TRD Intake ! CAI ?!
Personally, I have tried out the INJEN and AFE intake on the BRZ / FRS. Both does have pretty good high rpm power gains which you can feel it but when it comes to ON/OFF throttle response, I think stock air box performs much better. With the stock intake or with a panel filter, the acceleration improves at lower rpm especially 1-4k range but you won't have the pull like the after market intakes.
The first time I saw the TRD intake on the Scion celebrity race car, that design really get my attention. Bigger air box increasing intake volume, this intake will improve throttle response and power. I don't think it will make as much power as a aftermarket box up cone filter, however, throttle response SHOULD be unbeatable. Since no one has dyno the TRD intake, it's too early to judge if it's good or bad. So I will be dynoing this unit and plus a DRIFT OFFICE tune along with it. Here's are some pics for the intake : ![]() ![]() ![]() ![]() I will keep you update how the install and dyno goes. Thanks Ben |
#2 |
Drives: 2013 Asphalt FRS
Take a picture of the inside of the box~~~
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
#3 |
Ontario's FT86
Drives: 2016 Lexus GS-F
Thanks a lot of doing all of this, exactly what we need to see. Dyno for stock and tuned!
#4 |
In that second picture, it almost looks like you can take off the red TRD letters. I'd like to do that if it's possible.
#5 | |
Drives: Attitude
#6 | |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
![]() 20130403-86TRDIntake-033 by VictorN07, on Flickr The rest of my pictures are on my flickr
#7 |
In for the depressing results. Glad someone is finally doing it so I can either STFU or continue my bashing.
#8 |
#9 |
wheel gap
Drives: whiteout frs, 04 xrs
in for results, i like the look
#10 |
Ontario's FT86
I wonder if it's possible to make the opening larger and pair it up with a bigger air duct
#11 |
Thanks. I saw your post and noticed you were surprised by it being made in the US. TRD USA and TRD Japan are totally different. Iirc, TRD USA is actually under Toyota North America and has nothing to do with Toyota Japan. Many of the exhaust are rebranded or made by US companies.
#12 |
Drives: White Out FR-S
#13 | |
IMO it would look completely stock with it off.
http://jprova.co.jp/products/intake/...000001o5j.html
#14 |
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
what is the length and width of the filter to calculate area and compare to the OEM one.
| cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 12:43 AM |
| So cold air intake or air intake? | bcmakesiteasy | Engine, Exhaust, Transmission | 12 | 02-01-2014 08:06 PM |
| HKS intake setup VS Injen intake,,,what are your thoughts? | JDMrolla | Engine, Exhaust, Transmission | 4 | 10-11-2012 01:31 PM |
