Old 04-02-2013, 03:20 AM   #1
GhostofAkina
Drives: 2013 Scion FR-S Raven
LED vs HID: what's the difference?
Hey guys, I know I will surely be outing myself as a noob but I need your help on this. Can anybody tell me what the difference is between LED and HID lights? Most of the information I've found are on the difference between the gasses and their respective properties but I'm wondering more about the real world differences, like; which are more OEM looking? Which produce better visibility? Which are harder/more expensive to install and why? Thanks your you help and insight.
GhostofAkina is offline   Reply With Quote
The Following User Says Thank You to GhostofAkina For This Useful Post:
calis5nest (04-05-2013)
Old 04-02-2013, 10:16 AM   #2
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
if for visibility go with HID. LED looks nice but is useless for visibility. they are both plug n play. the HID just has extra wires leading to its power box since it creates more power for a stronger light
lbroskee is offline   Reply With Quote
Old 04-02-2013, 10:29 AM   #3
infinite012
Drives: 13 DGM BRZ Ltd
If you're talking about plug and play kits, don't waste your money (even if it only costs $20 for whatever crap kit you decide to purchase).
Do it right and either retrofit HID projectors and use OEM HID hardware (D2S bulbs and OEM ballasts) with a wiring harness (to avoid melting your car) or just upgrade your halogen bulbs to H9 (I think that's the one).
infinite012 is offline   Reply With Quote
Old 04-02-2013, 11:38 AM   #4
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
I have LED'S for my DRL's and it eliminates the high beams which I never used in any car I own, but if you ever need to use them they are not there. They look nice, but are really non functional.
As for HID's, the plug and play kits get all kinds of grief because "you shouldn't spend 30k on a car to not spend money on proper lights" or "they are not aimed correctly".
Personally I don't have the skill/time or want to bake headlights in the oven I cook my food in, but some do for a retrofit. If you are looking for most usable light, just upgrade the halogen bulbs.
UnOvertime is offline   Reply With Quote
Old 04-02-2013, 11:40 AM   #5
YourFearlessLeader
Team ScioNRG President
YourFearlessLeader's Avatar
Drives: 2017 WRB BRZ
HID produces better visability than an LED. While LEDs are extremely energy efficient and last very long, they only provide a focused beam of light.They are unidirectional. A halogean bulb or "HID" buld will produce light in all directions.
2017 Subaru WRB Limited BRZ w/ PP
YourFearlessLeader is offline   Reply With Quote
Old 04-02-2013, 12:34 PM   #6
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
its about color spectrum
Huehuecoyotl is offline   Reply With Quote
Old 04-02-2013, 01:09 PM   #7
infinite012
And color rendition (I guess that's the same thing as saying color spectrum...). And luminous output.
Old 04-05-2013, 05:43 PM   #8
eurominican
Bringing Hachiroku Back
eurominican's Avatar
Drives: 2013 Firestorm FR-S
Why the hate towards plug and play HID's? Please excuse the ignorance..
eurominican is offline   Reply With Quote
Old 04-05-2013, 06:45 PM   #9
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
HID's = high output over a great distance. Primary use: Headlights/hi beam/some fog lights
LED's(Light emitting diode) = Bright and precise over a small distance(generally). Primary use: Turn signals/brake lights/markers/running lights/interior lights etc.
Disclaimer: Some high end manufacturers are starting to use, or at least develop LED headlights and such that will work over a greater distance.
Trashed675 is offline   Reply With Quote
The Following User Says Thank You to Trashed675 For This Useful Post:
Lverasky (04-05-2013)
Old 04-05-2013, 08:12 PM   #10
MaximaZero
MaximaZero's Avatar
http://www.theretrofitsource.com/trs...s_hid_kits.php
MaximaZero is offline   Reply With Quote
Old 04-05-2013, 10:55 PM   #11
eurominican
Originally Posted by MaximaZero View Post
For what I've seen so far here, the stock projectors on the frs are pretty good for pnp hids. I'm sure retrofitted shrouds/projectors will be better but for 60 bux vs prolly $300+ ... I'm going with hids
Old 04-05-2013, 11:25 PM   #12
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Same here, the stock projectors are really good, have yet to have anyone flash me with my pnp HiD's.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
The Following User Says Thank You to WolfsFang For This Useful Post:
Tim_Asphalt_FRS (04-06-2013)
Old 04-06-2013, 02:32 AM   #13
TYPEONE86
Drives: SCION FR-S
if you guys want to upgrade ur fog...here's your option:
http://www.spoonzauto.com/product_p/hn-brz-h11.htm
TYPEONE86 is offline   Reply With Quote
Old 04-06-2013, 07:23 AM   #14
Liquid Thinker
Drives: 2008 Nissan Titan
Most places it seems to be an elitism thing. As long as your don't have horrible housings that blind the crap out of everyone then pnp kits generally get the job done. No you wont have a perfect cut off when you are 10 feet from a wall (seriously how often do people drive into walls), and yes the light will probably have some hot spots. However, from a cost/effectiveness standpoint they are hard to beat, if you are objective about it.
*Yes I understand the merits of retrofits, and the purpose of a clean cutoff.
Liquid Thinker is offline   Reply With Quote
The Following User Says Thank You to Liquid Thinker For This Useful Post:
Tye300 (04-06-2013)
Right gas makes big difference Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 33 06-22-2013 06:03 PM
BRZ vs BRZ limited? what is the difference? Bangduk Scion FR-S / Toyota 86 GT86 General Forum 1 08-07-2012 03:36 PM
The Yamaha Difference Exage Engine, Exhaust, Transmission 36 12-05-2011 01:03 PM
