Old 03-21-2013, 12:20 AM   #29
DSlayerZX
Drives: 2010 Corolla, 2013 Fr-s
I just purchased a proclip today. I"ll let you guys know how it turns out.
DSlayerZX is offline   Reply With Quote
Old 04-04-2013, 12:55 PM   #30
MadFRS
MadFRS's Avatar
Drives: UltraMarine FR-S
Originally Posted by jshadeck View Post
Mine is mounted w out using the adhesive. It is not going anywhere or i would have used the adhesive as im not opposed to using it, but mine doesnt even wobble slightly
I can attest to the ProClip not needing the adhesive as well. I even have an extra Ram Mount Arm attached to the ProClip.
MadFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to MadFRS For This Useful Post:
kludger (04-04-2013), serial gixxer (04-04-2013)
Old 04-04-2013, 01:07 PM   #31
serial gixxer
I have the proclip mounted now and I can confirm what the others have said regarding not needing to use the adhesive.
serial gixxer is offline   Reply With Quote
The Following User Says Thank You to serial gixxer For This Useful Post:
Old 04-04-2013, 01:32 PM   #32
kludger
kludger's Avatar
Drives: '13 Boxter S, '13 BRZ(gone)
Thanks for confirming the no adhesive needed, proclip on the way and I was waiting to mount it until after doing the reverse camera DIY to avoid having to undo the adhesive, but now I know it won't matter.
kludger is offline   Reply With Quote
Old 04-04-2013, 01:34 PM   #33
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
I was using the Exogear Exomount 2, but I've been hesitant to put it back on the windshield since the tint was applied. Anyone have insights to share with tinted windows and suction mounts? Thank you!
Anthonytpt is offline   Reply With Quote
Old 04-04-2013, 02:13 PM   #34
Hanakuso
I'm happy with my RAM Mount
Hanakuso is offline   Reply With Quote
Old 04-11-2013, 12:02 PM   #35
13 FR-S Veteran
13 FR-S Veteran's Avatar
Drives: 2013 FR-S (Raven Black)
I was messimg around with my Mountek mount the other day and discovered that it's in the perfect spot to allow me to use my Galaxy note 2 as a dash cam when it's in the vertical position.
Sent from the great white north via smoke signal.
13 FR-S Veteran is offline   Reply With Quote
Old 04-11-2013, 12:45 PM   #36
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
I have iOttie Easy View, works best ever.
[ame="http://www.amazon.com/iOttie-Universal-INCREDIBLE-BlackBerry-Revolution/dp/B00B78MT44"]Amazon.com: iOttie Easy View Universal Car Mount Holder for iPhone 5 4S 4 3GS Samsung Galaxy S3 S2 Nokia Lumia 920 Touch 4G HTC OneX EVO 4G Rhyme DROID RAZR MAXX BIONIC INCREDIBLE 2 CHARGE Google Nexus BlackBerry Torch LG Revolution GPS Compact Size 360 degree Rotatable: Cell Phones & Accessories[/ame]
Old 04-12-2013, 01:47 PM   #37
Jaqub Jackson
Drives: Honda Civic
Hello man. After reading about small holder on the FRS/BRZ with 3D print I search a lot but did not find anyone. I really did not find such thing which require direct access to 3D printer.
Jaqub Jackson is offline   Reply With Quote
Old 06-13-2013, 10:01 PM   #38
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
I did not see Gooseneck on the RamMount website. Where can i get one like yours?
Originally Posted by F1point4 View Post
This RamMount Gooseneck is what i use
chenshuo is offline   Reply With Quote
Old 06-13-2013, 10:14 PM   #39
kALMIGHTY
Drives: TRD Ultramarine '13
You got your windshield tinted?
Anyway, if the tint is completely dried and adhered to the glass, you should have no problem putting a suction mount on it. The only problem would be if it was mounted close to the edge of the tint where it could start to lift up a bit by pulling the mount off, but if it's closer to the middle of the tint, there shouldn't be a problem.
Old 06-14-2013, 08:26 AM   #40
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
I got the iottie and its great and cheap, plus its universal will fit any car.
speedy racer is offline   Reply With Quote
Old 06-14-2013, 10:47 AM   #41
Anthonytpt
Anthonytpt's Avatar
Yes, it's a clear film with a hint of blue. Specifically, it's Llumar's Air 80 blue ceramic windshield tint.
Old 06-14-2013, 12:53 PM   #42
spgrizz22
Drives: Scion FR-S
Have any of you guys tried imagnet before? I just bought it, and I love it! No, it doesn't mess up the phone, but do not keep it next to your wallet. It sticks perfectly and also it doesn't fall off or anything. But I do have to say if you have a big case on your phone, you can either put the magnet outside of the case with the adhesive or switch cases! They give you two magnet adhesives to put on top of the case if you have a big case and one thing circle magnet to put inbetween the phone and case. Now if you go naked with your phone and have entry to your battery, you can open then back of your phone and put the small thin circle magnet in there. IT WON'T MESS UP YOUR PHONE. I love it!
spgrizz22 is offline   Reply With Quote
STI Group N Strut Mounts ZC6BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 03-12-2017 08:08 AM
Whiteline Com-c top mounts sw20kosh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 349 05-27-2015 05:15 AM
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-11-2013 11:31 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 07:07 PM
