Old 02-18-2013, 09:25 PM   #15
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Too bad they killed that preproduction pedal.. that made it look a lot easier. It's still easy compared to my other track car with it's bent pedal box
I'd like to see a nice replacement that actually replaces the stock pedal instead of bing stuck/screwed on, not sure if the OEM pedals are easily removed or not.. probably not.
The stock pedal is a plastic piece with complex contours. Been a while, but if I remember correctly, when I had the pedal assembly out for installing the SRP pedal, it seems to be slid onto the shaft with a set-screw/roll pin holding it in place.
I really do like the SRP pedal though....when firm on the brake pedal the outside of my foot is over the accelerator pedal and sole of my foot just barely touching it. Rock foot just slightly into the accelerator pedal to blip it. Feels perfect with the Adidas wresting shoes I wear for driving and I've had no issues with dress shoes. It's as solid in feel now as it was when initially installed some 6 months ago.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
swift996 (02-18-2013)
Old 02-18-2013, 10:15 PM   #16
swift996
swift996's Avatar
So that's just the SRP accelerator pedal? Can you snap a pic from the angle showing how it sits relative to the other pedals in position (from the side profile)? It looks suffice for what I need.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-19-2013, 12:20 AM   #17
FasterpromsFRS
FasterpromsFRS's Avatar
Drives: FRS
i took the stock pedal off and added washers to give it a raise, and removed the metal cylinders under the pedal to allow it to slide left ever so slightly. I went from having a real hard time learning it, to now getting it fairly easy, for free. Pedal hasnt fallen off yet heh.
FasterpromsFRS is offline   Reply With Quote
Old 02-19-2013, 07:36 PM   #18
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
I actually bought the car that PedalPusher (site sponsor for SRP) owned up in North Carolina. My car is the one on the site with the black pedals. Let know if you would like some additional pictures or anything like that.
Thanks,
n8dog11914 is offline   Reply With Quote
Old 02-19-2013, 07:55 PM   #19
Vracer111
Vracer111's Avatar
Doubt I could get a good shot in that cramped space... Put it this way, when you are one the brakes firmly the pedal surface is the same distance from the firewall as the accelerator pedal. If you press REALLLY hard the brake pedal will be a little closer to the firewall than the accelerator pedal. The pedal itself is 1/8" thick.
swift996 (02-19-2013)
Old 04-06-2013, 08:24 PM   #20
EN2_Squirrel
EN2_Squirrel's Avatar
Originally Posted by bbb View Post
Will both sizes fit?
EN2_Squirrel is offline   Reply With Quote
Old 04-06-2013, 09:48 PM   #21
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I have fitted the Cusco unit. Fiddly to install. Has made throttle blipping so much easier. I was reluctant to get it though because I think it has reduced the value of my car by 20%. At least it isn't anodised blue.
iLuveKetchup (04-06-2013)
Old 04-06-2013, 09:49 PM   #22
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
http://www.japanparts.com/db/parts_detail.php?submit.x=66&submit.y=7&NUMBER=000 42625&VOLUME=495-001-007&DEALER=2&CAR=178&MIDDLE=2&SMALL=13&MAKER=301&V OLKEY=&SEARCH_DEALER=2&SEARCH_CAR=178&SEARCH_MIDDL E=2&SEARCH_SMALL=13&SEARCH_MAKER=&SEARCH_VOLKEY=&S EARCH_page=
^ This one seems to bring the pedal lower.
http://www.japanparts.com/db/parts_d...=&SEARCH_page=
^ This seems to imitate the pre-production pedal.
*Never tried them, hell I don't even have an FR-S/BRZ... I just drool @ their pictures all day.*
That said I have used Razo pedals before on my current and previous car. They never fell off, nor will they come off without cutting now that the steel screws are rusted into the aluminum? pedal. Thanks city hall, for all the salt.
KKaWing is offline   Reply With Quote
Old 04-06-2013, 10:06 PM   #23
CrazyWookiee
Drives: Whiteout FR-S
I installed the same one. It was pretty fiddly to install, hard to grasp the nuts behind the bolts. But I was successful enough to grab them with some longer bent nose pliers.
The pedal has worked wonders for me. Here's a review video I put up a few days ago:
[ame="http://www.youtube.com/watch?v=q4cfX1aocTo"]Cusco Sports Accelerator Pedal FR-S/BRZ/86 Install & Review - YouTube[/ame]
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 04-09-2013, 06:51 PM   #24
emutcfut
Drives: 2013 Argento
Slightly off topic but guys with the SRP pedal, how did you get the stock aluminum cover off? There isnt any room to pry the tabs up. Did you just cut them off?
emutcfut is offline   Reply With Quote
Old 04-09-2013, 07:57 PM   #25
celica73
I took the pedal out of the car (easy to do) and pried up the tabs. Unfortunately, I gave up on the SRP pedal this weekend. For me, it was too close to the brake and resulted in a lot of unwanted simultaneous brake-gas situations.
Radar Detector Recommendation? execoll Electronics | Audio | NAV | Infotainment 39 05-11-2019 03:59 PM
Recommendation for Mild audio upgrade czar07 Electronics | Audio | NAV | Infotainment 19 02-05-2014 11:09 PM
PDX Recommendation for Detailing JayNutter Northwest 2 12-08-2012 10:26 PM
FT-86 Speed Factory Quick Recommendation Carban User/Vendor/Sponsor Reviews, Feedback, Comments 15 11-15-2012 05:48 PM
Recommendation: Toyota/Scion of Irving (DFW) Lefty Scion FR-S / Toyota 86 GT86 General Forum 3 06-12-2012 11:04 AM
