Old 04-02-2013, 11:48 PM   #57
kanundrum
Drives: 2013 Whiteout FR-S
Originally Posted by Blown_xa View Post
I was working hard on the PTUNING FRS today. Just waiting for coilovers to come in, so it will be autocross ready.
I might as well just not come any more
Old 04-03-2013, 12:15 PM   #58
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
Haha, we need you there. If we get the Ptuning FR-S ready in time for the autoX, it will be at the autoX for testing purposes and not to compete against anyone
MrC
Mrc@ptuning is offline   Reply With Quote
The Following User Says Thank You to Mrc@ptuning For This Useful Post:
kanundrum (04-03-2013)
Old 04-03-2013, 01:58 PM   #59
warman
warman's Avatar
Drives: WRB BRZ
Im sure if you have signed up, we will cut you a deal! On another note, I was working hard on the PTUNING FRS today. Just waiting for coilovers to come in, so it will be autocross ready.
Do these cars benefit from an alignment when they're stock? Or are they known for being far off from the factory?
warman is offline   Reply With Quote
Old 04-03-2013, 02:07 PM   #60
kanundrum
Most of the time factory alignment isnt the best/accurate how ever when you do an alignment from stock You can adjust camber toe etc.
That being said unless you have Lower Control arms for the car from a 3rd party, stock is non adjustable.
The front is adjustable up to a point.
Old 04-03-2013, 03:31 PM   #61
frostbitten
Drives: Whiteout Pearl Fr-S
Im from NC and saw the event. Just registered. so stoked on going to this event.
frostbitten is offline   Reply With Quote
The Following User Says Thank You to frostbitten For This Useful Post:
Sargy (04-03-2013)
Old 04-03-2013, 03:39 PM   #62
leon78
leon78's Avatar
Drives: 13 Whiteout
These are going in this weekend....b/c race car!
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 04-03-2013, 04:15 PM   #63
Blown_xa
Blown_xa's Avatar
Drives: xA
The factory alignment is fine for everyday driving, it is the best for even tire wear ( if just street driving).
However, the car will understeer and "wash out" when pushed hard. Even a stock FRS/BRZ could benefit from a more performance oriented alignment. All that is needed are front camber bolts, and custom alignment. More - camber would be a huge advantage, even on stock tires. We carry the bolts and can do a more aggressive alignment for you.
PTUNING ; Tuned for Competition
Blown_xa is offline   Reply With Quote
Old 04-03-2013, 04:29 PM   #64
warman
warman's Avatar
Drives: WRB BRZ
Camber bolts aren't allowed for stock classes at SCCA AutoX events though, correct?
Old 04-03-2013, 05:08 PM   #65
UncleFester
Correct.
UncleFester is offline   Reply With Quote
The Following User Says Thank You to UncleFester For This Useful Post:
warman (04-03-2013)
Old 04-03-2013, 05:09 PM   #66
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by UncleFester View Post
Signed up. Found an E85 station nearby, definitely going to need it.
PS - I get my E85 from the next closest station (maybe 10 min or so away from the one closest to the track) and it tests at 85-88% ethanol content.
The one near the track is owned by the same people, but i haven't tested to confirm that their ethanol content is as high.
Old 04-03-2013, 05:52 PM   #67
Mrc@ptuning
Drives: S1000RR
Correct.
Camber bolts are not allow without putting you into another class for SCCA. With NASA, I believe you are given an allowance of 24 points for mods in a stock BRZ/FRS (not sure if there's an automatic points deduction for a BRZ/FRS vs other stock vehicles) before you are bump up to the next class from your base class. I believe the point deduction for camber bolts is something like 2 points, which still leaves you with 22 points left over before you are bumped up to the next class.
If this is your first autoX, I would not worry about the points too much. Just focus on your driving and enjoy the events. But if you're going after the national championship then yeah, every point counts.
MrC
warman (04-03-2013)
Old 04-03-2013, 06:19 PM   #68
warman
warman's Avatar
Drives: WRB BRZ
Correct.
MrC
Thanks guys. It's been a few years but I've done a few autox's in the past. I doubt I'd ever attempt to compete in SCCA AutoX and I know how much of a difference an alignment made when I had my previous car (S2000), which had adjustments for camber from the factory, so it just seems silly that you can't do that to other cars without getting bumped to a higher class. I should probably just do it and forget about the stupid classes.
Old 04-03-2013, 08:00 PM   #69
Blown_xa
Blown_xa's Avatar
Drives: xA
Yea, I prefer NASA classification personally. It allows a lot of freedom, and variety.
Old 04-03-2013, 09:06 PM   #70
warman
warman's Avatar
Drives: WRB BRZ
Yeah it definitely seems more complicated, but it also encourages people to be creative.
PTUNING: 2013 Scion FR-S R&D Car Mrc@ptuning Member's Car Journals 67 04-18-2015 08:42 PM
Ptuning Spring Cleaning Meet March 23, 2013 Events@Ptuning Mid-Atlantic 58 05-09-2014 12:26 AM
Brakes unless at high speed - what to tackle? empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 10-12-2012 05:06 PM
Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) Levi BRZ Photos, Videos, Wallpapers, Gallery Forum 43 05-16-2012 12:37 AM
Casey Stoner high speed cornering at 1000fps tranzformer Off-Topic Lounge [WARNING: NO POLITICS] 6 08-01-2011 04:20 PM
