Old 04-05-2013, 07:32 PM   #127
Yruyur
Yruyur's Avatar
Awesome thanks
Old 04-05-2013, 08:31 PM   #128
Yruyur
Yruyur's Avatar
I have the feeling I was shipped the wrong harness. Is anyone available to call me. Pm me your number.
Sent from my GT-P3113 using Tapatalk 2
Old 04-05-2013, 08:36 PM   #129
Yruyur
Yruyur's Avatar
I may have the correct harness. I only have 4 plugs off of the relay harness not 5. Its missing the ground but each of the ballast connections have their own ground.
Old 04-05-2013, 08:47 PM   #130
Yruyur
Yruyur's Avatar
As you can see from the pic there are only 4 wads coming from the relay harness. Each ballast plug has its own ground. Are these grounds used for the relays and the ballasts?
Old 04-05-2013, 09:47 PM   #131
Yruyur
Yruyur's Avatar
Found another mounting spot. Double sided tape. Bolt and zip tie.
Old 04-05-2013, 10:48 PM   #132
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Did you get the harness figured out? If not, shoot me a pm. The notification comes right to my phone so I can respond quickly.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 04-05-2013, 10:59 PM   #133
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Another spot for mountng ballast is under the fender area
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 04-05-2013, 11:22 PM   #134
Yruyur
Yruyur's Avatar
Stock compared to new. New is the smaller one.
Old 04-05-2013, 11:24 PM   #135
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I've retrofitted this kit and love it.. Did my own little mod to the housing for a red LED and it lights up at night a subtle red when on.. I have my ballast mounted on the wheel moulding a.. I learned the hard way about hiding them and placing them in places that when they go out pulling apart the whole bumper or fender in one case just to swap out a ballast.. Guys with the morimoto kits really shouldn't have to worry much, as their kits are top notch, but still shit happens..
I never got the boots with my retrofit.. I'm going to have to call and get two sets coming.. One for mine and one for a club member that I'm about to do a quad retrofit on.. This should look sick
Gixxersixxerman is offline   Reply With Quote
Old 04-06-2013, 02:36 PM   #136
Yruyur
Yruyur's Avatar
Finished at midnight last night. Pretty damn easy if I had to do it again. So for anyone else doing the install you will most likely have what I think is a revised harness like mine that does not have a long ground cable that runs up to the battery. I believe the relay mount is just a ground now.
Will do some aiming tonight. Thank you so much for everyone that posted in here especially @civicdrvr. Very helpful information.
The Following User Says Thank You to Yruyur For This Useful Post:
civicdrivr (04-06-2013)
Old 04-06-2013, 03:24 PM   #137
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Sorry I couldn't talk on the phone last night, but I figured it was just a revised harness. Output pics?
Parting out HERE
Old 04-06-2013, 03:36 PM   #138
Yruyur
Yruyur's Avatar
Ill take some pics tonight when I align.
Old 04-07-2013, 01:04 AM   #139
SupraRon
SupraRon's Avatar
Drives: Raven 6AT
I think I got that revised harness where the 2 cables going to the ballasts have a ground split from each one. I grounded them to the frame.
Edit: I see you covered that on your previous posts. I too have the ground coming from the relay.
The fun has returned!!
Morimoto Mini H1 HID conversion
SupraRon is offline   Reply With Quote
The Following 2 Users Say Thank You to SupraRon For This Useful Post:
civicdrivr (04-07-2013), Yruyur (04-07-2013)
Old 04-11-2013, 10:18 PM   #140
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
im noob with a retrofit thingy, so when u do a morimoto retrofit, can u still use the HID kit u use in a halogen projector or the retrofit has its own ballast, and replacing the bulb to D2S?
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 08:37 PM
The Retrofit Source Bi-Xenon FR-S Retro-Quik Conversion Andrew @ TRS Exterior Parts - The Rest 84 07-23-2012 10:43 PM
OEM Fog Light install! ON and working! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 07-04-2012 08:11 PM
How to install Homelink mirror? Grimlock Electronics | Audio | NAV | Infotainment 10 06-10-2012 07:07 PM
Five axis limited retro Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 28 05-18-2012 04:16 PM
