Old 11-30-2011, 09:24 PM   #15
brillo
Drives: 2013 Firestorm FR-S
I would guess you can get another 100lbs without gutting the interior etc.. light weight wheels, tires, battery, remove spare kit etc... will go along way. Wheels should make a real difference on a car this light already.
brillo is offline   Reply With Quote
Old 12-01-2011, 05:08 AM   #16
Levi
Drives: Toyota
The given weight is curb weight and dry weight, so this means with fluids and with 90% full tank.
The lowest weight is 1180 kg. It is for the car with 16" rims, without radio, A/C,....
The low-spec is at 1210 kg and high spec Subaru at 1230 kg.
Dry weight would be about +1100 kg
Levi is offline   Reply With Quote
Old 12-01-2011, 06:23 AM   #17
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
What's been leaked or released so far:
Toyota:
Racing spec is 1180-1190 kg.
Base trim is 1210 kg.
High-end trim is 1230 kg.
BRZ
"Estimated average" is 1220 kg.
So it'll be more than 2425 pounds dry (that was the weight of the race-prepped car at Nurburgring).
Deslock is offline   Reply With Quote
Old 12-01-2011, 06:41 AM   #18
Soravia
Drives: Miata Club
I assume the drive shaft is steel and will go around 40-70lb just like 240SX. That can be saved by aluminum drive shaft for around 20-25lb of savings. After light weight wheels and better Y split dual muffler, that'll be my next performance upgrade. Since header is equal length, it won't need to be touched. Scion will have very few interior parts other than seats with airbags that can be removed for significant savings.
Soravia is offline   Reply With Quote
Old 12-01-2011, 03:38 PM   #19
Kostamojen
The drive shaft isn't heavy on Subaru's. Maybe 25-30lbs at most, and this one is shorter than your average Subaru driveshaft so probably even less.
Old 12-01-2011, 03:46 PM   #20
c0rbin
Drives: 97' 240SX
Will probably get around 2350 lbs with moderate weight reduction. That's light!
c0rbin is offline   Reply With Quote
Old 12-01-2011, 03:56 PM   #21
Tainen
Drives: First SWP BRZ-L
I wonder if those lightweight seats will be an option that I've seen on some other threads. That'd be a cool option that would still get you good factory fitment and adjustment while lowering the weight a fair amount.
Definitely pulling the spare and throwing a can of fix a flat in there.
Tainen is offline   Reply With Quote
Old 12-01-2011, 09:04 PM   #22
e30kawi
Drives: CWP limited
I am just curious how this car is so heavy? I believe my wifes car to be just over 2600lbs (08 civic 4 door lx), seems like with it being a bigger car it would weigh more.
e30kawi is offline   Reply With Quote
Old 12-01-2011, 09:19 PM   #23
pastuch
pastuch's Avatar
THe DX is 2600... if your wifes is an automatic lx it's probably 2700. Valid question though...
pastuch is offline   Reply With Quote
Old 12-01-2011, 09:56 PM   #24
Kostamojen
I made a thread about this, I guess I need to bump it...
Old 12-01-2011, 10:12 PM   #25
e30kawi
Drives: CWP limited
Your thread seems to be talking about subarus and various motor weights, how can a eco modern car (2008civic 4dr auto) be so comparable to a car designed to be light?
Old 12-02-2011, 12:34 AM   #26
Steve Theodore
Drives: 2001 Porsche 911 Turbo
Send a message via AIM to Steve Theodore
One reason that comes to mind is that the FR-S is a MR layout, compared to the FF layout of the Civic. I suspect that the addition of a driveshaft and rear differential isn't going to be trivial.
However, also consider that the FR-S is being designed with even more safety/convenience features in mind (I suspect) and probably has sturdier hardware (brakes, wheels, suspension parts) to support its sporting intentions.
Steve Theodore
1993.5 Toyota Supra TT hardtop - SOLD
2003 Lexus IS300 5 speed (with LSD)
2008 Toyota 4Runner Sport Edition
Steve Theodore is offline   Reply With Quote
Old 12-02-2011, 02:13 AM   #27
Kostamojen
That was part of my analysis. FWD Imprezas weighed under 2400lbs. If you made a 2008 Civic RWD, it would wind up being over 2800lbs.
Old 12-02-2011, 03:23 AM   #28
Quantum
Drives: Infiniti G35
The US market BRZ will weigh 2770lbs.
Cheers,
Hong
Quantum is offline   Reply With Quote
How can i shave weight? fernan2 BRZ First-Gen (2012+) — General Topics 15 11-01-2011 10:31 AM
weight loss cynic Scion FR-S / Toyota 86 GT86 General Forum 36 10-24-2011 04:04 AM
Another Rumor About Weight Enzie Scion FR-S / Toyota 86 GT86 General Forum 1 10-23-2011 02:00 AM
Weight of FT-86? Levi Engine, Exhaust, Transmission 38 06-14-2011 10:43 PM
FT-86 weight distribution? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 15 04-04-2011 10:58 AM
