Old 04-10-2013, 05:32 PM   #1
TimR
TimR's Avatar
Drives: Limited Lightning Red
Michelin Pilot Super Sports
Swapped out stock Primacy's for some Pilot Super Sports and so far I am loving these tires. Really wanted to do dedicated wheels and tires for auto cross but wasn't in the budget this year. Testing the new skins on Sunday hopefully through the cones, but so far these tires have really raised the handling to a whole new level. Of course the downside is now I notice the lack of power a bit more but plenty of time to fix that. Figured I give the new rubber a shout out.
TimR is offline   Reply With Quote
Old 04-10-2013, 05:40 PM   #2
CSG David
CSG David's Avatar
Our car lost around 7MPG switching from the OEM tires to the Z1 Star Specs or EHP equivalent.
The Following User Says Thank You to CSG David For This Useful Post:
Anthonytpt (05-10-2013)
Old 04-10-2013, 05:42 PM   #3
powerj2
powerj2's Avatar
Drives: 2013 Scion FRS
PSS Is an amazing Street Tire! best of all they have nice treadwear
powerj2 is offline   Reply With Quote
Old 04-10-2013, 05:44 PM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Love the PSS both on the track and on the streets!
Cant go wrong wit these tires
86_ZN6 is offline   Reply With Quote
Old 04-10-2013, 05:55 PM   #5
TimR
TimR's Avatar
Wow, 7 mpg! I will have to watch that and see what I loose. I still averaged 28 with snows and I can't imagine the Super Sports being worse than those for rolling resistance
Old 04-10-2013, 05:57 PM   #6
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
FWIW I didn't see any mileage drop at all when I went from the Primacy to ExtremeContact DWs.
MVJ1975 is offline   Reply With Quote
Old 04-10-2013, 06:13 PM   #7
jeebus
I lost only .5mpg switching to the DW. After lowering the car and adding a K&N, I have gotten than .5mpg back.
I can't imagine the PSS would be any different than the DW...maybe by .1-.2MPG at most.
jeebus is offline   Reply With Quote
Old 04-10-2013, 06:16 PM   #8
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
I figured as much. Did you go wider or taller at all? My DW are stock 215/45R17.
Old 04-10-2013, 06:18 PM   #9
OrbitalEllipses
Drives: Attitude
I just came from Dunlop WS3D 205/50/17 winter tires and 150lbs of ballast to my 225/45/17 MPSS, so my mileage report will probably be wonky; also switched to a 5-6lb lighter wheel at the same time and I can't find weights for my winter tire. That said, I'm still getting ~30-35mpg on highway stints with steady throttle input at 65-70mph. My non-highway figures don't matter as I sit in traffic for my commute.
Old 04-10-2013, 06:58 PM   #10
jeebus
Stock size.
Old 04-10-2013, 07:16 PM   #11
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
what size are you running?
FreshFRS is offline   Reply With Quote
Old 04-10-2013, 07:29 PM   #12
CSG David
CSG David's Avatar
At the time, 215/45/17 Z1 Star Specs. No changes after running 225/45/17 RS3 compared to the 215/45/17 Z1SS. OEM tires = 33MPG, EHP tires = 26MPG. Definitely head scratcher...
The Following 2 Users Say Thank You to CSG David For This Useful Post:
Anthonytpt (05-10-2013), FreshFRS (04-10-2013)
Old 04-10-2013, 07:35 PM   #13
OrbitalEllipses
Drives: Attitude
OEM tires are lightweight and LRR rated versus your stiff as (insert imagination here) ZII...but I'm betting you've been getting into the gas more too.
Old 04-10-2013, 07:39 PM   #14
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
Could it be the diff and tranny motul gear 300 and 5-30 weight engine oil? I noticed less mpg with 5-30 then even more after i got my diff and tranny fluids flushed with gear 300 75-90 from motul. Could be just in my head though and i am just driving harder now.
RAWR BRZ is offline   Reply With Quote
Wheel Directory: OZ Ultraleggera 17x8.0 +48 Mageep Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 104 04-11-2021 12:03 AM
Wheel Directory: OZ Alleggerita HLT 18x8.0 +48 O.Z. BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 04-16-2015 06:49 AM
Michelin Pilot Super Sports Warrenty? FLASCH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-11-2013 10:39 PM
Pilot Super Sports Got3n Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-10-2012 12:23 AM
Michelin Pilot Super Sport 17 inch DieselBoXXer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-05-2012 10:17 PM
