Old 04-08-2013, 12:38 AM   #1
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
My AC went out
I only have 12k on the odo and the AC stopped blowing cold. I'm gonna take it in tomorrow and see what happens.
mrha is offline   Reply With Quote
Old 04-08-2013, 01:27 AM   #2
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
stopped blowing cold or stopped blowing at all? checked your fuses?
phanguy is offline   Reply With Quote
Old 04-08-2013, 01:16 PM   #3
mrha
#1819
mrha's Avatar
It still blows just only warm air now
Old 04-08-2013, 01:23 PM   #4
HunterGreene
Hail Magnet
HunterGreene's Avatar
Just throwing this in, but could it be a leak in the AC system? Did you check around your engine bay around the AC compressor? If you see a bunch of dried residue, you may have your culprit.
Second check would be your fuses.
Good luck, hope its a simple fix.
Old 04-08-2013, 02:24 PM   #5
phanguy
phanguy's Avatar
awhile back my dads honda element did the say thing, but it couldn't blow hot either. it took some time but i eventually figured out that it was the blower motor resistor that went bad. once that was replaced it then it was blowing nice hot air(winter time) no problem. not sure where the blower motor stuff is located on our car, but if it's similar to the honda then it'll be where the glovebox is. but even still this is probably something that is easily fixed at the dealership under warranty.
Old 04-08-2013, 03:26 PM   #6
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Yea just let the warranty take care of it, no point doing it yourself and risk something wrong might happen when you have warranty left
shu5892001 is offline   Reply With Quote
The Following User Says Thank You to shu5892001 For This Useful Post:
20valvewynn83 (04-08-2013)
Old 04-08-2013, 06:51 PM   #7
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Warranty typically won't cover a leak in the ac condenser. Rock chips can do more than just chip paint, they can put holes in the condenser and leak all your r134a out.
Coheed is offline   Reply With Quote
Old 04-08-2013, 07:06 PM   #8
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
AC doesn't work because racecar.
Subie is offline   Reply With Quote
The Following 3 Users Say Thank You to Subie For This Useful Post:
20valvewynn83 (04-09-2013), ftc~brz (04-10-2013), microbionic (04-08-2013)
Old 04-08-2013, 08:32 PM   #9
mrha
#1819
mrha's Avatar
Just came back from the dealership and they told me my condenser is damaged.
The weird thing is that the damage is behind the crash bar and you can't see it unless the car is up on a lift. Also there is no damage to my front bumper or grille. They told me to call Subaru corporate to see if I can get some relief.
The damage isn't covered by the warranty and the cost of the part + labor is $678.
Last Monday I had to pay $500 to put my dog to sleep and now this. Mondays aren't my day.
Old 04-08-2013, 08:43 PM   #10
phanguy
phanguy's Avatar
that is rough. sorry to hear man.
if they really aren't willing to help then i'd suggest checking for the forum marketplace for part outs. maybe someone has a condenser you can get for a decent price and you could do the install yourself hopefully maybe?
http://www.ft86club.com/forums/showthread.php?t=30425
The Following User Says Thank You to phanguy For This Useful Post:
mrha (04-08-2013)
Old 04-08-2013, 08:48 PM   #11
mrha
#1819
mrha's Avatar
Yeah I've been PMing as many members as I could find. For now I guess I'm just gonna have to drive with my windows down.
Old 04-08-2013, 09:09 PM   #12
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Why doesn't the warranty cover the ac condenser? I thought bumper to bumper warranty means it'll cover everything between the front bumper and the rear bumper for anything that's not a wear and tear part.
chenshuo is offline   Reply With Quote
Old 04-08-2013, 09:10 PM   #13
Subie
Señor Member
Subie's Avatar
If it's damaged it's very likely it's due to road debris (unless the OP gives details to indicate otherwise).
Old 04-08-2013, 09:31 PM   #14
BRZnut
Drives: BRZ DGM Limited
Would suspect that is what happened. I don't like how its so open at the lower front grill. Anyone make a black mesh for the lower grill that can be installed to protect from stones etc??
