too many variables.
Old 02-24-2013, 08:28 AM   #282
86drift
86drift's Avatar
Drives: Toyota 86 GT
1650kg be my best.
My 86 GT weighed in at 1,215kg with half a tank of fuel and no driver. Would need a big driver to make up 400kg :-)
86drift is offline   Reply With Quote
Old 02-24-2013, 10:21 AM   #283
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
Wow, 1650kg is massively heavy, rated curb weight is supposed to be with a full tank of gas. That's 3630lbs, for reference, the rated curb weight of my truck is about 3400lbs.
Mobius357 is offline   Reply With Quote
Old 02-24-2013, 04:07 PM   #284
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Well we should tell Toyota they need to update their specs or definitions..
http://www.toyota.com.au/86/specific...s_86_GTS_Specs
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 02-24-2013, 04:14 PM   #285
Gen
Drives: Scion FR-S
This was my corner balance with my heavy 200lb ass in the car. My car has actually gained some weight from being stock due to some sound deadening I've put in the car. So 2685 lb with 3/4 tank of gas.
LF: 830
RF: 766
LR: 675
RR: 614
Total: 2885
Front: 1596 / 55.32 %
Rear: 1289 / 44.68 %
Left: 1505 / 52.17 %
Right: 1380 / 47.83 %
Cross: 1441 / 49.95 %
Select: 0 / 0 %
Rear Bite: 0
Gen is offline   Reply With Quote
Old 02-24-2013, 07:19 PM   #286
Mobius357
I don't see anything out of place. 1275kg curb weight, that is, with all fluids and no pasengers or cargo. 1670kg gross. That's a little more than Subaru specs the BRZ here in the US, by about 20 kg, but reasonable, not knowing exactly what configuration the rating comes from.
Old 02-24-2013, 08:29 PM   #287
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
GVM is the maximum it can carry safely I believe
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 02-27-2013, 01:49 PM   #288
congiiee
Drives: WRB Subaru BRZ
hey skatery i forgot to ask you if you added any gauges to your setup
congiiee is offline   Reply With Quote
Old 03-01-2013, 10:09 PM   #289
skatery1989
Drives: BRZ Limited
I have not yet haven't found a pod I like.
skatery1989 is offline   Reply With Quote
Old 04-18-2013, 09:25 PM   #290
skatery1989
Drives: BRZ Limited
Lets see how the new blower works?
The Following 4 Users Say Thank You to skatery1989 For This Useful Post:
Coheed (04-18-2013), RedAlert (04-18-2013), reyruiz191 (04-18-2013), Sonolin (04-19-2013)
Old 04-19-2013, 12:00 PM   #291
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
Originally Posted by skatery1989 View Post
Attachment 34409
How are you defying gravity like that?
Brian@Vortech is offline   Reply With Quote
The Following 2 Users Say Thank You to Brian@Vortech For This Useful Post:
charged86 (04-21-2013), civicdrivr (04-24-2013)
Old 04-19-2013, 12:10 PM   #292
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Where does the water cooling from that hose hook up?
Old 04-19-2013, 12:42 PM   #293
skatery1989
Drives: BRZ Limited
That was for rinsing off the tiers it was muddy behind his shop.
Old 04-19-2013, 05:58 PM   #294
congiiee
hey skatery do you know how reliable it is to run 12 psi on our cars? I'm so tempted to do the smaller pulley now! xD
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
Vortech Supercharger Kits @Pure Automotive Performance Pure Automotive Forced Induction 25 01-16-2013 12:48 AM
Circuit Motorsports - SEMA 2012 Interview - Vortech Supercharger! Circuit Motorsports Forced Induction 6 11-06-2012 02:30 PM
