Old 04-10-2013, 01:29 PM   #1
lemonspeakers
Drives: blue
FRS colors = Prius colors?
With where I live, I’ve seen more Toyota Prius that I need in my lifetime. Because of that, I’ve seen all the factory colors of a Prius. But, I’ve yet to see all the colors of an FRS.
My question is, are the colors on the FRS the same colors they use on the Prius? They look incredibly similar. If this is true, then I've seen all the colors of the FRS.
i.e. The Pearl white Toyota uses on the FRS is practically the same as the pearl white on the FRS/BRZ
On a side note, there are many BRZ owners in my area. But I’ve seen them ONLY in WRB. Actually, I saw one in pearl white one time. Once.
lemonspeakers is offline   Reply With Quote
Old 04-10-2013, 01:30 PM   #2
zaptorque
zaptorque's Avatar
Drives: 2013 Asphalt FR-S
No, all FR-S colors except Hot Lava are Subaru paint codes.
zaptorque is offline   Reply With Quote
Old 04-10-2013, 02:28 PM   #3
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
ALL '86s are manufactured at a Subaru plant in Japan.
So, no. They aren't Prius colors any more than they are Camaro, Accord, Mustang, Aston Martin, ect colors.
Scott
naikaidriver is offline   Reply With Quote
Old 04-10-2013, 03:14 PM   #4
lemonspeakers
Drives: blue
I swear though, the pearl white and galaxy blue on Prius cars are quite literally the same on FRS.
Wait, I guess then the question is: Do Prius(es) paint colors come from Subaru?
Old 04-10-2013, 03:19 PM   #5
gily25
Drives: Silica BRZ 6MT
Fashionable colors are fashionable colors. I'm sure the paint code differs but overal the colors are repeated across industries. I saw a blue maxima the other day I swear was WR Blue.
gily25 is offline   Reply With Quote
Old 04-10-2013, 03:20 PM   #6
naikaidriver
No, they come from Dupont!
Scott
Old 04-10-2013, 03:20 PM   #7
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
FR-S in champagne... hmmmmmm..
Old 04-10-2013, 03:21 PM   #8
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
If they do not have the same paint code, then they are not the same color.
The Red FRS is a hair darker than the Lightning Red BRZ(I parked next to one so I know). Even though they are both built in Gunma, they are not the same color..
And why do you care if the FRS uses the same paint as a Prius? If you dont want to look like a Prius go buy a WRB BRZ.
LeeMaster is offline   Reply With Quote
Old 04-10-2013, 03:44 PM   #9
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
The nautical blue on the Prius is darker than GBS/Ultramarine. E8H is actually closer in shade to Toyota 8T5 (Blue Ribbon Metallic) than 8S6 (Nautical Blue).
MVJ1975 is offline   Reply With Quote
Old 04-10-2013, 03:49 PM   #10
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
um, op you should be banned for even mentioning this.
jkjk!
Old 04-10-2013, 03:51 PM   #11
Veloist
Veloist's Avatar
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
I have both the Whiteout FR-S and Blizzard Pearl Prius. The FR-S (Subaru's Satin White Pearl) is more of a creamy white, and Blizzard Pearl is more brighter but has more Pearl Texture in sunlight. In cases of extreme sunlight, both cars look white with pearl flaking. The time I can really tell the difference is during the sunset when sunlight is not too extreme.
Look closely and you may be able to see how darker the FR-S is
Veloist is offline   Reply With Quote
Old 04-10-2013, 05:02 PM   #12
lemonspeakers
Drives: blue
White Balance if gnarly and off. But it serves the purpose to answer my question.
I actually prefer the Prius pearl. I think it's gorgeous. All this time, i thought they were the same. But who here owns a white prius and a white frs to juxtapose and compare/contrast?
@Veloist, Thanks! That really helps!
Old 04-10-2013, 06:16 PM   #13
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
the FRS and BRZ do share the same paint codes, so they are the same (except hot lava and wrb). It must have been a batch color difference that you saw or something.
Edit: see the paint code chart here
http://www.ft86club.com/forums/showthread.php?t=6519
Old 04-10-2013, 06:20 PM   #14
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
Unless you look real close my philosophy is black is black and red is red. Changing the tint slightly won't affect my opinion on most cars n colors
mrlewistan is offline   Reply With Quote
OEM Wheel Colors brzadmir Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-28-2013 07:51 AM
Rare colors? be6sti Scion FR-S / Toyota 86 GT86 General Forum 45 11-10-2012 05:07 PM
It getting more colors, wich one would you have? RaceR Cosmetic Modification (Interior/Exterior/Lighting) 14 06-04-2012 02:51 AM
Colors stalon320 Cosmetic Modification (Interior/Exterior/Lighting) 1 06-03-2012 01:28 PM
Help Choose FR-S Colors Shin Scion FR-S / Toyota 86 GT86 General Forum 14 11-16-2011 01:29 AM
