Old 04-15-2013, 03:15 PM   #15
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by rice_classic View Post
And I bet you don't have any empirical data to disprove either?
forget him, anyone that needs to have science explained to them isn't worth the effort.
Old 04-15-2013, 03:28 PM   #16
robispec
Drives: Black frs project
Originally Posted by Huehuecoyotl View Post
what road course, curious>?
buttonwillow 13 ccw really hard on tires...
robispec is offline   Reply With Quote
Old 04-15-2013, 04:49 PM   #17
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Im still sitting on the fence on this one. I keep getting faster and faster in my s2000 all the time...and Ive had the car for years and am still getting faster. Same for my miata and same for my FRS. Track temps vary a lot through out the season here. Of course old wide tires will be slower than new skinnier tires.
I think it's highly driver dependent too. If you corner at the exact same rate because you brake in the same place and get on the gas in the same place with the smaller tires as the larger tires, i can see the smaller tires being faster. But if you are able to utilize the grip, you can brake later, corner quicker, and have a higher exit speed which in my mind is faster at a lot of tracks as long as they aren't high HP/long straight courses.
Feel free to disagree, but I don't think ANY of us are consisent enough and have the same control variables all the time to make any sort of blanket statement at this point.
GTM_Challenge is offline   Reply With Quote
Old 04-15-2013, 04:59 PM   #18
renfield90
The Stig's German cousin
Thank God we don't drive Spec Miatas. I speak from the experience of having tracked a ~120whp car...
And you need a lesson in how science works. He made the original assertion, he should have the data to back it up. I believe in data. I don't believe in conjecture unless it can be tested and verified.
What is the coefficient of rolling resistance for the wider tire compared to the smaller tire? How many Newtons of resistive force does that translate to? How much does the wider tire slow you down on, say, a 300m straight? Even simple data logging things like apex speed, max lateral g, and top speed at the end of a straight will help sort out what's going on here. If you come to me with zero data, the scientist in me is required to question your conclusions.
The Following User Says Thank You to renfield90 For This Useful Post:
console_cowboy (05-04-2013)
Old 04-15-2013, 05:01 PM   #19
renfield90
By far the best point in this entire thread.
Old 04-15-2013, 05:13 PM   #20
CSG Mike
CSG Mike's Avatar
Consistency doesn't matter when the data from on-board dataloggers is so conclusive.
More importantly, the straightline speed differentials are SO huge that we don't need to verify with data.
E.g. with 225 RS3, I'll hit 112mph before "lost hill" at Buttonwillow. With 245 RS3, I barely hit 106mph. This is all through large sweeping turns where you're WOT. The limiting factor to the entry of this section is "busstop". With the 225, I'm hitting the exit apex at about 84mph. With the 245, I hit it at about 86.
Think of it this way. How many turns are you limited by tire grip? How many turns are you power limited.
Buttonwillow 13CW (the socal standard), turn, turn name, limiting factor, approx entry (before braking) and apex speeds (for the CSG BRZ) on 225 RS3 :
T1 Sunrise - grip - 107, 70
T2 Buttonhook/Offramp - grip - 89, 35
T3a Cotton Corners - grip (hot entry) - 92, 55
T3b - grip (sacrifice) - 50
T3c - Power - 55
T4 Grapevine - power - 70
T5 Club Corner - power - 90
T6 Left kink- power - 98
T7 Bus Stop - grip - 103, 81
T8 Right kink - power - 88
T9 Riverside - power - 97, 100
T10 Left Kink - power - 108
T11 Lost Hill/Phil Hill - grip - 112, 72
T12 Right kink - power - 85
T13 Drag strip - power - 92
T14 Sweeper - grip - 106, 58
T15 Esses - power - 98 (final left apex)
T16 Sunset - grip - 110, 65
Speeds for identical car (same coilovers, same damper setting, same brakes, but with bolt-on power adders) with 245 RS3, same driver (me):
T1 Sunrise - grip - 98, 73
T2 Buttonhook/Offramp - grip - 83, 39
T3a Cotton Corners - grip (hot entry) - 88, 57
T3b - grip (sacrifice) - 54
T3c - Power - 57
T5 Club Corner - power - 87
T6 Left kink- power - 93
T7 Bus Stop - grip - 108, 83
T8 Right kink - power - 89
T9 Riverside - power - 95, 95
T10 Left Kink - power - 99
T11 Lost Hill/Phil Hill - grip - 105, 74
T14 Sweeper - grip - 101, 60
T15 Esses - power - 93 (final left apex)
T16 Sunset - grip - 13, 66
johnnie (04-15-2013), robispec (04-15-2013)
Old 04-15-2013, 05:21 PM   #21
GTM_Challenge
Drives: On track
Mike, were those taken the same day, no headwind or tailwind, same track temps, same barometric pressure so the air density is the same, etc? I get the data, and see it, but unless testing was done under the EXACT same circumstances, I take all data with a grain of salt. There are many, many outlying factors than just lap times IMO.
Edit* - Even two equal cars, EVERYTHING being the same - one car will be faster than the other. Its physics. One car will always be faster. They aren't going to return the same exact lap times. One motor will be stronger, one will corner better, etc.
I'm not saying you're wrong, Im just urging people to keep their minds open, that's all. You know how I am.
Old 04-15-2013, 05:29 PM   #22
CSG Mike
CSG Mike's Avatar
Conditions no longer matter, when the comparison has already been done so many times at the same track, and the results are consistently the same.
I think between Robi and us, we typically have 5 sets of rims and tires at the track on weekends where we both show. A lot of confounding variables simply are meaningless (heat cycles don't affect straightline speeds, etc.)
Old 04-15-2013, 05:33 PM   #23
GTM_Challenge
Drives: On track
Sigh. I already know which side your on. Ive got to prove it to myself. I trust no one.
Old 04-15-2013, 05:37 PM   #24
robispec
My but dyno says that the 205's are FAST in a straight line but slightly slower in the corners...then I get off track and my spotter tels me I'm KILLEN them in the corners lol....
The Following User Says Thank You to robispec For This Useful Post:
CSG Mike (04-15-2013)
Old 04-15-2013, 05:38 PM   #25
CSG Mike
CSG Mike's Avatar
You're alone in testing your FR-S locally, for the most part. Between Robi and I, we've probably driven a few hundred different setups (thanks to people who ask us to drive their respective cars).
It's REALLY REALLY easy to test straightline speed...
Old 04-15-2013, 05:42 PM   #26
GTM_Challenge
Drives: On track
Easy fix...you need to move to Chicago.
Womp womp.
Old 04-15-2013, 05:42 PM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I agree. It's why I bought another set of wheels with the smaller tires to test. I had the same results as Mike and Robi. I tested on the same weekend, but not the same day..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-15-2013, 05:45 PM   #28
CSG Mike
CSG Mike's Avatar
He's got the resources to do it...
Top Gear (UK) track times GeeTee86 AFRICA 29 02-15-2013 07:04 AM
NorCal: Grip Drift Skid HPDE Track Day at Thunderhill PMok Southern California 31 12-26-2012 03:12 AM
Before/After Track Times (Sonoma Raceway) CorteXracing Tracking / Autocross / HPDE / Drifting 5 11-26-2012 10:28 PM
Official 86 GT Modded/Tuned track times. GT5 PAImportTuner FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 12-26-2011 01:30 AM
GT5 - fastest Suzuka (full track) times NESW20 Other Vehicles & General Automotive Discussions 11 04-03-2011 12:20 AM
