Old 01-09-2013, 09:01 PM   #15
Chillz
Drives: Asphalt FR-S & S14
I hear this when I don't lift off the gas completely before pressing the clutch. I never suspected the pulley.
Chillz is offline   Reply With Quote
Old 01-10-2013, 10:27 AM   #16
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
So far we think it is:
1.) Pulley
2.) Tranny (maybe differential)
3.) Sound tube (maybe because it's cold outside)
There was someone who got a new differential because they heard the same sound and after numerous test drives with a Subaru rep he was given a new diff.
http://www.ft86club.com/forums/showt...=honking+noise
ap5512 is offline   Reply With Quote
Old 03-25-2013, 12:17 AM   #17
garf
Great Member
garf's Avatar
Drives: raven, baught 8-29-12, manual
any new news on this? its gotta be something with transmission/diff. went to the tail of the dragon this weekend for a meet and it's gotten to the point now where i can replicate it on command. Any other suggestions before I head out to toyota?
garf is offline   Reply With Quote
Old 03-25-2013, 07:39 AM   #18
SloS13
Drives: 2013 FR-S whiteout
My car makes a noise between shifts too. Would be interested if you found the culprit.
SloS13 is offline   Reply With Quote
Old 03-25-2013, 09:13 AM   #19
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
First the crickets, now ducks quacking....
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Boosted (03-25-2013), Calin (03-30-2013)
Old 03-25-2013, 09:55 AM   #20
bakerr6
Drives: 2013 raven black fr-s
Yea I took my car in to have the fuel pump replaced and now mine does the same thing. I'm leaning more towards clutch/trans issue thatn any of the other. I have had issues with having the lsd engage when I shift into reverse and making a large clunking noise, but it seems to not occur anymore.
bakerr6 is offline   Reply With Quote
Old 03-25-2013, 10:23 AM   #21
andrew20195
Drives: 2013 Subaru BRZ
I noticed the same noise on my BRZ yesterday. When depressing the clutch, there is a "honk" and I can feel a vibration in the clutch pedal. I suspect it's coming from the clutch master cylinder. I'll try and see if I can pinpoint the noise if I get slow this week.
andrew20195 is offline   Reply With Quote
Old 04-10-2013, 12:57 PM   #22
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
I have the exact same thing happening.
I have the Perrin Pulley and full Perrin Intake (CAI + Inlet Tube).
So, i think we can rule out that is has anything to do with the stock intake.
If i had to venture a guess, I think it's in the clutch assembly, since it ONLY happens during shifting, and not at any other time.
I assume that it's got something to do with the engage/disengage and maybe the clutch just needs to be broken in a little. It doesn't seem to effect anything mechanically, and also doesn't seem to have any effect on the holding of the clutch.
My .02
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 04-10-2013, 12:57 PM   #23
Gopherboy6956
Also, please sticky this - as it was hard to find.
Old 04-10-2013, 01:08 PM   #24
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
I got this for a whole week once, when sitting at a stop light & slowly pressing in the clutch to shift into first; if I press the pedal in faster it doesn't make the noise/ pedal vibration. I personally believe the under pedal parts/ clutch return spring just needs to be lubed up or WD40'd; although I only experienced this for about a week when the weather was humid here in Las Vegas; it has completely disappeared now even when I just press the pedal in slowly.
Cliff - check under dash for squeaking while slowly depressing clutch pedal; if found, lube/ grease/ WD40 or wait for humidity in your local climate to disappear
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
Old 04-10-2013, 01:11 PM   #25
Gopherboy6956
As far as climate goes - Here in Fargo, ND i've owned the car for about 3 weeks. I have close to 500mi on it. The temps have alternated between 20F and 40F and not really moved out of those temps.
It's also been both very dry and humid over the last few weeks, with neither one seeming to make a difference.
Old 04-10-2013, 01:41 PM   #26
Foobar
SLO NO MO
Foobar's Avatar
I have a Perrin lightweight pulley and no honking between shifts, so I don't think that's the culprit.
Old 04-10-2013, 02:35 PM   #27
Ethereal
Drives: 2012 VW GTI
try tightening the locknut underneath the clutch pedal. this is a common problem on the toyota x-runners. the locknut would come lose causing the pedal to squeak/honk all the time.
Ethereal is offline   Reply With Quote
Old 04-10-2013, 02:52 PM   #28
Gopherboy6956
I really don't think it's coming from the interior. I'm like 95% sure it's something to do with the clutch.
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Perrin Pulley ArKiTeCkT Issues | Warranty | Recalls / TSB 12 11-06-2012 11:57 AM
Just changed oil...crickets got but new pulley noise sa1126 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 09-30-2012 05:45 PM
