Visconti
Old 04-10-2013, 01:07 PM   #323
Visconti
Drives: 05 STi
I had an overboost episode, but I only hit 19 psi in third before the tires blew off the car, and I realized something was wrong. I still have no overboost protection.
Your the only turbo car I've tuned with no upgraded map sensor. When I tuned you in person I told you that you had to get a upgraded sensor ASAP.
I've done something in your mapping to help prevent explosion if the load get too high...
Since then you asked me about it but never got one?
Visconti is offline
Old 04-10-2013, 01:23 PM   #324
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
I want to let everyone know, @Visconti SAVED my engine yesterday. I floored the car for the first time last night, lo and behold I have an issue with my Wastegate and its NOT opening. The overboost protection he added to my map was the only thing between my car and 30+ psi BOOM.
THANKS John @Visconti. Literally saved my motor last night. Car boosted to 13 psi at about 5K RPMs (it happens so fast, my eyes only saw up to 9 in the gauge) and hit overboost protection and it would just NOT go any higher.
Any of the Turbo guys, you NEED Overboost protection, I could have been another sad story today.
sounds like another turbo install gone wrong averted..
Originally Posted by 2forme View Post
Absolutely. From what I understand, Johns tunes are the only ones to have this feature right now?
any ecutek tune can have this, I havent overtly checked with Perrin on what he has me running at the track, but overboost just isnt a concern in my setup with a SC
Huehuecoyotl is offline
Old 04-10-2013, 01:33 PM   #325
2forme
It can be if you ever decide to go wastegated
I was saying I think John is the only one who utilizes it, not that he's the only one who can.
2forme is offline
The Following 2 Users Say Thank You to 2forme For This Useful Post:
Huehuecoyotl (04-10-2013), Sportsguy83 (04-10-2013)
Old 04-10-2013, 01:33 PM   #326
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yeah, its either the MBC is installed backwards or the Actuator is shut down too tight.
Sportsguy83 is offline
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 04-10-2013, 02:14 PM   #327
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The overboost happened a long time ago on the Full Blown basemap when I was experimenting with my wastegate hose routing. I am ordering a MAP sensor tonight after talking with David last night, so when you send me my new ROM with more timing you can put boost cuts in. I should have my new 9.8 psi wastegate spring this week as well.
King Tut is offline
Visconti (04-10-2013)
Old 04-10-2013, 03:43 PM   #328
sw20kosh
Drives: 2013 Black FR-S
Connect a pump (even a bicycle pump with a gauge) and apply pressure to the wastegate nipple. Observe the wastegate actuator arm. Make sure it is opening at the correct psi. If that works then the problem might be the boost controller or the vac line going to the gate.
sw20kosh is offline
The Following User Says Thank You to sw20kosh For This Useful Post:
Old 04-10-2013, 03:55 PM   #329
Sportsguy83
Drives: Limited BRZ
Thanks for the tip, will definitely try it out.
Old 04-10-2013, 04:24 PM   #330
Calum
That Guy
Drives: 2013 asphalt FRS MT
Gauge accuracy COULD cause problems with this, but it is a VERY good idea.
Calum is offline
Old 04-10-2013, 05:21 PM   #331
sw20kosh
I have had nightmarish problems with internal wastegates. I once had an internally gated turbo where the flapper door was not able to open more than 30% because of machining tolerances being off......... Boost spiked up to 24 psi when we first boosted on the dyno. Luckily it was a 9:1 CR motor lol.
sw20kosh is offline
Calum (04-10-2013)
Old 04-14-2013, 05:32 PM   #332
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
@Visconti
Hi John! i am finally ready to order my tune. ive been driving my car around for a couple of days with the wastegate open to make sure that everything was good and working properly with no oil or coolant leaks. A friend of mine has an ecutek cable so i wont need one for now.
I tested my wastegate actuator on the bench and it starts to open at 7.5psi and is fully open at 8psi. i also have a 4 bar map sensor. I always run on 91octane but if i need to run 94 i can get access to it as well. I am using stock injectors for now... i believe that 8 psi was the limit for these but correct me if i am wrong. i also have no catalytic converter between my 2 o2 sensors so i dont know if you can do something about it... i currently have a cel because of that. i would also like to have launchcontrol if possible!
please hit me up soon with all the info that you need and where to send you the funds! i would like to chip the car this comming saturday!!
sincerely,
Max
Silverdub is offline
Old 04-14-2013, 05:54 PM   #333
Sportsguy83
Drives: Limited BRZ
sincerely,
Max
Sounds awesome! I think the best way to get in contact with him is either PM here, or submit a support ticket. Hopefully you hear from him soon!
Silverdub (04-14-2013)
Old 04-14-2013, 06:00 PM   #334
Frs300
Frs300's Avatar
Drives: Pile of junk
he will more than likely have you do a support ticket or call him
Frs300 is offline
The Following User Says Thank You to Frs300 For This Useful Post:
Old 04-14-2013, 06:05 PM   #335
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Support ticket?
Old 04-14-2013, 06:07 PM   #336
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Yeah in his sig got it
The Following User Says Thank You to Silverdub For This Useful Post:
Sportsguy83 (04-14-2013)
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Visconti Tuning - Who wants to run on e85? or 100 Octane Visconti Engine, Exhaust, Transmission 174 05-21-2013 04:00 PM
VISCONTI TUNING WILL BE IN PHX JAN 18-20 WHO'S READY Visconti Southwest 9 01-06-2013 02:40 AM
Visconti Tuning Stage 1 Tester #3 (I think) ruskymx Engine, Exhaust, Transmission 46 09-15-2012 05:29 AM
Visconti Tuning NA STG1 Group Buy Visconti Groupbuys 683 08-24-2012 12:28 PM
