Old 04-15-2013, 11:18 AM   #1
Foobar
SLO NO MO
Foobar's Avatar
Exhaust vibration/rattle at cold start?
I've got the Perrin headerback and recently (now that I've been able to drive with windows open in the mild weather) I've noticed that the exhaust makes a bit of a vibration or rattle sound for a second at cold start. I'm going to put the car up and check that everything's still tightened to spec, but was wondering if anyone else noticed this and perhaps it was just normal?
Maybe part of the exhaust system is too close to another part of the car and during the cold start routine there's enough vibration in the system to make it hit for a second?
6MT, in case anyone was wondering - I know that there were some cases of the exhaust being tight with the auto, so that's not it.
Old 04-15-2013, 12:44 PM   #2
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
My perrin un-resonated exhaust does it too, but only when it's very cold and it only happens for like 1 nano second.
shu5892001 is offline   Reply With Quote
The Following User Says Thank You to shu5892001 For This Useful Post:
Foobar (04-15-2013)
Old 04-15-2013, 02:29 PM   #3
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
if you have the non resonated, i say just get used to it?
maybe the piping is cold because i get this as well
after it's warm, it completely goes away. and only lasts for maybe a few seconds.
what kind of sound are you experiencing? can you try to be a little more specific?
another theory could be the studs connecting the exhaust manifold to the overpipe and perhaps that's loose?
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
The Following User Says Thank You to Tylub For This Useful Post:
Foobar (04-15-2013)
Old 04-15-2013, 02:37 PM   #4
DarkSunrise
DarkSunrise's Avatar
Same here -- Perrin NR.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Foobar (04-15-2013)
Old 04-15-2013, 02:41 PM   #5
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
SRT header back, lasts until it is warmed up. the car is v8 short block loud with a cold start (just not v8 deep)
The Following User Says Thank You to SkAsphalt For This Useful Post:
Foobar (04-15-2013)
Old 04-15-2013, 03:02 PM   #6
Foobar
SLO NO MO
Foobar's Avatar
Thanks guys - yeah I've got the unresonated catted headerback. It's not a big deal to "get used to" as Tylub suggests, I just wanted to make sure it was normal. I never noticed it before but now that it's warmer out, I've had a few opportunities to start the car with my windows open and I noticed the sound, sort of a metallic rattling sound as if part of the exhaust was just touching part of the car.
I put the car up and confirmed that all of the bolts and bands were tightened to spec, all the way from the header to the last muffler hanger. I don't see evidence of exhaust leak anywhere in the system. I also ran my fingers all along the system checking to see if it was butting up against part of the car, but aside from the connection to the header, the frontpipe hanger, and the muffler hangers, it's completely clear. The closest it gets to the car is by the rear crossmember, I'd say it has about a centimeter of space between the top of the pipe to the bottom of the crossmember.
Looks like it's just something inside of the exhaust that wakes up for a second at start, but then goes away. Based on other responses here, looks like it's completely normal.
Thanks guys!
The Following User Says Thank You to Foobar For This Useful Post:
Tylub (04-15-2013)
Old 04-15-2013, 04:24 PM   #7
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
Thanks guys!
From what you are describing, that sounds normal. Our shop car does the same thing on a cold start.
If you feel like it could be something more, make a video of it and get it over to us and we can look into it! You have done the steps that I would recommend you do in order to check for an exhaust leak or a loose bolt.
As I stated before, it sounds completely normal to me, but I understand the need to double check !
If you have any more concerns, just let me know here or via PM!
PERRIN_Mladen is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Mladen For This Useful Post:
Foobar (04-15-2013)
Old 04-16-2013, 05:15 PM   #8
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I now have added vibrations throughout my car at certain points in my rev range... I blame my resonator for that. So I will be slowly finding them and adding stuff to remove the rattles/vibration sounds. I like the louder exhaust but also want a smooth sounding car.
So i guess I took a few steps forward and a few steps back but I love my car
Exhaust rattle on cold start? Laurie Scion FR-S / Toyota 86 GT86 General Forum 8 12-04-2020 07:15 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
FR-S cold start stumble - video whtchocla7e Issues | Warranty | Recalls / TSB 11 04-17-2013 07:02 AM
Cold Start Exhaust Volume SilentMike Engine, Exhaust, Transmission 15 04-04-2013 10:49 AM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 01:35 PM
