Old 04-06-2013, 03:31 PM   #1
bobpuffer
bobpuffer's Avatar
Drives: FR-S Hotlava 6-speed
DIY - FR-S Valenti Tail Lights Install
Got a chance to install the Valenti tails. Learned quite a bit:
1. Open trunk
2. remove spare tire cover, set to the side
3. remove three push pins (don't know what these are actually called) on plastic covering the area where the trunk lid engages with the body by prying the center up with a small screwdriver. Once the center pops you can pull them out and place them off to the side. Set plastic piece to the side
4. Remove the foam that contains the tools on each side. The only way I could figure how to do this was to just gradually pull up on the foam close to the retaining pin (not a push pin) in the center. The pin flew like a bullet so I'd recommend putting a small towel over it when you pull so you don't lose them (like I did).
5. remove the front push pins off of one side retaining the the wheel well cover. I removed all of them on the passenger side and removed the wheel well cover only to find out on the driver's side I only needed to take out the rear-most four.
6. disengage the lighting connection by pressing on the retainer clip and pulling gently on the plastic connecter.
7. Using an 8mm wrench remove the four nuts holding the taillight onto the body of the car. On the passenger side you'll have to remove the wiring harness retainers from one of the nuts. This was the hardest thing I had to do. A small wrench that wraps around the nut used a leverage seemed to work best to get these retainer clips off the screws. The driver's side has two of these retainers. OF SPECIAL NOTE: the screws attached to the Valenti taillight unit are longer so these retainers do not clip back onto the new headlights. They fit, just don't catch onto the threads of the screws. A person could saw off a 1/4 inch of the screw before installing and get around this problem.
8. Pull off the old headlight.
9. Install the new in backwards fashion of the steps above.
10. Repeat for other side.
Took me about an hour to do both -- pretty easy even for a mechanically challenged owner like me.
I'll post some more pics when its dark and you can see the tails better.
bobpuffer is offline   Reply With Quote
Old 04-06-2013, 04:00 PM   #2
jlu
jlu's Avatar
Drives: Asphalt AT FR-S
Thanks! Can't wait to see them lit up.
jlu is offline   Reply With Quote
Old 04-06-2013, 07:35 PM   #3
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
Nice cant wait for more pics. Perhaps a video of how it works exactly. Each feature.
xDBOYx is offline   Reply With Quote
Old 04-07-2013, 10:04 AM   #4
GregV
Drives: Kia Stinger GT2
Wire retainers will pull off easily with pliers.
You can also get to the tail lamps easily by just removing the plugs in the trunk liner and folding it back, you don't have to pull out the trunk latch piece or the foam.
GregV is offline   Reply With Quote
Old 04-07-2013, 01:58 PM   #5
bobpuffer
bobpuffer's Avatar
Hmmm... I was not able to get the trunk liner pulled back without removing the trunk latch piece and couldn't remove the trunk latch piece without removing the foam. Perhaps someone else will have better luck.
Old 04-07-2013, 02:10 PM   #6
bobpuffer
bobpuffer's Avatar
Here's a pic in the dark. The tails are actually quite bright but this pic causes them to look like they fade out -- individual LEDs are very discernable. Probably not strictly legal as they are not red driving down the road, only when braking and turning. Am not very concerned about that but if there's some rewiring to do I'd probably do it so I had red on going down the road, and yellow for blinkers.
Old 04-07-2013, 02:14 PM   #7
suaveflooder
Those look great!! Nice write up!
suaveflooder is offline   Reply With Quote
Old 04-07-2013, 02:37 PM   #8
GregV
Definitely not wired properly from Valenti, and as you said - illegal.
Old 04-09-2013, 11:41 AM   #9
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Yea... the tube should be your tail lights. The orange 'half arrow' should be your blinker and the red LEDs should be your brake lights.
Definitely wired wrong from the manufacturer. This happened with another user and another tail light from Japan.
Chewie4299 is offline   Reply With Quote
Old 04-09-2013, 11:47 AM   #10
maceSWISS
Drives: 2012 Toyota GT86
Yeah your right. I think there's a difference between JDM and USDM wireing of the tail lights? I will check, if my taillights light up correctly without changing pins, when i change it to the valenti because here in switzerland we've got the JDM version of the car.
greetings
-maceSWISS
maceSWISS is offline   Reply With Quote
Old 04-09-2013, 05:00 PM   #11
Razzle
Razzle's Avatar
Drives: Toyota 86 (High) - White
Is this the yellow LEDs that are illuminated?
Are they on as your tail lights?
Razzle is offline   Reply With Quote
Old 05-14-2013, 12:16 PM   #12
jeffsides
AZ FRS 86
jeffsides's Avatar
So.... I got the Colin lights in the mail today. All the lights are reverse. My tail lights are blinkers and vise versa. Help?
@AZFRS86
Old 05-14-2013, 05:14 PM   #13
jeffsides
AZ FRS 86
jeffsides's Avatar
Size:  145.4 KBgot it figured out. Thanks to everyone Who PM me with help!
@AZFRS86
Old 07-17-2013, 12:51 AM   #14
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
Just replaced these lights into my 10 series. It is very easy as per your instruction here......
#944_10_Series_FRS is offline   Reply With Quote
Valenti Japan Full LED Tail Lights pornflakes AUSTRALIA 4 11-07-2015 08:56 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
Gauging Interest Valenti Japan Full LED Tail Lights pansontw Cosmetic Modification (Interior/Exterior/Lighting) 95 03-10-2013 04:29 AM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
