Old 04-02-2013, 06:38 PM   #113
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Originally Posted by Hanakuso View Post
Flexing when it's closed due to the hinges. These pictures are taken from the UK forum.
If you install it by taking it apart, i doubt it will do it. I think they left the two hinge side screws out. give me 5 mins and ill post up. mines been installed for weeks now.
supramkivtt2jz is offline   Reply With Quote
Old 04-02-2013, 06:41 PM   #114
Hanakuso
I think almost everyone on that board is having the same issue. The first picture I posted seems to be on the extreme side. If taking it apart fixes the problem, maybe someone should inform those guys.
Hanakuso is offline   Reply With Quote
Old 04-02-2013, 06:46 PM   #115
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
I'm saying take it apart to install like I mentioned in the first post
Old 04-02-2013, 06:49 PM   #116
Hanakuso
Awesome. Looks like the way to install would be to disassemble it then.
Actually not too sure about that. It seems this member did the same as you but still had flexing.
I've fitted mine today and I'm afraid to say that mine is exactly the same as lukester's.....should have read his thread before drilling mine as I was thinking this was how it was but couldn't understand why you would need them (i.e. why it states thing in the instructions)....plus....did any of you need to remove the padded arm rest to screw in 2 of the screws? There was no way of putting in the 2 screws by the hinge, weather the arm rest was up or down, so I've had to unscrew the padded part from the plastic frame.
Old 04-02-2013, 07:02 PM   #117
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
like i said, take it apart to install the hinge side screws
im glad they can correct this now. hopefully the plastic has not stresses too much and they can install them without permanent damage.
edit: ah, i understand your concern. ctp parts is replacing units that exhibit issues according to this thread:
http://www.gt86ownersclub.co.uk/foru...09_page31.html
Old 04-02-2013, 07:03 PM   #118
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
looks great but I don't see myself spending about $180 for this armrest
Old 04-02-2013, 07:18 PM   #119
Hanakuso
It seems at least the guy with the worse looking flex found a solution. If i'm understanding correctly, it's not a design flaw, it's just the way they were assembled was flawed.
Success
Took the pad off, pressure where the arrows are and bent it. There was a thud as something located properly...
(I was actually trying to bend it sufficiently to get the lid off the frame as the hinge pins wouldn't budge.)
Old 04-02-2013, 08:28 PM   #120
Calum
That Guy
Drives: 2013 asphalt FRS MT
Just ordered mine today, direct from CTP to Canada. The group buy wouldn't have saved me anything so I just waited a little for things to calm down and see some install pics.
Thanks @jpit for bringing this to our attention!!
Calum is online now   Reply With Quote
Old 04-03-2013, 08:15 AM   #121
Alabang 86
Alabang 86's Avatar
Drives: GT86
I want! PM sent
...my turn...
Alabang 86 is offline   Reply With Quote
Old 04-03-2013, 04:26 PM   #122
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
For those of you wanting black screws...
Take a trip to your nearest Lowe's or Home Depot and pay $6 for black Plasti Dip. Clean off the screws with water and rubbing alcohol, then dry. Take a small paint brush and spray a little of plasti dip onto the paint brush. Then paint over each screw carefully to not get too much plasti dip on the armrest itself. Let the coat dry for 20 minutes. Put about 3/4 more coats on with 20-30 minutes of dry time between each coat. Done.
husker741 is offline   Reply With Quote
Old 04-03-2013, 04:31 PM   #123
husker741
Wait, so he squeezed it a bit and things popped into place? Then all is good?
Old 04-03-2013, 05:47 PM   #124
Hanakuso
If I can find out the exact screw sizing, I will order black ones from McMaster Carr.
It seems so. I don't have the armrest yet but I hope it's not too hard to fix.
Old 04-03-2013, 07:07 PM   #125
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
You could take the nuts and bolts to an ace hardware to find the right thread pitch. Probably would be best with black Allen key bolts.
TouchMyHonda is offline   Reply With Quote
Old 04-03-2013, 07:40 PM   #126
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
Could you post a link to where you got it from, I'm in Canada as well.
aghuman is offline   Reply With Quote
armrest, jpit
Carsmo Armrest - Short review and quick pics Bleevin CANADA 3 09-27-2014 12:21 PM
new armrest Derrick Cosmetic Modification (Interior/Exterior/Lighting) 3 01-24-2014 10:48 PM
86 Armrest CzechZA AFRICA 30 02-05-2013 06:44 AM
armrest!!! whitefrs Cosmetic Modification (Interior/Exterior/Lighting) 10 09-07-2012 03:16 PM
