Old 04-06-2013, 10:59 PM   #15
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Originally Posted by rainmonkey View Post
If I'm reading this correctly, you're basically saying that between 17 and 18, the major difference will just be weight, because total diameter of the wheel+tire is still roughly the same as a 17.
If 8 and 9 are not considered 'over-tire-ing' then what is? I was always under the assumption that anything past 8 was just for looks... even on track. Granted I don't know much about this stuff.
btw, thank you Alan, you're helping a lot.
No problem. As you indicate, you're new at this. I remember when I first got into modding in 2000 and knowing absolutely nothing. 13 years and 7 cars later, I'm still learning, but enjoy helping others, especially those new that sometimes don't get answers. I should also add that this info is particularly fresh for me as I just bought new wheels and tires for my BRZ this week.
I think 9 is probably enough for most people with these cars. 10s seem to be pushing it except if you really need the grip at track/auto-x. But even then its a lot of wheel/tire for a 200hp car. You can always have more grip with a wider tire (and thus wider wheel). But the question is, can you exploit it and what are the downsides? Oversimplifying, a wider wheel and tire combo will add weight, may affect the feel and of course there is only so much space under the fender.
In most cases, whenever you "+1" (the term for adding an inch in diameter to a wheel), you will get a tire with a smaller sidewall heigh so the total diameter of the wheel/tire package is the same. Thus the wheel rotates the same number of times in a given distance. You would get an even smaller sidewall if you "+2" and so on. At some point, you just can't get a smaller sidewall tire and you run into a larger overall wheel/tire package which would then affect the rolling diameter and which would then affect the speedo/odo.
This link and the links on the page at Tire Rack will give you plenty of reading for wheel/tire education.
http://www.tirerack.com/tires/tirete....jsp?techid=31
Alan is offline   Reply With Quote
Old 04-07-2013, 12:31 AM   #16
Chuynh207
I have an FR-S and drove this past winter with General Altimax Arctic tires. They are dedicated winter tires and were awesome! After the "nemo" blizzard, I drove from Boston to NJ and they were great. As long as I wasn't trying to accelerate quickly and just stayed cautious, I was perfectly fine.
I recommend getting a set of winter tires for the winter, if you're planning on driving the car at all. Just my recommendation though
Chuynh207 is offline   Reply With Quote
Old 04-07-2013, 01:40 AM   #17
rainmonkey
Drives: BRZ - Dark Grey
Yeah I've resigned myself to getting a set of winters.
If I wrap my OEM wheels in winter tires and get a different type of wheel (say for example 18x8) would I have to readjust my suspension when I swap em?
rainmonkey is offline   Reply With Quote
Old 04-07-2013, 07:30 AM   #18
Skurj
Drives: SOLD...
I've had my V12's out when its below zero, and they aren't bad at all. I wouldn't want to hit any ice, but if the pavement is clear they are fine.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 04-07-2013, 01:11 PM   #19
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
No - this is what most of us have done. Stock wheels are good winter beaters!
Khyron686 is offline   Reply With Quote
FS: stock summer tires abutterman Wheels and Tires 4 03-28-2013 07:46 AM
I miss my summer tires FRiSson New England 23 02-19-2013 11:27 PM
Summer preformance VS All season performance ScionFamily Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-06-2013 08:11 PM
Looking for new summer tires, but don't want to add too much grip @Art_Mighty Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 12-24-2012 09:27 AM
Yep, these are summer-only tires. FRiSson New England 5 11-09-2012 09:12 AM
