Old 04-11-2013, 12:08 AM   #15
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
wtf is 90 octane? i've never seen that
lbroskee is offline   Reply With Quote
Old 04-11-2013, 08:12 AM   #16
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
I never let any of my cars get too low, about 1/8 to 1/4 tank is the lowest. With the fuel pumps in the gas tanks of most modern cars, damage can occur and shorten the fuel pump's life.
When the fuel level is low, the pump has to work harder to produce the same pressure because the reduced fuel weight no longer pushes fuel into the pump. Instead the pump must draw the fuel in. There is also less fuel to cool the pump and the overworked pump can overheat.
Most pumps today are pretty rugged and have safety backups but it's not worth taking any chances for me, especially if I'm driving hard.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
The Following User Says Thank You to Clembo For This Useful Post:
mixtape (04-13-2016)
Old 04-11-2013, 08:17 AM   #17
CaptainSlow
CaptainSlow's Avatar
Usually an at-pump mix of regular and premium
I believe manufacturers bias the fuel gauge to make sure people don't run out of gas (make them think they have less fuel than they do)
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
The Following User Says Thank You to CaptainSlow For This Useful Post:
lbroskee (04-11-2013)
Old 04-11-2013, 09:04 AM   #18
marcosowns
marcosowns's Avatar
Drives: 2014 Lexus IS350
The gas light is very fool proof. You should very easily go at least another 30 miles after the light comes on if it is necessary. I've had other cars (Honda/BMW) which I have driven a few miles indicating 0 miles left in my tank. Now whether you should be doing that is a whole different discussion.
marcosowns is offline   Reply With Quote
Old 04-11-2013, 09:15 AM   #19
Mikem53
Drives: FR-S 6MT
In tank fuel pumps are cooled and lubricated by the fuel... Best not to run them too low as they can overheat and fail...
Mikem53 is offline   Reply With Quote
Old 04-11-2013, 09:16 AM   #20
Freetime
Freetime's Avatar
Drives: Raven Manual FRS
I'm pretty sure I read in a warning in the FRS manual that said to NOT run the car low on fuel as it can damage the engine. I usually fill back up around the 1/4-1/8 mark.
Freetime is offline   Reply With Quote
Old 04-11-2013, 09:40 AM   #21
lbroskee
lbroskee's Avatar
so if i have a station that sells it ethanol free near me, would it b better or worse then regular 93?
Old 04-11-2013, 12:01 PM   #22
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Tucson FR-S View Post
On a related note, I see that the car's computer overestimates average mpg per tank by about 5%. Sound about right?
I've never had it under 6% accuracy, closer to ~8% with a couple off by 10%
I have yet to see an mpg computer that underestimated mileage. Trying to trick you into thinking you're outdoing the EPA figures pisses me off.
ineedyourdiddly
civicdrivr (04-11-2013)
Old 04-11-2013, 01:49 PM   #23
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
The lifetime mpg average on the dash shows 28.4mpg on my car. The actual lifetime mpg average is 25.6mpg. Huge difference.
And that damn instant fuel economy reading is a joke.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following 2 Users Say Thank You to civicdrivr For This Useful Post:
lbroskee (04-11-2013), strat61caster (04-11-2013)
Old 04-11-2013, 03:34 PM   #24
strat61caster
The only thing it's good for is telling you when you're in "compressor" mode not burning any fuel (or very minimal fuel as the case may be). Otherwise it's basically a throttle position readout.
ineedyourdiddly
Old 04-11-2013, 04:57 PM   #25
immortal_suby
Drives: 2015 BRZ Limited 6MT
I have tracked every fillup since new and the computer is consistently 2 to 2.5 mpg over vs. the actual mpg. My calculated average over 7k miles is 29.7 with a high of 32.5
2015 BRZ , 1992 SVX LSL, 2019 ASCENT
immortal_suby is offline   Reply With Quote
Old 04-11-2013, 05:14 PM   #26
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I made 340 miles 98% highway trip going on average 85 mph, filled up to 10.3 gallons. Couldve gone an extra 50-75 miles if I wanted to. Touche.
Zero cruise control
LeeMaster is offline   Reply With Quote
Old 04-11-2013, 05:32 PM   #27
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
The most I've gone on a tank was 392.5 miles, that was 12.46 gallons. I have a heavy foot most of the time.
Parting out HERE
Old 04-11-2013, 07:00 PM   #28
jmaryt
Drives: 2012 honda civic ex
slush,or stick?
jmaryt is offline   Reply With Quote
Anyone running this size? cruzinbill Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-26-2013 09:15 PM
Running a Group Buy Hanakuso Site Announcements / Questions / Issues 1 02-19-2013 04:27 PM
CEL after running out of fuel Kido1986 Issues | Warranty | Recalls / TSB 10 02-11-2013 12:34 PM
For those running 18x9.5 all around empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 11-17-2012 11:10 AM
HID for Daylight Running Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 3 09-21-2012 06:47 PM
