Old 04-04-2013, 12:43 AM   #29
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Spec'd out the Cusco kit through individual parts on McMaster-Carr (assuming wire terminals were for the usual 8mm bolts on the engine) and included heat-shrink wrap suitable for up to 450 F, all came out to be ~$40. Yay~
Assuming I go with gmookher's advice, I can get it down to about $10. Sweeet!
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
The Following User Says Thank You to markmatley For This Useful Post:
Huehuecoyotl (04-04-2013)
Old 04-04-2013, 03:20 AM   #30
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by JoeBoxer View Post
Cusco seems to produce a lot of parts that don't really provide any results, this and the big bore throttle body seem to just be out there to take peoples money. Some people will buy it just because they think it wouldn't be available if it didn't add power or they want it for bragging rights on the show circuit. I don't have a lot of respect for Cusco for offering stuff like this.
This may be a bit dramatic but this is why I refuse to put any Cusco products on my car. I have seen this on other platforms I have owned. They have lost my respect/interest and are so greedy.
Old 04-04-2013, 04:42 AM   #31
silverbullet
Drives: 2013 BRZ LTD Silver
I haven't gotten my ohm meter out and done any legit testing yet but I have noticed that the electrical system does become a little taxed at idle. With the headlights, rear defrost, radio, and heated seats on, flipping on the climate control can almost stall the car when the AC compressor kicks in. Obviously this is with the alternators output at a minimum and as rpms increase so do the available amps to the system but, theoretically, if someone hadn't done all their maths right during the engineering process, I guess it might be possible for conditions to be just right to get a random weak spark that causes a misfire that causes the ecu to pull timing or modify the DAM value slightly. Even with that in mind, I really don't think that is the case here and I don't believe marketing a product like this as a HP increasing mod has any justification in today's market. Hell, even all the popular spark voltage increasing boxes to put on muscle cars back in the day didn't do anything but prevent misfires and put some colored cables in your engine bay.
silverbullet is offline   Reply With Quote
Old 04-04-2013, 05:09 AM   #32
tisb0b
Drives: Grey GT86 MT
If no-one bought the product then they wouldn't be making it. There is a demand and they are meeting it, basic business. Hating a company for producing items that customers want is stupid.
tisb0b is offline   Reply With Quote
Old 04-04-2013, 05:42 AM   #33
silverbullet
For anyone interested in the full article.
http://www.importtuner.com/powerpage...13_scion_fr_s/
$2561 in parts for 6.8 hp and 6.4 lb/ft. Apparently Cusco thinks we are all stupid.
Old 04-04-2013, 09:33 AM   #34
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
If you want a grounding kit i would suggest the Chase Bays one.
The Following User Says Thank You to JoeBoxer For This Useful Post:
markmatley (04-04-2013)
Old 04-04-2013, 09:37 AM   #35
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
what does the chase bay cost?
next tiime I will try using a s grounding strap
Huehuecoyotl is offline   Reply With Quote
Old 04-04-2013, 01:19 PM   #36
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
$100 and there's isn't much wire involved.
http://www.chasebays.com/product/sci...rs--subaru-brz
Better off getting some 4g or larger wire and terminals from a local audio shop. Heat shrink is dirt cheap.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 04-04-2013, 02:12 PM   #37
sw20kosh
No where did I sat I hate them. I just refuse to support them.
Buying products because of hype and name brand blindly and paying exorbitant prices is stupid. C wut I did there?
Old 04-04-2013, 06:14 PM   #38
markmatley
markmatley's Avatar
Calm down guys! We're all car friends here.
I understand that all of us buy products based on many different factors, some include hype, some include price, effectiveness, design, brand name, etc etc the list goes on. But what we need to focus on is whether someones home grown solution or brand name bought item does or doesn't relieve our cars of issues that we may have/already encountered.
So as soon as I get my 8 gauge or 3 gauge wiring and terminals and the heat shrink tubing, Ill post my home-made solution up and tell you guys if anything unusual happens. Note that I do not have an aftermarket stereo or any other electrically taxing equipment besides retrofits.
~Matt
Old 04-04-2013, 07:12 PM   #39
2point0
2point0's Avatar
Since you're doing this yourself, if you have a soldering iron/gun or any kind of torch, I recommend soldering the terminals.
On my WRX, I think I used 8g wire, but I'd slide on the heatshrink, crimp on a ring terminal then set it in my bench vise and aimed my torch at the connection for a bit (cheap propane torch from Home Depot). Once it was hot, I pushed the solder in from the top and basically filled the whole connection. I then slipped the heatshrink on past the end of the wires and shrunk it down so the whole thing was covered except for the ring itself. Very solid connections and fairly weatherproof.
Old 04-04-2013, 07:16 PM   #40
OrbitalEllipses
Drives: Attitude
That's the way to do it. Wondering if this will help with idle issues as it did on my WRX.
Old 04-04-2013, 07:23 PM   #41
2point0
2point0's Avatar
I would think so. One of these days I'll either adapt my old wires to the BRZ or just start fresh with something heavier. It's amazing how much strain there is just turning on the rear defroster.
Old 04-04-2013, 07:52 PM   #42
markmatley
markmatley's Avatar
Roger that! Was planning to double crimp then solder the end of terminal with the wire attached just in case. I have heat shrink tubing that should withstand up to 492F, and is chemically resistant (oil, acid, cat pee...LOL).
I haven't had much idling issue, but maybe I'll keep a better eye on things before I do this mod to see if any changes occur.
~Matt
Cusco Zero 3s on the car Spaztastik Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 08-02-2012 02:12 AM
New Cusco parts! ($$$$) Thongpocket BRZ First-Gen (2012+) — General Topics 15 06-21-2012 05:43 PM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 03:24 PM
Installed my old grounding kit. Fish Electronics | Audio | NAV | Infotainment 4 06-02-2012 11:14 AM
