Old 04-03-2013, 02:34 PM   #1
df.dima
Drives: FR-S and Mazda 3 Sky
Starting car afte winter / disabling fuel injection
Hey guys,
I'm about to take my car out of storage tomorrow. What I've seen recommended in several guides online is to disable the fuel supply, so the engine gets oil pumped through it, but does not start.
Obviously I don't have the car to see, but could anyone tell where to look for to cut off fuel? I'm guessing fuse box under the hood? (EFI fuse, fuel pump fuse)? My old car had some fuses below the dash/steering wheel too (probably not there).
Sorry, I couldn't find anything relevant, service manual doesn't seem to have a diagram in it and my manual/papers are in the car. A hint would be appreciated. I just don't want to go in unprepared.
Thank you.
df.dima is offline   Reply With Quote
Old 04-03-2013, 03:50 PM   #2
Hardrock4445
Hardrock4445's Avatar
Not sure about this engine, but on most fuel injection systems if you hold throttle at 100% on start up it goes into clear flood mode and disables injectors. I could be wrong on this application. But I don't see why it would be different than other fuel injection systems.
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
The Following User Says Thank You to Hardrock4445 For This Useful Post:
SkullWorks (04-03-2013)
Old 04-03-2013, 03:52 PM   #3
SkullWorks
Drives: SSM LT MT BRZ
That would also be my suggestion. ^^^
Old 04-03-2013, 05:32 PM   #4
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
I've also been told to pull the plugs so there is no compression in the cylinders, this way there is almost no stress on the engine while you are getting the pump primed back up. I had a '67 Mini and after the engine build that is what we did, no fuel, no plugs, crank till you get pressure on the gauge, put everything back the way it belongs.
Cade01 is offline   Reply With Quote
Old 04-03-2013, 05:41 PM   #5
df.dima
Well, with this boxer engine I think pulling the plugs is something not everyone is looking forward to.
Old 04-03-2013, 05:44 PM   #6
Cade01
Cade01's Avatar
Just a suggestion, I've never done plugs on a boxer.
Old 04-04-2013, 09:41 AM   #7
Mikem53
Drives: FR-S 6MT
I would think the fuses would be labeled so you can pull the one you need..
IMO .. I believe you are over thinking this.. Storing your car for one season doesn't require any special precautions on startup.. Not with a modern engine in running order..
Mikem53 is offline   Reply With Quote
Old 04-04-2013, 09:47 AM   #8
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
I'm pretty sure the 100% throttle will disable the injectors.
Old 04-04-2013, 10:20 AM   #9
HunterGreene
Hail Magnet
HunterGreene's Avatar
Where was this stored? My car sat for 6 months in my garage, never got super cold, I trickle charged the battery once, hopped in it last week and it started right up like I had just parked it.
I understand the need to do this for older motors (will probably do something similar when we take our vette out of storage in a couple weeks), but if the car wasn't stored outside, my understanding is that its pretty much the same as leaving the car sitting for a couple days.
Old 04-04-2013, 10:33 AM   #10
df.dima
It was stored in a heated warehouse since mid November. I know new engines and oils are great, just wanted to take the precautions, its not like I'm going to spend tons of time on doing that.
I will try full throttle method and post back to confirm.
Thanks.
Old 04-04-2013, 10:37 AM   #11
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Pull the fuel pump relay. In the box under the hood.
I'm with some of the other guys sentiments. Just start it.
FRSFirestorm is offline   Reply With Quote
Old 04-04-2013, 11:32 AM   #12
DSoundman
Drives: Firestorm 6AT
I just took mine out of storage last week and did nothing special. Took the cover off, put the battery in, and started her up. Ran perfect! Driving it again reminded me why I pay so much a month for the thing... LOVE IT!
DSoundman is offline   Reply With Quote
Old 04-04-2013, 01:42 PM   #13
Subforever
Drives: SWP BRZ
Started the car last week after 5 months in storage. No problem either i just put the start button to the on position and waited like 30 sec to prime it then vroom without a problem.
During storage the car was on the battery tender and i put sta-bil fuel stabilizer.
Was so hard to wait that long but at least the car never seen a grain of salt !
Start it up and enjoy the season !
Subforever is offline   Reply With Quote
The Following User Says Thank You to Subforever For This Useful Post:
FR-S/GT-86 (04-05-2013)
Old 04-04-2013, 02:20 PM   #14
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Here is my suggestion: Do nothing but start the car normally. It hasn't been setting for long. Just make sure it has fresh fuel in the tank.
Disabling Compass & Auto Dim on Homelink ZC6BRZ Electronics | Audio | NAV | Infotainment 2 04-20-2014 03:34 PM
ever seen fuel injection like this? carbonBLUE Other Vehicles & General Automotive Discussions 1 10-17-2012 03:17 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained Moshpit37 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 06-26-2012 10:19 PM
Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained Moshpit37 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-21-2012 01:47 PM
