Old 04-12-2013, 11:40 AM   #1
Supermassive
Supermassive's Avatar
Cusco Vertical Mount Air/Oil Seperator
So I have installed the new Cusco vertical oil catch can and I can already attest to this being worth it's weight in gold. My fuel mileage has gone from my average indicated of 25.4 (+/-.1) to 27.0 (+/-.1) miles per gallon for my average daily drive which includes a bunch of stop and go city driving with a 7 mile stretch of highway mixed in, which is my daily commute. On top of this I have drastically reduced the soot build up on my exhaust tips. Before the catch can I could clean the tips and at the end of a day of driving they would be black instead of chrome. Now I have run the car 7 days since cleaning them and only have a couple soot spots that I think might be from further in the exhaust.
There are a couple little things I had to do to make this setup work in my car and I basically had to look at how others have theirs set up since the instructions provided with this car were in Japanese and had crappy diagrams...not to mention they routed the hoses to the wrong parts of the engine to have any real effect. I hooked mine up to the engine case PCV valve and the intake manifold port that the breather was originally attached to.
Also I reverse mounted the can so that the hose nipples are pointing toward the firewall instead of the engine...this was only because the hoses were rubbing on the edge of my CF engine cover and I didn't want to risk cutting the lines due to abrasion.
I am super stoked about this can, at first I was not too excited about this kit, but I have definitely had a change of heart and can honestly say I love it. Little issues aside this product actually works is it collecting oil probably, cant tell yet since none is showing in the little sight gauge but the effects were immediate and definitely help with the turbo.
I will be buying better hoses due to the fact that these clear plastic hoses will likely yellow and already have a slight brown tinge due to the oil vapor coating the insides of them. I am also considering putting an actual drain petcock on the side of this can at the very bottom to facilitate draining it. I haven't had to yet but i can see how it will be a pain in the ass later when I do have to.
Pictures:
Supermassive is offline   Reply With Quote
The Following 4 Users Say Thank You to Supermassive For This Useful Post:
Hanakuso (04-15-2013), JPxM0Dz (04-12-2013), serial gixxer (04-12-2013), whataboutbob (04-12-2013)
Old 04-12-2013, 12:25 PM   #2
Hanakuso
How much stuff has it catched yet and where did you buy it?
Hanakuso is offline   Reply With Quote
Old 04-12-2013, 01:04 PM   #3
Supermassive
Dunno how much, still haven't drained it, I also haven't really beaten on the car since i put it on. I bought it through Vivid Racing, Sean is basically my crack dealer there...
The Following User Says Thank You to Supermassive For This Useful Post:
vividracing (06-17-2013)
Old 04-12-2013, 03:40 PM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
Awesom, thanks for the write up.
What was you previous setup?
Old 04-13-2013, 07:27 AM   #5
Supermassive
My previous setup was nothing, this is the first catch can I have installed. I may one day switch to Radium but at the moment this is more than suitable!
Calum (04-13-2013)
Old 04-13-2013, 09:01 AM   #6
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
would like to see what you catch!
Huehuecoyotl is offline   Reply With Quote
Old 04-13-2013, 11:02 AM   #7
Calum
That Guy
Just for clarity, did you have the factory PCV left stock? Or was it removed and you were literally had nothing?
Sent from mission control
Old 04-13-2013, 01:09 PM   #8
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Part # 965 010 A for anyone who is interested in picking this up
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 04-13-2013, 01:11 PM   #9
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Retail is $240 on it, let me know if interested there very few in stock.
Old 04-13-2013, 08:10 PM   #10
Supermassive
@Calum
I had the stock PCV setup as it comes from factory.
Old 04-14-2013, 05:07 PM   #11
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
http://www.cusco.co.jp/en/pdf/New%20...12313%20A4.pdf
2URGSE
Old 04-15-2013, 02:15 PM   #12
CrazyWookiee
Looks like a good unit. Makes me wish I didn't pick up the first non-separator type.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 04-15-2013, 02:16 PM   #13
Hanakuso
Since the bottom fitting is like 2 inches from the bottom, doesn't that effect the capacity of oil/junk it can hold?
Old 04-15-2013, 02:47 PM   #14
Supermassive
Yes, so that's why you drain it when you can see oil in the little sight tube, which I just figured out makes a perfect drain since its a clear plastic tube with one-touch fittings, just undo the top one-touch and flip it over into something you want to catch it in and presto!
The Following 3 Users Say Thank You to Supermassive For This Useful Post:
Hanakuso (04-17-2013), JPxM0Dz (04-17-2013), texasbound972 (01-11-2014)
Cusco Street Spec A Coilover Kit Scion FR-S Subaru BR-Z No Upper Mount FRS-HHH Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 03-31-2016 07:17 AM
**PHASTEK** Scion FRS / Subaru BRZ Oil Catch Can (oil air seperator) PhastekSport Engine, Exhaust, Bolt-Ons 16 11-30-2013 11:45 AM
Selling a Vertical door kit FRS-89 Exterior Parts (Aero, Lighting, Etc.) 0 02-20-2013 02:57 PM
Group Buy - Cusco transmission mount + Beat Rush master brake cylinder stopper Nardi330 Australia Classifieds 74 10-28-2012 01:08 AM
New cusco transmission mount! Silverdub Engine, Exhaust, Transmission 5 07-11-2012 08:50 AM
