Old 03-29-2013, 02:14 PM   #29
sweeney208
sweeney208's Avatar
Drives: red subaru brz limited
Originally Posted by jwjknorr View Post
the two bolts that hold the bracket yet. not the lower bolt on the exhaust pipe
i took out the bolt that holds the exhaust to the bracket and gave it a little wiggle to get it off, didnt cause any harm. To each his own i guess.
sweeney208 is offline   Reply With Quote
The Following User Says Thank You to sweeney208 For This Useful Post:
swift996 (03-29-2013)
Old 03-29-2013, 02:30 PM   #30
jwjknorr
Drives: FRS 2013
Both ways will work but i had a issue with mine lifting it off the lip after unbolted. So i just took the whole bracket down , it was only 2 easy to get to bolts. Probably different clearing issues with different exhausts used.
jwjknorr is offline   Reply With Quote
Old 03-29-2013, 03:12 PM   #31
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Great write up as always. The How-To will be spotless as well I bet. Thanks!
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
F1point4 (04-02-2013)
Old 03-31-2013, 07:30 PM   #32
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Okay here's the story:
+Vortech has offered free upgrades for existing 86 Supercharged customers.
+I opted to return my car back to NA rather than rent a car. That was a great learning experience.
+I flashed a stock tune which I recieved from FA20Club.com when I was NA tuned by them.
Today I got a check engine light for no cat. I'm not worried. If you aren't tuned this will happen. I have cleared the code and it hasn't come back yet.
If it comes back before I put the supercharger back on I'll let everyone know.
F1point4 is offline   Reply With Quote
Old 03-31-2013, 10:44 PM   #33
F1point4
Photo Specialist
F1point4's Avatar
Some info, some old, some new.
The Borla header weighs 11lbs and some change on the Phastek scale
20130323-BorlaUELHeaderInfo-001 by VictorN07, on Flickr
The OEM header/exhaust manifold with its full clad is almost 21.5 lbs.
20130323-BorlaUELHeaderInfo-002 by VictorN07, on Flickr
Here are the two headers side by side. The large bulge in the lower left of the OEM Exhaust manifold is the stock catalytic converter. I will take apart all the heat shielding and shoot some pics inside the cat to show everyone how bloody restrictive it is
20130323-BorlaUELHeaderInfo-003 by VictorN07, on Flickr
Some goodies. Subaru Exhaust Manifold gaskets (top left), graphite gasket I had when I did my Perrin headerback (top right), Subaru exhaust crush gasket (bottom). The exhaust manifold gasket had two part numbers, I believe the top one is the new number. It is really a beefy part. about 2 mm thick.
20130323-BorlaUELHeaderInfo-004 by VictorN07, on Flickr
The Following User Says Thank You to F1point4 For This Useful Post:
ProjectD (03-31-2013)
Old 04-01-2013, 08:32 AM   #34
sweeney208
sweeney208's Avatar
nice, did you need the gaskets? or just playing it safe. When i took mine off, only the crunch gasket was kinda bad but still pretty good. Probably better to just swap them while its easy. They're like 15 a piece right?
Old 04-01-2013, 08:48 AM   #35
infinite012
Drives: 13 DGM BRZ Ltd
You could probably get an O2 sensor "chip" (for lack of a better word). There were a few people running them on the GD chassis WRXs to fool the ECU into thinking their aftermarket catless uppipe (because the stock uppipe had a cat and had a tendency to get sucked into the turbo/engine) had a catalytic converter and was working within spec.
infinite012 is offline   Reply With Quote
Old 04-01-2013, 10:37 AM   #36
F1point4
Photo Specialist
F1point4's Avatar
I played it safe. The stock gaskets looked okay. They are 8 USD a pop in my region. I replaced the overpipe/manifold gasket with a graphite gasket instead of a metal crush gasket. Hope that was a wise move.
Thanks. When i put the supercharger back on the tune has the P0420 code disabled so I wont' see any CELs for this.
Old 04-01-2013, 10:51 AM   #37
sweeney208
sweeney208's Avatar
damn.. good ol texas huh? im in CT and they were 16 a pop for the OEM gaskets..
Old 04-01-2013, 10:51 AM   #38
infinite012
I think I saw the O2 sensor fooler back in my e46fanatics days, as well. Way back when I had a 330xi.
Old 04-01-2013, 11:54 AM   #39
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
@F1point4 , any ETA on the DIY? I'm installing mine this weekend and would love to review your DIY before hand. I read over the included instructions from Borla but I know your pictures will be 100x better.
Old 04-01-2013, 12:29 PM   #40
F1point4
Photo Specialist
F1point4's Avatar
I have the pictures in Lightroom right now. I want to clean them up and put the instructions on them tonight, and hopefully upload them tonight or tomorrow. Late night work conference calls with Thailand keep me from spending more time on this and other stuff
ATL BRZ (04-01-2013)
Old 04-01-2013, 11:06 PM   #41
F1point4
Photo Specialist
F1point4's Avatar
DIY is live. and I got another CEL!
20130323-BorlaUELHeaderDIY-001 by VictorN07, on Flickr
The Following 2 Users Say Thank You to F1point4 For This Useful Post:
mxsled (04-01-2013), swift996 (04-02-2013)
Old 04-01-2013, 11:20 PM   #42
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
That one guy in the Borla hat looks like he's going bald.
Other than that, another good post! Thanks for your contribution.
Sent from my SCH-I605 using Tapatalk 2
PhastekSport is offline   Reply With Quote
The Following 2 Users Say Thank You to PhastekSport For This Useful Post:
F1point4 (04-01-2013), norsamerican (04-03-2013)
borla, header, unequal length
Borla UEL Header - Pics / Videos / Dynos - FT-86 SpeedFactory Review FT-86 SpeedFactory Engine, Exhaust, Transmission 533 04-01-2015 12:10 AM
>>>>Rev Works UEL (Unequal Length) Header - Specs, information, & Customer Review<<<< Rev Works Engine, Exhaust, Bolt-Ons 917 08-04-2014 11:52 PM
BORLA UNEQUAL LENGTH HEADER NOW IN STOCK @ NINJA AUTOSPORTS!!! NJA Announcements, Contests, Giveaways 6 04-03-2013 05:47 PM
unequal length headers 001BRZ Engine, Exhaust, Transmission 10 07-21-2012 01:20 AM
