Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > ASIA
Old 03-22-2013, 01:48 PM   #589
pauland
pauland's Avatar
Drives: Subaru BRZ
Yeah, those are really nice!!!
Originally Posted by HRTROB View Post
Congrats Carlo_BIG! Dumadami na tayong naka Red
pauland,
Those are Rays 57Xtreme. Ganyan rin ilakabit ko na mags
pauland is offline   Reply With Quote
Old 03-22-2013, 09:26 PM   #590
Margovincent_22x
Margovincent_22x's Avatar
Drives: Lightning Red BRZ MT Limited
Originally Posted by pauland View Post
Sirs, tanong ko lang, anong wheels ito?
alam ko rays... baka g12 or 57exteme
Margovincent_22x is offline   Reply With Quote
Old 03-22-2013, 10:13 PM   #591
HSY86
HSY86's Avatar
Drives: Satin White Pearl 86 MT
Originally Posted by phenoyz View Post
mga sir pasyensya na off-topic kailangan ko kasi ng suggestion:
(eto yung tanong ko sa isang car forum)
__________________________________________________ _________
at 80mph i didnt notice any vibration, but at 100mph i notice a slight vibration which i thought was the wheels.
The steering wheel is fine....
i just had the wheels balanced and rotated.
my car has 40,000 miles already, is an alignment needed?
(car DOES NOT veer to the right or to the left)
what could cause that vibration at 100mph?
what can be done to correct it?
my suspension is stock, i have a 15x7 aftermarket wheels
the vibration IS NOT STRONG, i would say a "SLIGHT vibration"
there is NO sound or anything underneath
is that NORMAL when you hit 100mph?
__________________________________________________ __________
15x7 wheels
tires are 195/55
ano kaya ang cause ng vibration?
hinde naman siguro kailangan ng hubcentric rings?
salamat
I think the answer to your question is what you have done lately on your car Sir. I read that you just had it balanced and rotated.
The easiest way is to have the wheels re-balanced in a more competent/trusted tire service center. Usually mali/hindi pulido or nag-mamadali ng pag-babalance ang cause ng steering wheel wiggle ng 80-100kph.
Personally, I experienced it here sa Manila. When we bought new set of wheels/tires for our other car and had it balanced sa shop(won't name the shop) where I bought the items, then when I ran the car sa NLEX it was wiggling like crazy at high speeds. My friends suggested to have it re-balanced. So I went to Tireboy(even though it's much more expensive to them balance it), tested it again at high speeds. Nawala na yung wiggling! HTH Sir
HSY86 is offline   Reply With Quote
The Following User Says Thank You to HSY86 For This Useful Post:
phenoyz (03-23-2013)
Old 03-22-2013, 10:15 PM   #592
HSY86
HSY86's Avatar
Originally Posted by Carlo_BIG View Post
Mga bossing! Mabuhay!
I just took delivery of my Toyota 86 MT in Lightning Red
I also just finished backreading through the whole 27 page thread :p - good to see a strong Filipino presence in FT86club!
Welcome aboard Carlo_BIG! Nice shot!
Old 03-23-2013, 06:20 AM   #593
pauland
pauland's Avatar
Drives: Subaru BRZ
15x7 wheels
tires are 195/55
salamat
Sir, i would assume that the car you're pertaining to is based there in Las Vegas since you've used MPH. But if it is based here sa Pinas, I would agree with sir HSY86. Bring it to a reputable tire alignment/balancing shop. Most tire shops here in manila will offer free balancing when you purchase new tires/rims with them. I usually decline the offer because of some bad experiences. I just go to my trusted shop for the balancing afterwards. I wont mind spending extra basta sigurado yung gawa. Big tire balancing/alignment shops (like Goodyear Servitek) would usually give you a warranty for their service. Check with your shop if you're still under warranty. They should rebalance it with no charge.
That is where i would start. Hopefully dun lang din ang problem. Good luck sir!
The Following User Says Thank You to pauland For This Useful Post:
Old 03-23-2013, 06:50 AM   #594
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
Kanino toh mga pare? Nakita ko lng s isang page.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 03-23-2013, 10:52 AM   #595
jdmasfcuk
jdmasfcuk's Avatar
Drives: Toyota 86 ZN6
some pics from todays touge run..
Honda fans.. anyone?
jdmasfcuk is offline   Reply With Quote
The Following User Says Thank You to jdmasfcuk For This Useful Post:
lonelydriverZN6 (03-23-2013)
Old 03-23-2013, 02:31 PM   #596
Carlo_BIG
Carlo_BIG's Avatar
Drives: 2013 Toyota 86 M/T (Lightning Red)
panira ang card board sa ilalim. hehe thank you!
Carlo_BIG is offline   Reply With Quote
Old 03-24-2013, 09:24 AM   #597
Jerome22086
Drives: M/T, Galaxy Blue
I had it serviced yesterday at Toyota Batangas. Total cost for the 1st PMS was 3,122.55.
Replaced Engine Oil (they used 5W-30)
Replaced Engine Oil Filter
Inspected Air Filter
Inspected Brake Pads & Discs
Inspected Steering Wheel, Linkage & Gearbox
Inspected Ball Joints & Dust Covers
Inspected Front & Rear Suspension
Tightened Bolts & Nuts on Chassis and Body
Inspected Tires and Inflation Pressure
Inspected Lights, Horns, Wipers & Washer
Jerome22086 is offline   Reply With Quote
The Following 2 Users Say Thank You to Jerome22086 For This Useful Post:
jdmasfcuk (03-24-2013), lonelydriverZN6 (03-26-2013)
Old 03-24-2013, 11:24 AM   #598
TOY 86
TOY 86's Avatar
Drives: GT 86
Hi guys! alam nyo ba kung san makakuha ng ow-20 na engine oil dito samin sa iloilo wala akong mahanap ang replacement na ginamit ng toyota is 5w-30
TOY 86 is offline   Reply With Quote
Old 03-24-2013, 12:16 PM   #599
jdmasfcuk
jdmasfcuk's Avatar
hi papa, I am currently using Toyota 5w-30 as well.. ayos naman dd and occasional spirited driving.
you can try Motul, Red Line or Castrol Edge if need mo talaga yung 0w20. meron yan available at your suking carshop sa Iloilo
Old 03-26-2013, 10:48 AM   #600
TOY 86
TOY 86's Avatar
Drives: GT 86
Thanks
The Following User Says Thank You to TOY 86 For This Useful Post:
jdmasfcuk (03-31-2013)
Old 03-26-2013, 12:46 PM   #601
melon
melon's Avatar
Drives: Toyota 86
Just a query? Available ba for sale dito sa Philippines yung OEM Spoiler? Specifically the BRZ spoiler in US. TMP or Motor image addt'l option?
melon is offline   Reply With Quote
Old 03-26-2013, 01:44 PM   #602
Retro86
Retro86's Avatar
Drives: Awesome
Originally Posted by jdmasfcuk View Post
hi papa.. i was qouted 280k for a GENUINE Rocket Bunny Kit..
but then i saw these pics..
d kaya ng powers ko
its always ugly during the operation but dont worry maganda naman ang outcome.
Retro86 is offline   Reply With Quote
The Following User Says Thank You to Retro86 For This Useful Post:
jdmasfcuk (03-26-2013)
