Old 04-13-2013, 05:58 PM   #57
norm24
Drives: TSX
I took mine from a Mazda. I had to modify it a bit so the locks will engage. I just hit the back of the pin with a flat head screw driver and done!
norm24 is offline   Reply With Quote
Old 04-13-2013, 11:24 PM   #58
jcat5150
Originally Posted by Retro86 View Post
nope because theres suppose to be 3 wires going to the turn signal. but the beauty of this thing is that you can disassemble that connector at the end and take the female pin out and put it in your stock connector as shown here....
http://www.ft86club.com/forums/showt...=29263&page=12
Why does the turn signal need 3 wires?
jcat5150 is offline   Reply With Quote
Old 04-14-2013, 02:44 AM   #59
Retro86
Retro86's Avatar
Drives: Awesome
there wires are red green and black, honestly i have no idea but id love to know why as well. maybe because it blinks.
Retro86 is offline   Reply With Quote
Old 04-14-2013, 07:56 AM   #60
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Apparently they are two filament bulbs. One for the blink and one for staying on as parking lights. 3 wires required.
FRSFirestorm is offline   Reply With Quote
Old 04-14-2013, 12:38 PM   #61
jcat5150
I ordered one, and will scavenge a wire / pin from the old connector for the third wire. I will take some pics in a couple of weeks when they get here.
Old 04-14-2013, 01:26 PM   #62
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
ever heard of junkyard?
imravenit is offline   Reply With Quote
Old 04-15-2013, 01:29 AM   #63
Lanbaldo3
Divine Wind - Dori
Lanbaldo3's Avatar
Drives: RWD
Nice!!!! You're The MAN!!!
1990 FC3S T2swapped! "Savannah"
1992 240sx Type X "Nadia"
2013 Scion FRS "Raven"
Drift Specials.....
Lanbaldo3 is offline   Reply With Quote
Old 04-16-2013, 01:08 AM   #64
norm24
Drives: TSX
I'm trying to pull the steering wheel off but it won't budge! Yes, the center nut is already removed. Is a steering wheel puller necessary or is there a trick to getting this damn wheel off?
Old 04-16-2013, 02:55 AM   #65
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
wiggle it a lil bit and use all your force im sure youve gotten it off at this point already..
Old 04-17-2013, 07:51 PM   #66
Willsonk
Drives: Scion FR-S Asphalt AT & XB
Any luck getting steering wheel off???
Willsonk is offline   Reply With Quote
Old 04-17-2013, 08:57 PM   #67
norm24
Drives: TSX
Yeah, I ended up using a steering wheel puller. Even with the puller, a bit of force is required to break it loose.
The Following User Says Thank You to norm24 For This Useful Post:
Willsonk (04-18-2013)
Old 04-18-2013, 01:49 AM   #68
Willsonk
Where did you order it from???? And how hard was it to take the steering wheel off for you????
Old 04-18-2013, 08:47 AM   #69
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
http://www.ft86club.com/forums/showthread.php?t=34078
full fog light kit
Old 04-18-2013, 10:01 AM   #70
jcat5150
Originally Posted by imravenit View Post
So they are doing the same thing we outlined here and scavenging a pin / wire from the "returned" turn signals. They could make 3 kits from each return (who cares about additional wire color).
  1. Bezels ~ $22x2=44 (Amayama or Nigel)
  2. Tundra Stalk ~$60 http://subarupartsforyou.com/cp_part...p?partid=23294 (Can also get JDM stalk with auto for future for ~$90)
  3. Outback Glass Fog Lamps $42x2=84 (subarupartsforyou.com)
  4. JDM Wiring Harness ~$32 (hokori-motor last price I got - would be less with larger qty) @Ebay or other source
Total = $220 DIY + various shipping costs to different locations
When I took my steering wheel off I just gripped at 3 and 9 o'clock / made sure I was pulling it straight and pulled like BOSS. It almost hit me in the chest if that gives any indication of how hard to pull.....
FRS fogs using BRZ stalk Sco2355 DIY (Do-It-Yourself) Guides 378 12-16-2018 05:17 AM
Factory shift light/chime Wonderbar Electronics | Audio | NAV | Infotainment 29 04-05-2013 03:30 PM
Manual shifter stalk thread dimensions for knobs bcj Scion FR-S / Toyota 86 GT86 General Forum 1 03-19-2013 06:42 AM
SEAT BELT STALK COVERS cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 1 03-01-2013 12:57 PM
FRS fogs using BRZ stalk Sco2355 Cosmetic Modification (Interior/Exterior/Lighting) 0 02-18-2013 01:51 PM
