Old 04-17-2013, 09:07 AM   #29
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
Originally Posted by Kodename47 View Post
Mine does not feel as good at low RPM as it did before, I'm certain of it. I posted in the other thread that I'm going to do some testing so we shall see. I'm not biased either way.
Where's your other thread? I could swear that the car runs worse than stock as well! I deleted all of the resonators, including those on the snorkels. For anyone thinking of resonator delete, I would recommend not doing it. Can't be sure though, as I'm using Unichip with a "stock cai + dropin tune" The problem may be that the tune isn't right anymore because it's a modified stock intake.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 04-17-2013, 11:58 AM   #30
Kodename47
Kodename47's Avatar
Drives: UK GT86
#215 on this thread. I will test it out, I'm collating MAP, MAF data for the road and dyno and dyno power data using different resonator configs. I will undoubtedly just put the main resonator back in and, fingers crossed, that will restore the stock airbox's performance.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-17-2013, 02:32 PM   #31
reeves
I have still yet to see any aftermarket intakes produce more power when tuned than the stock system with a filter.
I think a good comparison would be to test the STOCK intake (with aftermarket filter) vs. a complete aftermarket intake system, on a car with exhaust modifications.. after alot of hard driving.
Is it possibly that's where there'll be a difference in power gains on an aftermarket intake, especially a CAI..? Maybe the stock exhaust is SO restrictive, it really doesn't matter what intake you have on there.. But when you start modifying the exhuast to allow more air to move through the engine, the better intakes will start to show a little more gain? I'm no expert, just interested to see if there's more of a difference on more heavily modified car.
Old 04-17-2013, 03:53 PM   #32
Kodename47
Kodename47's Avatar
Drives: UK GT86
IMO, doing I/H/E isn't heavily modifying and I doubt that even then the OEM setup is a restriction. Once you start increasing engine capacity and/or changing cams then it may well be worthwhile to improve the intake.
Surely there must be some cars with exhaust, remapped with both CAI and stock box?
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-18-2013, 12:32 AM   #33
reeves
'Heavily modified' is the wrong term.. more like heavily bolted-on modded is what I meant. But the OEM setup is pretty restrictive, especially considering the 2 cats on the exhaust system. The engine is just basically an air pump afterall.. it can't draw in more air if it can't spit it back out at the same rate.
Restricting the exhaust might possibly restrict the intake as well is all I'm saying. So if you put in a more free-flowing exhaust system, maybe the better intakes will start to show themselves. But I didn't do any before & after air flow tests of my intake with my other mods, so it's just conjecture at this point.
Old 04-18-2013, 12:34 AM   #34
FA20Club.com
Drives: 2013 White Out FR-S
Originally Posted by jamesm View Post
Taking the front bumper off to change the air filter seems like a bit of a design flaw, but then some others are the same way. Personally I prefer stock intake (gains don't justify the PITA filter replacement) until the turbo is finished, then it'll probably be in the bumper and ill be complaining about how hard it is lol.
as stated plenty of times before front bumper doesnt have to come off to install or serve the filter in our intake
FA20Club.com is offline   Reply With Quote
Old 04-18-2013, 12:36 AM   #35
NickFRS
Drives: 2013 Asphalt FRS
I have mine deleted plus a custom tune.... My car runs perfectly fine. Maybe you should find a local tuner and not run a base map. I hate it when people make speculations w.o data to prove "it runs worse" I would personally recommend doing it because the car felt better to me and my led foot.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 04-18-2013, 12:51 AM   #36
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'd actually go as far as saying that the cats are only slightly restrictive, but for the time being I'm not on about the exhaust but I understand your point. Although swapping the front-pipe out doesn't create a huge jump in power, although I know it does help.
The opening of the stock air feed in 60mm, if you look at how much power a 60mm TB can support (It's well above 200hp BTW) then you have an idea of when the stock system becomes a restriction. I know the routing is more convoluted than a CAI but that will just change the power curve rather than choke the engine.
@NickFRS, I have to agree with @BuBlake that I feel the same. I don't think it's down on power though and I will dyno it to likely prove that, I just feel that at part throttle applications it's no where near as good as it used to be. I also have a custom tune BTW.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-18-2013, 08:47 AM   #37
jamesm
That's awesome! How do you do it?
Old 04-19-2013, 05:23 PM   #38
reeves
Unscrew the TOP and SIDE (wheel well) bolts/screws of the bumper, don't bother with the ones on the underside.. You can pull the top portion off & away from the frame far enough to install the intake.
www.ft86club.com/forums/showthread.php?t=31662
Old 04-19-2013, 05:28 PM   #39
mad_sb
Drives: 2013 Asphalt FR-S
Especially if you opt for the long body K&N filter (which has 30% more filter area than the aem dry flow)
Old 04-20-2013, 01:58 AM   #40
Lytheum
Drives: 2013 BRZ Premium 6MT
my intake came in yesterday. quality looks great...there does seem to be a lot of loose metal dust inside the piping. going to have to clean that out before it gets installed.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 04-20-2013, 05:04 PM   #41
maj75
Drives: Blue FRS 6sp, 95 M3
I have the Fa20 CAI with the AEM filter.
Pulled the bumper for the install as I was doing some other mods that required the bumper to be off the car.
I also have a Fa20club tune.
With the tune there is more power/torque at every rpm. The dip is flatter, but not gone entirely. The car sounds great from 2500 rpm and up, really a lot louder than stock. Install was pretty straight forward with the exception of the PVC hook up. I had to get a 90 degree fitting (Ford PVC) from Autozone to connect the PVC hose to the intake.
I have tracked the car as well and absolutely no driveability issues there or on the street.
Well worth the price of the intake.
maj75 is offline   Reply With Quote
Old 04-20-2013, 09:26 PM   #42
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
I'm also running this intake and the FA20Club ECU tune. Like a whole new car. I highly recommend it. Not the prettiest intake but I think it's the best design.
Bg8780 is offline   Reply With Quote
*Official Visconti Tuned Feedback Thread* - Suggestions, Comments, Questions Rich@ViscontiTuning Software Tuning 61 09-10-2013 07:09 AM
Track Tow Hook R&D Thoughts and Comments (Pictures) NON-VTEC Scion FR-S / Toyota 86 GT86 General Forum 24 02-06-2013 10:06 AM
Need to find FR-S/BRZ Acidz CANADA 5 09-17-2012 12:45 AM
Want the BRZ but can't find one kduff85 BRZ First-Gen (2012+) — General Topics 9 07-10-2012 09:33 AM
Dutch General Director of Toyota comments on price Navi Scion FR-S / Toyota 86 GT86 General Forum 34 12-28-2011 02:08 PM
