Old 03-29-2013, 01:42 PM   #15
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Maybe you been workin out at the gym?
Benching over 250lbs will do this too!
Slow down on them vitamins?
Protein shakes?
Just having fun with it, dont mind!
Huehuecoyotl is offline   Reply With Quote
Old 03-29-2013, 01:57 PM   #16
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Originally Posted by Huehuecoyotl View Post
tire pressure check time
Double this.
Chewie4299 is offline   Reply With Quote
Old 03-29-2013, 04:34 PM   #17
FRiSson
Drives: FR-S MT
Sometimes a bad alignment can make the steering feel very off. Or possibly a tire that has become asymmetrical or with a slipped belt. Rule those out first.
FRiSson is offline   Reply With Quote
Old 03-29-2013, 04:47 PM   #18
wbradley
Sarcastic SOB
wbradley's Avatar
You lift?
Old 03-29-2013, 04:49 PM   #19
OrbitalEllipses
Drives: Attitude
Originally Posted by scottrichardson View Post
Hi all,
I couldn't find a specific forum for 'steering', so figured this would be the ideal place.
I have only had my 86 GTS manual for 4 weeks and have only done 1250 km on her, but as of about 3-4 days ago, my steering started to feel a bit different.
It's hard for me to explain, but the best description is light, lazy, and vague.
When I first got it, the steering was tight, responsive, and reactive. I felt connected to the road and could feel the car pull and had lots of feedback.
But now, it feels light.. I feel less feedback from the road - very little at all. I feel that I have to turn the wheel more than I should - almost like the power steering is on, but not assisting.
It is certainly worse at low speed than it is going faster, but even then there's little feedback or resistance when cornering and I still feel like the car isn't responding. At high speed I feel like there's a delay in the car responding to my turns.
I have checked tyre pressure and it's all fine.
I am stumped honestly. My local dealer took a quick ride and says it felt normal, but i KNOW it's nothing like what it was like when I got the car. A perfect indication something is wrong: I couldn't stop finding reasons to get out and drive the thing, and now I am finding excuses not to drive it
Overall the steering feels sloppy, light, and slippery and not tight, resistive and responsive.
Any ideas on what might cause this type of thing?
I understand it is electronic power steering?
Scott
Have you flushed the power steering fluid?
Old 03-29-2013, 04:57 PM   #20
schlomo
Drives: mazda3, 370z
Did you hit any curbs lately? Even lightly brush any curbs?
schlomo is offline   Reply With Quote
Old 03-29-2013, 06:49 PM   #21
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Linseal (04-01-2013), OrbitalEllipses (03-29-2013)
Old 03-30-2013, 12:09 AM   #22
Ozzman
Drives: old
Have the dealer do an alignment, more than likely for some reason you have too much negative toe on the front end causing the car to wander/feel vague.
It is possible that after the suspension bushings, springs, and spring seats settled in the angles changed a little. You would be surprised at how much of a difference the alignment can have on how a car feels and how it interacts with the roadway.
Ozzman is offline   Reply With Quote
Old 03-30-2013, 12:50 AM   #23
Krimlin
Because Racecar
Krimlin's Avatar
Drives: 2013 Toyota 86
Also the 86's features of the VSC Sport mode affects steering, if you're driving with the VSC mode on for a few days then turn it off the steering will feel different.
95' Nissan 240sx Race Car - DEAD
01' Lexus IS300 VIP machine - SOLD
13' Toyota 86 Hotness - Under Construction
Krimlin is offline   Reply With Quote
Old 03-30-2013, 01:46 AM   #24
scottrichardson
Drives: Toyota 86 GTS White
Ahaha thanks for the great (and funny) replies guys. Yes, I DO lift, and 250lbs is no probs on bench press LOL, but I'm not that much of a unit (I'm a track 100m sprinter actually lol).
Tyre pressure checked in at 240-250kPa while warm on all 4 tyres.
Ozzman, thank you for the info. That tends to make a lot of sense honestly.
And LOL - I DO realise that YES I might just be getting used to the car - but a sign that it's different is that today, yesterday and the day before, I have had to hard lock the wheel all the way to the right or left when exiting shopping mall car parks etc.. Something I'd not had to do a single time until 4 days ago... lots of travel in the turning for little actual steer affect.
And LOL at the power steering fluid comment. I looked but couldn't find where to top it up :P
Toyota 86 GTS Pegusus White
scottrichardson is offline   Reply With Quote
Old 03-30-2013, 01:55 AM   #25
Carbon420
Drives: 2013 FR-S Raven with carbon fiber
Just did 1000k run from Calgary to Jasper and back and my stealings still tight as a virgin.
Carbon420 is offline   Reply With Quote
Old 03-30-2013, 02:07 AM   #26
LeftFootBrake
LeftFootBrake's Avatar
Drives: White 86 GTS AT
Source, please.
LeftFootBrake is offline   Reply With Quote
The Following 2 Users Say Thank You to LeftFootBrake For This Useful Post:
russv (03-30-2013), strat61caster (03-31-2013)
Old 03-30-2013, 02:08 AM   #27
scottrichardson
I took mine on about 140km drive today... at higher speeds the problem isn't as bad, but to me there is a slight delay before the car responds to my steer. ie: if I'm doing 100 on the highway and give it a little nudge to either side, there's a small delay before it actually nudges the steer.
Old 03-30-2013, 03:27 AM   #28
86X86
86X86's Avatar
Drives: '13 GBS BRZ Ltd (MT)
...as in, cow-tipping?
86X86 is offline   Reply With Quote
The Following User Says Thank You to 86X86 For This Useful Post:
russv (03-30-2013)
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
light steering angle improvement alexmotrix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 03-17-2013 02:38 AM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
This is what happen you get lazy 4agze Other Vehicles & General Automotive Discussions 9 09-05-2011 08:34 PM
