Old 04-02-2013, 12:21 AM   #197
sw20kosh
Drives: 2013 Black FR-S
I am personally waiting to see more data on the wastegated option. This looks very promising for my vehicle as it is daily driver 90% of the time and track avenger 10% of the time.
The waste gate (or bleed valve) will allow this scenario for example:
1. Install 15 psi pulley kit
2. Tune for 15 psi on 93-95 octane or 100 octane (whatever is in your budget)
3. Set the wastegate to hold 10 psi
4. Re-tune for 91 crap gas
5. For daily driving cruise around on 10 psi 91 octane tune
6. When at the track, add the appropriate amount of 100 octane, switch maps, and reset the wastegate to hold 15 psi. (You can do this by a boost controller or for the bleeder valve you can just adjust the screw)
Old 04-02-2013, 12:22 AM   #198
Dezoris
Dezoris's Avatar
Originally Posted by Huehuecoyotl View Post
Are we talking tires? Heck when I go wheeling with my truck in snow I'm down to 8psi
I think someone is a bit confused..we're talking boost
I was just used my 4/1 token to be an idiot. Actually thats everyday.
Originally Posted by tha7osavage View Post
this has probably been answered countless times, but what is the optimal setup for the vortech blower if i were strictly using my car as a daily driver. is it as easy as install + tune?
Yes if you choose a Vortech kit direct it comes with their tune. Install parts and flash.
If you choose a tuner kit, same deal install parts and load their flash. And then do follow up data logging using your laptop, supplied software and email the tuner your data log and they will adjust the tune if needed.
Or you can choose a tuner kit, get the Ecutech gear needed to tune and work with someone to make their own flash. (Lot more work)
Old 04-02-2013, 12:42 PM   #199
tha7osavage
Thanks for the feedback fellas.
Makes sense. I used to have a wrx so I was used to already having the turbo, and dealing with all of the maintenence. I guess what i'm really asking is, will I be able to drive my car with the vortech setup without having to worry about any serious issues down the road? granted that I don't abuse the car. I've seen a lot of people upgrade their pulley with the vortech install, but should I be worried about the clutch or anything else?
tha7osavage is offline   Reply With Quote
Old 04-02-2013, 12:44 PM   #200
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
sit tight...
Huehuecoyotl is offline   Reply With Quote
Old 04-02-2013, 01:31 PM   #201
sw20kosh
Would like to see a comment on this from vortech for us track junkies:
Tuner Kits and Supercharger Options
Tuner kits are the same as complete systems except without the fuel system upgrades or ECM reprogramming. This allows for custom tuning and fuel modifications that the custom tuner or racer may prefer. Vortech has supercharger options for various types of racing or boost level. For continued use, such as road racing, the V-2 series superchargers share the engine's oiling system. This approach is more suitable for continued boost conditions and allows for the addition of an oil cooler or filter. Call the Vortech Tech Line for complete information on the many upgrades and options available.
Source: http://www.vortechsuperchargers.com/page.php?id=30120
Would a V2 unit bolt in to the existing kit or would we have to wait till you produced a V2 kit?
Old 04-02-2013, 02:23 PM   #202
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
this has probably been answered countless times, but what is the optimal setup for the Vortech blower if i were strictly using my car as a daily driver. is it as easy as install + tune?
Sure, or just buy the complete system that includes our production tune. Both are viable options.
Depends on the output level you set it at, but if we are talking the 9psi out-of-the-box setup with our production tune or another safe tune, you should be good to go without any issues whatsoever.
This statement is geared more towards repeated, competition level track use, and not the weekend, open track club racer. The V-3 is well suited for street and casual track use. For those considering competition level applications, contact our sales department and we should be able to guide you in the right direction to get you dialed in properly.
Brian@Vortech is offline   Reply With Quote
Old 04-02-2013, 02:49 PM   #203
tha7osavage
Good to know! this makes my decision for boosting options much easier
The Following User Says Thank You to tha7osavage For This Useful Post:
Brian@Vortech (04-02-2013)
Old 04-04-2013, 12:13 PM   #204
2forme
I have an interesting question, for those who swapped from the old design to new, is a retune necessary? If not, is it safe to drive on the old tune until a retune is able to be had?
Old 04-04-2013, 12:55 PM   #205
Brian@Vortech
Chances are that an updated tune is necessary, but in working with Perrin and Visconti on the upgrade, they both had the product in hand ahead of time. Therefore, upgrade tunes were already available on the day of release.
The Following User Says Thank You to Brian@Vortech For This Useful Post:
2forme (04-04-2013)
Old 04-04-2013, 03:47 PM   #206
ft_sjo
Drives: GT86
Originally Posted by ft_sjo View Post
@Brian@Vortech
Were there design issues which prohibited the retention of the OE washer fluid bottle? Lots of other FI conversions seem to retain it with some more creative pipework.
I for one value the large capacity of the OE resevoir and would prefer not to lose it.
Are there any intentions from Vortech to improve this situation?
Thanks
Bump @Brian@Vortech
Old 04-04-2013, 04:25 PM   #207
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
You don't lose the washer reservoir, its relocated and the filler neck is slightly modified.
Page 20 of the install document:
http://www.vortechsuperchargers.com/...20-010v1.0.pdf
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 04-04-2013, 04:46 PM   #208
ft_sjo
Drives: GT86
I'd try reading what you just referred me too.
Old 04-04-2013, 04:52 PM   #209
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Ahhh, sorry. You want to use the stock reservoir. I thought you were under the impression you lost the reservoir entirely.
Parting out HERE
Old 04-05-2013, 12:06 PM   #210
Brian@Vortech
@Brian@Vortech
Thanks
Can't imagine what you'd need that insanely large reservoir for...I've seen apartments smaller than that thing!
An optimized air pathway in our system required the factory reservoir to be removed. When people started requesting a replacement reservoir, we went the extra mile and designed and included a replacement bottle arrangement (and we didn't even raise the price!).
Pete (04-06-2013)
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
