Old 04-04-2013, 03:14 PM   #15
df.dima
Drives: FR-S and Mazda 3 Sky
Ok its out of storage. Holy shit I've been missing a lot of while driving the winter beater .
I basically just started it, because my battery died (long story short: i bought the charger the day I put it in storage and there was a wrong manual in the box - completely unrelated, so I didn't really know how to set it, buttons are not labelled well - I seem to set it to maintainance mode, but battery still drained).
We put it on the charger, let it sit for 30 mins and it started without any hickups.
df.dima is offline   Reply With Quote
Old 04-05-2013, 09:44 AM   #16
FR-S/GT-86
FR-S/GT-86's Avatar
Drives: 68MGBGT/93MiataLE/11Legacy
Originally Posted by Mikem53 View Post
I would think the fuses would be labeled so you can pull the one you need..
IMO .. I believe you are over thinking this.. Storing your car for one season doesn't require any special precautions on startup.. Not with a modern engine in running order..
I feel this way... you're going to get 2 gazillion interpretations on what to do after winter storage.
Here's what I did: Started the car, let it idle, drove away. Mine was in storage from October to end of March. All I did was buy a custom fitted car cover, pump the tires up to 40psi, add Stabil to the fuel, leave it with the e-brake OFF, and rolled it manually a foot in one direction, then a foot in another a couple of times to keep the tires from flat-spotting over the winter. My storage garage doesn't have electricity, and it didn't even hesitate to start.
FR-S/GT-86 is offline   Reply With Quote
Old 04-05-2013, 09:47 AM   #17
Jason952
Pull the relay if u are worried
Jason952 is offline   Reply With Quote
Old 11-23-2014, 12:40 AM   #18
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Has anyone figured out a way or confirmed the 100‰ throttle method? Perhaps pulling injector fuse? Would also like to crank the oil a bit before starting the engine come spring. Thanks!
1Cor10:23 is offline   Reply With Quote
Old 11-23-2014, 03:03 AM   #19
Yes, it's true. It's a common flood-clearing feature. Works on this car.
Old 11-23-2014, 04:30 AM   #20
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Didn't know that. Thanks for the tip, it may be helpful one of these days..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 11-23-2014, 12:42 PM   #21
1Cor10:23
1Cor10:23's Avatar
So basically, accelerator to the floor when starting the car? Thanks!
Old 11-23-2014, 01:54 PM   #22
Correct. Fuel is cut as long as you have the accelerator mashed into the floorboard before and during cranking.
1Cor10:23 (11-23-2014), HunterGreene (11-24-2014)
Disabling Compass & Auto Dim on Homelink ZC6BRZ Electronics | Audio | NAV | Infotainment 2 04-20-2014 03:34 PM
ever seen fuel injection like this? carbonBLUE Other Vehicles & General Automotive Discussions 1 10-17-2012 03:17 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained Moshpit37 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 06-26-2012 10:19 PM
Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained Moshpit37 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-21-2012 01:47 PM
