| DIY (Do-It-Yourself) Guides For all DIYs. |
#1 | |||
Rugger Extraordinaire
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
DIY Warning - Removing the Crank Pulley
This warning has to do with installer error and has no bearing on the quality of any pulleys.
ALWAYS CHECK YOUR WORK BEFORE TEST DRIVING. Here, @Gopherboy6956 explains the process and the problems, in detail. I'd like to give a huge shoutout to him for great pictures, and even a video! Quote:
| The Following 28 Users Say Thank You to thejevans For This Useful Post: | Black Tire (05-05-2013), BLACK->BULLET (06-02-2015), brybot (01-02-2017), Caspian (08-31-2015), CBR600RR (04-02-2013), Choco (01-21-2015), ChrisD (01-27-2016), Dadhawk (02-14-2013), ddevl_86 (03-30-2021), echo419 (12-09-2014), Efferalgan (08-30-2013), finch1750 (09-23-2013), GhostOp86 (04-13-2015), Gixxersixxerman (01-14-2013), hyper4mance (04-02-2013), Jesse (04-01-2013), JPxM0Dz (03-26-2013), kykiee (02-14-2013), LeeMaster (02-27-2013), Mike86 (08-30-2013), MJones_RB (01-18-2021), ProjectD (01-15-2013), so26 (01-14-2013), tbwoodlee (01-15-2013), TRD_07 (04-02-2013), Tristor (08-26-2018), whataboutbob (01-14-2013), Wolfking (09-18-2013) |
#2 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
This should be stickied with all the recent threads that are having issues
#3 |
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
This should get a bump and stickied
#4 |
Site Moderator
Drives: ichi 86 Project
& it is sticky now
#5 |
Drives: 13 BRZ Limited WRB
I ran into this issue when installing mine this weekend. The Oring came off with the old pulley. I tried to place it back in, but it was ever so slightly bigger than the area for it. So, i ordered a new one for about $2.
Found here: http://wardmuscatellsubaruparts.com/...iagram=7610205
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
| The Following User Says Thank You to Gopherboy6956 For This Useful Post: | microbionic (03-26-2013) |
#6 |
So I put my pulley on yesterday on my replacement frs so this is my second install. When taking the bolt out I actually got some oil that came out that I don't remember having the first time around. This sleeve stayed in as far as I can tell. Now you got me worried. I need to double check. Anyone have a pic of how fush the stock one sits in the block? Is it just pressed in?
Sent from my SCH-I535 using Tapatalk 2 |
#7 |
A picture of the backside of that little nugget might be helpful......so people know what the key-way mate up would be.
#8 | |
1994 Plymouth Acclaim - Engine died and went to cash for clunkers
2001 Dodge Neon R/T- Hydro-locked engine and parted out 2003 Nissan Sentra SE-R Spec-V - Traded for next car 2013 Scion FR-S - Got taken out by a distracted driver while I was sleeping. Total loss. 1997 Mazda Miata - Current |
#9 | |
When first took off the stock pulley, the end of the crank stayed in, but then when I took it apart a second time (because i forgot the oring, that end piece came out. Pretty easy to slide it back in, and yes, there will be a little oil, that's normal. It won't gush out or anything.
#10 |
So - check this - I just took off my pulley today, armed with my new O-Ring. Of course, the crankshaft pulley spacer (as it's actually called) came out. I sat there for what felt like forever trying to get it back in. I eventually gave up when the cold got me (~15f).
Now, what I think may be complicating this is there is really TWO parts of this that come into play here... One is that stupid key, and the second is a moveable ring on the inside of the crank tunnel. See photos - In this image, you can clearly see the key on the end of the crankshaft. (red arrow) The Yellow call-outs and arrows point to the two side keys, WHICH are on a ring that rotates freely. So, you need to have both those items lined up to get it back in. ![]() This is the backside of the crankshaft pulley spacer ![]() So, If you only get it seated with the outside ring, it won't slide in flush as seen in this DIY: ![]() Also - take note, as Perrin says if you don't get it flush in there, the pulley will wobble. When i put it back in this time after changing the o-ring, I did not have it flush and it did wobble for a few seconds. Now, I'm not sure if this is going to be an issue for me yet, but it seems it could be easy to damage the spacer and/or crankshaft key. This is what my spacer currently looks like which has me a bit concerned: It looks like a bit was sheared off when the engine started and the pulley was wobbling. And a closer look at my crankshaft might show a little damage too ![]() This makes me a bit nervous - but I'm going to order a new spacer and maybe play with it some more before I do anything drastic. So - Let this be a strong warning to all - MAKE SURE YOU GET THE SPACER FLUSH before you start the engine. I'd like to do a quick callout to @thejevans and @PERRIN and see what they think, and specifically to thejevans - how did you get it realigned?
#11 |
OK!
6 hours, a sore back, lots of curse words, loss of hope, and a 15F degree garage, I got it! I was so frustrated, and actually just gave up. I was going to get the BRZ towed to the dealership tomorrow and bite the bullet. I figured they may take pity on me, so I went about putting both the intake and pulley back to stock. I took the stock pulley, put the new o-ring in place, attached it to the Crankshaft pulley spacer, lined it up as close as I possibly could to where I knew the key was (I used a mirror and light to better see inside) and gave her hell. Just as with the Perrin Pulley, it went in, but not all the way. So, i decided i'd bolt it down anyways, got it to 94ft/lbs, and started to put the stock intake back on. After that, i gave it one more cautious start, and to my *fucking* surprise, it ran WITH NO WOBBLE, absolutely perfect. So, I cursed with joy and sorrow for time spent, and decided to take one more shot at the Perrin pulley, now that I knew the spacer was seated correctly. Here is the part, that should be included in the DIY to keep that spacer seated: When removing the stock pulley, wedge a socket extension (or two) into the bolt hole to keep pressure on the spacer in place. It would be much easier with a friend, but it's possible to keep pressure on the socket extension and pull off the stock pulley at the same time. I can take a shot of this just to make it easy to see tomorrow. Here are two photos of how I used the socket to keep the spacer in - The bolt is obviously in place, I just wanted to show how I used the socket extension. ![]() ![]() Here is my spacer completely in place. ![]() ![]() And a reminder of when it is NOT in place: ![]() Also, here is a quick clip of my Perrin Pulley after this project: Hope this info helps someone.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 Last edited by Gopherboy6956; 04-02-2013 at 10:02 AM. |
| The Following 9 Users Say Thank You to Gopherboy6956 For This Useful Post: | Black Tire (05-05-2013), brybot (01-02-2017), ExquisiteStance (07-22-2014), fstlane (09-01-2013), GhostOp86 (04-13-2015), MJones_RB (11-16-2016), Mr. (04-22-2013), thejevans (04-02-2013), Yruyur (04-02-2013) |
#12 |
Fantastic. Thank you
#13 | |
Thank you so much for your pictures and information. I'm glad you got it back in. I'm going to update the first post with quotes from yours.
#14 | |
| Perrin Crank Pulley now available | milenko11 | Engine, Exhaust, Transmission | 96 | 12-10-2017 06:45 PM |
| Kartboy crank pulley | Turn in Concepts | Engine, Exhaust, Bolt-Ons | 5 | 05-22-2013 10:51 AM |
| NEOPLOT Crank pulley Alternator pulley& Waterpump pulley | ANREX | Engine, Exhaust, Transmission | 10 | 10-25-2012 07:45 PM |
| Crank Pulley and the warranty | Brimford | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-08-2012 03:47 PM |
