Old 04-09-2013, 09:22 AM   #29
Retro86
Retro86's Avatar
Drives: Awesome
yup the stalk is plug and play. its easy pare.
the stalk does have the auto feature but with all the progress that we are having so far, its just a matter of time til we figure out how to add the auto headlight module just like the GT86. and when that time comes your car is already prepped
Retro86 is offline   Reply With Quote
The Following User Says Thank You to Retro86 For This Useful Post:
imravenit (04-09-2013)
Old 04-09-2013, 09:28 AM   #30
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
salamat pare! i got the bezel, lights, jus need the stalk and some wires..
imravenit is offline   Reply With Quote
Old 04-09-2013, 09:39 AM   #31
Retro86
Retro86's Avatar
Drives: Awesome
Originally Posted by OmarGC View Post
Completely lost here...
he's talking about the turn signal connector. the fog(red/white, power, 12v) wires ends there.
Old 04-09-2013, 10:26 AM   #32
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
im sure theres a ground wire off that connector too..
Old 04-09-2013, 02:06 PM   #33
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
I got that much but which side is red/white and which side is white/red... It only refers to the driver side. Re-read it and you'll see what I mean...
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-09-2013, 02:55 PM   #34
KAR
Drives: Whiteout 6spd
Is it possible to be able to turn it on with the parking lights like how the BMW fogs works
KAR is offline   Reply With Quote
Old 04-09-2013, 04:22 PM   #35
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Originally Posted by imravenit View Post
so you went with the tundra stalk correct?
Yes, I didn't want the Auto location in the BRZ staldk
so with this approach theres no meed to tap into the bcm c3 anymore correct?
No need to touch C3.
I'd say there is. The ground for the turn signals.
2 wires to light a 12v bulb. 12v+ and ground. The drivers side turn signal connector has red/white wire with 12v+. The passenger side turn signal connector has white/red wire with 12v+.
Not with this method. To do this you need a stand alone switch.
FRSFirestorm is offline   Reply With Quote
The Following User Says Thank You to FRSFirestorm For This Useful Post:
OmarGC (04-09-2013)
Old 04-09-2013, 05:48 PM   #36
Tama-Y
Tama-Y's Avatar
Drives: ZN6, DC2
Slightly off, but still on topic. Is anyone aware what the EU GT86 Stalk part number would be? I am interested in setting the fogs on the stalk, but would like to have the option of a rear fog light as well. I personally feel that the rear 4th brake light concept is not the "correct" way to utilize the option. I would like to keep it as intended, a rear fog light.
See the Youtube link for what I'm specifically referring to. [ame="http://www.youtube.com/watch?v=WVzSXSYefjA"]Toyota GT86 euro - Light indicator stalk - YouTube[/ame]
@FRSFirestorm, any thoughts on this? Or better yet, maybe an Extended DIY?
Tama-Y is offline   Reply With Quote
Old 04-09-2013, 06:12 PM   #37
Retro86
Retro86's Avatar
Drives: Awesome
this has been discussed over here...
http://www.ft86club.com/forums/showthread.php?t=29954
that is my next project. actual rear foglight indicator on the guage engaged.
Old 04-10-2013, 10:14 AM   #38
norm24
Drives: TSX
Where'd you guys ground the other end of the fog lights? is there a location near the connector behind the bumper?
norm24 is offline   Reply With Quote
Old 04-10-2013, 10:27 AM   #39
FRSFirestorm
Red is Fastest
I grounded here at a factory ground point. You can see 3 (with fog ground) in the picture. This is looking down into the engine compartment. The yellow part is the oil fill tube. There is another ground point directly accross the bay for the passenger side.
From the pictures it looks like there is a ground wire in the connectors for the turn signals. A possiblility. The black wires have to be grounds.
Old 04-10-2013, 01:47 PM   #40
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Am I correct in thinking that the last thing needed to make the fogs 100% plug & play is the wire harness in this ebay listing:
http://www.ebay.com/itm/151013458015...witem=&vxp=mtr
BatStig is offline   Reply With Quote
Old 04-10-2013, 03:22 PM   #41
norm24
Drives: TSX
Looks about right. The connector splits into two, turn signals and fog lights. It would be awesome if we can find the part number for that harness.
Old 04-10-2013, 03:43 PM   #42
BatStig
Some say.....
BatStig's Avatar
@nigel-jdmparts @Carson Toyota
Would either of you fellas able to dig up this harness for us?
FRS fogs using BRZ stalk Sco2355 DIY (Do-It-Yourself) Guides 378 12-16-2018 05:17 AM
Factory shift light/chime Wonderbar Electronics | Audio | NAV | Infotainment 29 04-05-2013 03:30 PM
Manual shifter stalk thread dimensions for knobs bcj Scion FR-S / Toyota 86 GT86 General Forum 1 03-19-2013 06:42 AM
SEAT BELT STALK COVERS cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 1 03-01-2013 12:57 PM
FRS fogs using BRZ stalk Sco2355 Cosmetic Modification (Interior/Exterior/Lighting) 0 02-18-2013 01:51 PM
