Old 04-08-2013, 10:25 PM   #1
JeremyClarkson
JeremyClarkson's Avatar
Drives: Raven FRS 2013
Stock tires losing air?
i got my FR-S on Jan , through out the months ive been losing air in my tires, the 1st month 3 of my tires were flat , 2nd month i had some air loss in 1 tire , and by this month i got another light telling me that my tires are flat , i checked if my tires had holes or anything stuck in them , nothing ...just wondering if anyone else got the same problem before i take it back to the dealership
JeremyClarkson is offline   Reply With Quote
Old 04-08-2013, 10:30 PM   #2
Tiremonkey0824
Drives: 2013 Argento 6mt
Are they actually going flat, or is your tpms light just coming on? It may be that the air is contracting inside the tire when the temperature drops triggering the light to come on. This happens all the time, I work at discount tire co and when it's cold outside I have to do TONS of air checks and search for flat tires that aren't even leaking.
Tiremonkey0824 is offline   Reply With Quote
The Following User Says Thank You to Tiremonkey0824 For This Useful Post:
JeremyClarkson (04-08-2013)
Old 04-08-2013, 10:35 PM   #3
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
The guy at my dealer said that that's been happening to alot of Toyotas car. Your tire shrinks when it gets cold outside, so all you need to do is to fill up your tire with nitrogen air at your local gas station or at the dealer. The guy at the dealer filled up a couple extra psi for me so I didn't have to come back. (Cuz I live pretty far away)
Kelbyat07 is offline   Reply With Quote
The Following User Says Thank You to Kelbyat07 For This Useful Post:
Old 04-08-2013, 10:41 PM   #4
JeremyClarkson
the 1st time my 3 tires were flat , but the next 2 times was the tpms light that came on, i live in California , and the weather is just perfect right now !
Old 04-08-2013, 11:16 PM   #5
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Lol, then you want to talk to your dealer about that. My lights would always go on when it was cold. (I live in Chicago)
Old 04-09-2013, 09:50 AM   #6
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Adjust the air pressure in your cold tires to 35psi. If it's too much, let out some air. If not enough, pump some. Then go take a 10mile drive and see if the lights turn off. If it doesn't then take it to the dealer.
chenshuo is offline   Reply With Quote
Old 04-23-2013, 11:32 PM   #7
Willsonk
Drives: Scion FR-S Asphalt AT & XB
Could be the TPMS sensor nut might not being tighten down enough or too tight that would have crushed the rubber gasket. Should be (35 inch lbs) torque not foot lbs. This sounds crazy but spray some windex on the valve ( take cap off) and the nut around the valve and see if any bubbles show up.
Willsonk is offline   Reply With Quote
Old 04-24-2013, 11:22 AM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
What gauge are you using to fill up the air in your tires? It might not be accurate. It is not unreasonable for a tire to lose 1 to 2 psi per month.
Old 04-24-2013, 11:31 AM   #9
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
[ame="http://www.youtube.com/watch?v=uaxQiQB4lyM"]Give these people air - YouTube[/ame]
The Following User Says Thank You to 7thgear For This Useful Post:
Anthonytpt (04-24-2013)
Old 04-24-2013, 11:57 AM   #10
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
All the nitrogen from Costco!
Anthonytpt is offline   Reply With Quote
Old 04-24-2013, 01:09 PM   #11
simpleisbest
Senior Citizen
Drives: Scion FR-S
tighten your valve stem. I had one that was a little loose.
simpleisbest is offline   Reply With Quote
Old 04-24-2013, 01:13 PM   #12
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
I bought my car last September and only two times have I had my tpms alert me.
whaap is offline   Reply With Quote
Losing Control. Asterisked Accolade Other Vehicles & General Automotive Discussions 18 04-01-2013 10:39 PM
Been on a losing streak with my car lately...help sa1126 Scion FR-S / Toyota 86 GT86 General Forum 5 04-01-2013 10:18 PM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
I'm losing it. How did you cope? Kyubi Scion FR-S / Toyota 86 GT86 General Forum 56 01-09-2013 02:20 AM
Losing hvac lighting? SemperFi Electronics | Audio | NAV | Infotainment 0 11-01-2012 12:36 PM
