Old 03-29-2013, 11:28 AM   #113
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by jdzumwalt View Post
The kits are very complete and with a little patience it's pretty easy. Pulling a trans is way harder. If you can read you can do this period.
Bolting on the Bullet unit looks way more complex you have to remove the whole intake manifold.
It really isn't that difficult to remove the intake manifold. I removed mine in about 30 minutes with the help of a buddy. We left the fuel rails/injectors installed on it and instead disconnected the fuel lines as that is what the factory service manual says to do.
Old 03-29-2013, 12:12 PM   #114
Saab2Frs
Drives: 2013 Hot Lava Scion FRS
Little late to this thread, but that Innovate kit sure looks nice, but they have an intercooled and nonintercooled version? I figured all FI systems would be intercooled because of the heat caused by the TC/SC.
Saab2Frs is offline   Reply With Quote
Old 03-29-2013, 12:17 PM   #115
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
Saab The intial kit is internally intercooled but you can upgrade and go front mount with a different kit. Rumor is...
Old 03-29-2013, 12:19 PM   #116
Saab2Frs
Thanks. Not thinking about FI until many years from now, but it's good to know what's out there.
Old 03-29-2013, 12:21 PM   #117
sw20kosh
Drives: 2013 Black FR-S
Not the case.
The base kit is non-intercooled. The upgraded kit is intercooled. You can upgrade the base kit later on with ease.
When upgraded, the intercooler is inside the intake manifold right below the supercharger unit.
Old 03-29-2013, 12:35 PM   #118
NJA
Drives: Supercharged Saturn ION
Originally Posted by Huehuecoyotl View Post
I heartily disagree with this above statement
my Centri feels like a big NA motor, linear power
PD will feel very different than NA, more like TC, non linear power
the charts say it, dont believe me!
I would say there is something else going on with that chart
This type of blower definitely should feel like an N/A car. I DD a car with a roots blower and the power delivery is very linear.
Most blowers like this have a very flat torque curve so not sure what's going on there.
NJA is offline   Reply With Quote
The Following User Says Thank You to NJA For This Useful Post:
sw20kosh (03-29-2013)
Old 03-29-2013, 12:36 PM   #119
sw20kosh
the bigger of the two screws have reached its limit-each screw has a much narrower bands of use, again see TQ chart from japan, you can see each screw's 'sweet spot'.
Just want to let everyone know this is pulled out of the clouds.
Gem, where do you get your information from? Or do you just like making things up lol?
The two screws work together as meshing lobes. One screw doesn't work better than the other. They work together to pressurize air. One screw cannot exist without the other.
One screw looks bigger than the other because of the way its lobes are shaped compared to the other one.
I think you are somehow confusing twin screw with sequential twin turbos that were in the RX-7 and Supra Turbo.
Here is the Rx-7's graph. You can clearly see where the first turbo runs out of steam at which point the 2nd turbo is brought online.
Supra stock twin turbo:
There is nothing similar between a twin turbo system and a twin screw. Other than the word twin.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
Huehuecoyotl (03-29-2013), JoeBoxer (03-29-2013)
Old 03-29-2013, 12:40 PM   #120
sw20kosh
Agreed. Let's wait and see what more tuning can accomplish. If you look at these numbers I see no fall off in torque in the top two tables:
Can anyone explain why the bottom table has a fall off in torque? Maybe that is the non-intercooled version? Heat in the higher rpm range could cause torque drop off. Just a thought.
Old 03-29-2013, 12:53 PM   #121
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I know that our throttle body is quite large stock but i would be interested to see if a larger throttle body, new map sensor, and header/full exhaust would effect it.
Old 03-29-2013, 12:58 PM   #122
King Tut
NASA SpecE30 Racer
King Tut's Avatar
The Innovate kit should be just about ready for you in a couple years.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
akuhei (03-29-2013), swift996 (03-29-2013)
Old 03-29-2013, 01:16 PM   #123
RT87
Not if they deliver this time. Lulz.
RT87 is offline   Reply With Quote
Old 03-29-2013, 01:19 PM   #124
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Monday is april fools day
Huehuecoyotl is offline   Reply With Quote
Old 03-29-2013, 01:20 PM   #125
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
If only this hadn't been said before....
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 03-29-2013, 01:23 PM   #126
swift996
swift996's Avatar
They "already" had dyno numbers, pictures, videos last month but remember they were just finishing up durability testing. So it seems like they ran into a snag in their durability testing that would prevent them from wanting to release any of those things...
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Our Silver Bullet - FT-86 SpeedFactory FT-86 SpeedFactory Member's Car Journals 151 10-06-2016 11:57 PM
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 10:25 PM
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 06:11 AM
Bullet Performance supercharger by Mercury Performance mastertech86 Forced Induction 219 10-24-2012 06:01 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 01:39 AM
