Old 04-08-2013, 01:08 PM   #15
Retro86
Retro86's Avatar
Drives: Awesome
Originally Posted by FRSFirestorm View Post
Can I use your photo's from the other thread for this threa? The connector's behind the front nose.
sure feel free to use it
Retro86 is offline   Reply With Quote
Old 04-08-2013, 07:00 PM   #16
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
so this set up, can only turn the fogs on, with parking lights or headlights are on?
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 04-08-2013, 07:22 PM   #17
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Headlights, low beam only.
FRSFirestorm is offline   Reply With Quote
Old 04-08-2013, 10:21 PM   #18
Low&Slow
Low&Slow's Avatar
Drives: 10 Series #845
If i may ask, where did you purchase your fog lights at? ( Light, bezzel, etc..)
Low&Slow is offline   Reply With Quote
Old 04-08-2013, 10:29 PM   #19
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Did you not read the second paragraph?
OP is it cool if I update my thread and add a link to this one?
Juanito08 is offline   Reply With Quote
Old 04-09-2013, 03:23 AM   #20
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
hmm i hope this is not a stupid question but where did you buy the stalk with the fog light option? thanks in advance
imravenit is offline   Reply With Quote
Old 04-09-2013, 05:41 AM   #21
FRSFirestorm
Red is Fastest
Please refer to the link I posted for the fog light install.
Sure.
Toward the end of the stalk install link I posted the part number is posted. I don't remember it or I'd post it. I just googled that part number and several parts places showed up. I just picked the cheapest one and ordered it. It was a dealership with online parts presence.
Old 04-09-2013, 07:47 AM   #22
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
is it this one?
http://www.toyotapartszone.com/oem/t...140-02670.html
subaru has it too? $60?
http://subarupartsforyou.com/cp_part...p?partid=23294
Old 04-09-2013, 08:03 AM   #23
FRSFirestorm
Red is Fastest
Yep. That's it.
Old 04-09-2013, 08:17 AM   #24
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
Yep. That's it.
so you went with the tundra stalk correct?
This is the second and the better option. I was strapped for time and had to complete mine. Didn't want to pull the front bumper. Sometime in the future I will and undo the wires that I've run
After installing the stalk and fogs remove the front cover.
Find the connector that the turn signals plugged to. On the drivers side the red/white wire or 12v power for the fogs will be in that connector. Either splice into the wire there and run it to one side of the Drivers fog connector and the other to a convient ground location. Do the same on the drivers side but the wire will be the white/red.
Here are some pictures of the connectors behind the front cover.
so with this approach theres no meed to tap into the bcm c3 anymore correct?
Old 04-09-2013, 08:29 AM   #25
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Completely lost here...
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-09-2013, 09:03 AM   #26
Retro86
Retro86's Avatar
Drives: Awesome
get the subaru stalk. its cheaper. plus its oem.
Old 04-09-2013, 09:06 AM   #27
Retro86
Retro86's Avatar
Drives: Awesome
yup! just need a female connector pin or make shift connection anyway you like runnin through the connector.
Old 04-09-2013, 09:11 AM   #28
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
its coming a lil bit all together now .. so if i understand this correctly.. once ive installed the brz stalk no wiring needed basically just switch stalks..
locate the connector for the signal lights for both driver and passenger tap in to the red/white wire vice versa and then find a ground for fog lights .. flick the saitch and it should work?
on the side note i thought the brz stalk has the auto headlights feature?
FRS fogs using BRZ stalk Sco2355 DIY (Do-It-Yourself) Guides 378 12-16-2018 05:17 AM
Factory shift light/chime Wonderbar Electronics | Audio | NAV | Infotainment 29 04-05-2013 03:30 PM
Manual shifter stalk thread dimensions for knobs bcj Scion FR-S / Toyota 86 GT86 General Forum 1 03-19-2013 06:42 AM
SEAT BELT STALK COVERS cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 1 03-01-2013 12:57 PM
FRS fogs using BRZ stalk Sco2355 Cosmetic Modification (Interior/Exterior/Lighting) 0 02-18-2013 01:51 PM
