Drives: TRD Ultramarine '13
Where to look for HIDs?
Just like many of you, I hate the halogen headlights on the FR-S and would love HIDs, but at the same time, I don't want to just half-ass it and get a cheap HID kit for the halogen projectors, because then I'd have to retrofit LED's as well, and that's just a lot of work.
I was thinking of getting either GT86 headlights from Europe, or hopefully get them from Scion if they can be ordered after the Series 10's are released, or maybe from some wrecked BRZs. Where could I get them for the cheapest? And where should I go about looking for headlights from wrecked BRZs? (I live in Canada, so something specific to Canada would be helpful). |
#2 |
Drives: SWP BRZ
The Retrofit Source has a retrofit kit for the FRS which gives you good HID projector lenses and good ballasts.
http://www.theretrofitsource.com/pro...roducts_id=254 Then check this thread out for a DIY: http://www.ft86club.com/forums/showthread.php?t=10296 |
#3 |
Drives: 2013 MT Asphalt FRS
#4 |
#RememberTheBuster
Drives: Firestorm FRS MT
I believe with the retrofit, you are putting in HID projectors along with the bulbs
vs. Sticking in HID bulbs in Halogen projectors. The cut offs and beam pattern are different from HID/Halogen projectors. This is the only kit I'm aware of that has the projectors included with the bulbs and ballasts for a full retrofit. Every other kit it just The bulbs and ballasts so with every other kit, you'd essentially be sticking HID bulbs in the halogen housing. Which is no bueno. |
#5 |
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
^ which happens all the time cause most people don't care. However if you choose to go that route I still recommend the retrofit source, the morimoto plug and play hid kit is the highest quality standard hid kit I've ever seen. Assuming you don't do a proper hid projected retrofit, you will need to bend the sqirl finders down to compensate for the dif light pattern an stop as much glare as possible. The search function will take you to numerous threads talking about just that.
#6 | |
#RememberTheBuster
I retrofitted my girlfriends civic with the kit from TRS. They definitely have high quality products and will always buy from them whenever I need to. |
#7 |
Just drive it
Drives: 13' FR-S
hid bulbs in stock projector isn't that bad.
| The Following User Says Thank You to frslee For This Useful Post: | wawro569 (04-19-2013) |
#8 |
Drives: Raven Fr-s
I was considering hids for my low beams but then i stumbled across these.
http://automationled.3dcartstores.co...KIT_p_138.html frs uses h11 bulb btw |
#9 |
Amateur Drifter
Drives: '13 FRS
Diode Dynamics FTW
#10 |
PM Ken one of the best lighting vendors on here, has quality stuff and is one of the few who takes his ballasts apart to show quality difference between the generic ones.
http://www.ft86club.com/forums/showthread.php?t=8500 Did all of my lighting on my car from him.
| The Following User Says Thank You to Dezoris For This Useful Post: | KI_ZN6 (04-20-2013) |
#11 | |
Drives: Scion FR-S
| The Following User Says Thank You to jstans84 For This Useful Post: | Pin Flare (04-20-2013) |
#12 |
Drives: 2013 Ultramarine FRS
DDM tuning.
I've bought 5 sets from them(two for my last car, 55watt was too bright, had to change to 35w, two sets for my bike, and one set for the FRS) Only had 1 set that didn't work(55watt for the last car, one bulb's output was redish). At $30 for a set, its hard to say no, if one goes out, just buy another. |
#13 | |
#14 |
What's the best way to just get "white" light instead of the stock yellowish light. Honestly, that's really my end goal, but I do want to do it safely, and do want the mod to last.
| Best HIDs/ LESs Vendor | L3P47 | Cosmetic Modification (Interior/Exterior/Lighting) | 39 | 03-04-2013 04:19 PM |
| HIDs 8k | DAmarcus28 | Cosmetic Modification (Interior/Exterior/Lighting) | 37 | 10-31-2012 04:26 AM |
| Halo HIDs? | ExWhyZer0 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-12-2012 01:59 PM |
| Hids | Sh4rp | CANADA | 3 | 07-30-2012 12:25 PM |
