Old 04-04-2013, 12:39 AM   #43
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Thickness = heat capacity. Thinner rotors will overheat quicker with abuse, ultimately ending in cracks or other failure.
If you read his posts, he says that it's the diameter of the wheels and tires is larger. My brother's WRX came stock with 215/45-17's, exactly the same as our car. Plus, his car weighs 500lb more than mine. Now, regardless of bias, how are the rotors going to crack any more severely or quickly on a 500 lb lighter car running exactly the same wheels? I just don't see it.
Would I run these? Not unless I did the calcs for the bias. But if the bias isn't shifted negatively, I don't see how there's any reason they should fail compared to using them on a WRX.
Cheers
Nathan
SubieNate is offline   Reply With Quote
Old 04-04-2013, 12:52 AM   #44
OrbitalEllipses
Drives: Attitude
Referring to Wilwood's post? It sounds like marketing bullshit. Tire compound has more to do with braking than tire diameter...
2013GTRNate (02-02-2015)
Old 04-04-2013, 01:05 AM   #45
SubieNate
SubieNate's Avatar
Yeah, that's what I was questioning.
Old 04-04-2013, 09:40 AM   #46
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
This has to be the most asinine thread I've ever seen. The FRS/BRZ uses the same brakes as the 08 WRX. So naturally a user purchases a wilwood kit for an 08 WRX. People lose their shit and a wilwood rep comes in here and specifically says they will fail if tracked.
This doesn't make any sense.
People are tracking their car with stock brakes and upgraded fluids and they aren't out right failing. How on earth could a wilwood kit be that shitty that it's only marginally better than stock?
Wilwood is just trying to scare everyone with a BRZ or FRS into buying "86" designed rotors and calipers. I bet most people, myself included, don't track their car hard enough for these to fail.
If you're that scared of the heat run brake ducts.
I'm just going to keep face palming.
post_break is offline   Reply With Quote
The Following 9 Users Say Thank You to post_break For This Useful Post:
andrew4554 (11-08-2020), Anthony (11-18-2014), DAEMANO (12-10-2014), diss7 (10-28-2013), mfbmike (10-30-2013), Scooby South (04-04-2013), SuperTom (06-08-2018), swift996 (04-04-2013), Wayno (05-26-2016)
Old 04-04-2013, 09:58 AM   #47
OrbitalEllipses
Drives: Attitude
Not the exact same setup as the 08 WRX, but this thread is full of generalities. Speaking to the "failure" ... yeah, we've identified that as marketing BS. No one's losing their shit.
Wilwoods probably fail because they're Wilwoods, lawl.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
2013GTRNate (02-02-2015), Sammakko (07-25-2015)
Old 04-04-2013, 10:01 AM   #48
CSG Mike
CSG Mike's Avatar
Yeah, we abuse em. Then again, they've been looking like this for a while now and are still working fine. We do take spare rotors just in case though, and this is arguably the most cost effective system available for the car
Most kits use a 28mm thick rotor, and 16mm pad. The Essex "Sprint" kit uses a 32mm thick rotor and 21mm pads.
Are there published specs for the Wilwood?
Old 04-04-2013, 10:28 AM   #49
OrbitalEllipses
Drives: Attitude
From the first post http://www.wilwood.com/BrakeKits/Bra...temno=140-9193
"Width (In.): 0.81" Thin rotors.
Old 04-04-2013, 11:38 AM   #50
CSG Mike
CSG Mike's Avatar
Sorry, still sleep deprived from yesterday's shoot.
20-21mm rotors... wow.
Old 04-04-2013, 11:52 AM   #51
OrbitalEllipses
Drives: Attitude
Yep, not even legal for SCCA autocrossing so I don't know why Bill even jumped into this thread.
Old 04-04-2013, 12:03 PM   #52
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Because they were mine to begin with.. and I couldn't use them and was following the progress with them since they make a decent upgrade over stock for not alot of money.. some of us are not Baller.. so Pricepoint and Function play a BIG part of Mods... Some of you guys are WOUND WAY to tight for sure..and you also realize the factory rotors are only 22mm, Right??? of course they aren't for continual Track use..
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
Old 04-04-2013, 12:10 PM   #53
OrbitalEllipses
Drives: Attitude
Bill
I saw your post when you got them and when you realized they were illegal; wasn't aware this was YOUR set.
Old 04-04-2013, 12:34 PM   #54
Scooby South
Conedancer
^^^ yep.. thats why the personal interest.....Trust me I had these researched LONG before I was able to purchase them.. just didn't realize the rotors were thinner than stock by 1.5 mm.. everything else would have worked according to the rules.
Bill
Old 04-04-2013, 05:22 PM   #55
swift996
swift996's Avatar
WRX Kit:
Type: Dynapro Radial Mount
Piston Count: 4
Piston Area (In²): 4.12
Piston Type: Aluminum
Mount Type: Radial
Brake Pad Area (In²): 6.36
Brake Pad Volume (In³): 3
BRZ/FRS Kit:
Type: Forged Narrow Superlite 6R
Piston Count: 6
Piston Area (In²): 4.04
Piston Type: Stainless
Mount Type: Radial
Brake Pad Area (In²): 8.2
Brake Pad Volume (In³): 3.8
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following 2 Users Say Thank You to swift996 For This Useful Post:
DAEMANO (12-10-2014), Scooby South (04-04-2013)
Old 04-04-2013, 05:30 PM   #56
OrbitalEllipses
Drives: Attitude
Looks like the 6pot moves bias even further rearward, with 12.88" rotors that are 1.1" thick.
Wilwood Big Brake Kit Installed msile Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 03-03-2014 02:00 PM
FS: WISC. BNIB Wilwood Front BBK Scooby South Brakes, Suspension, Chassis 4 03-10-2013 03:22 PM
Wilwood BBK Slartibartfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 01-08-2013 09:12 PM
help on Wilwood brakes brackets Turbo Den Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-01-2012 08:14 PM
