Old 03-26-2013, 03:09 AM   #687
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Originally Posted by CSG David View Post
Too cool to cool down Dave!
On a side note, I wonder if ducting will solve the issue at this point. The replacement disc cost is simply hard to beat right now. Crack that 2nd set with ducting and it'll mean it's time to move onto ducted Endurance Kit! :happy0180:
Have you considered ducts pulling air from UNDERNEATH of the car, rather than in front of the car? Take a look at stock GT3/RS/Cup Car brake ducting around the control arm area for ideas.
the OEM BRZ "RA Racing spec" brake ducts look promising, bit this is where my STI lip will go
I've decided to say goodbye to the fogs for summertime and got these APR Carbon Fiber Brake Ducts, which I'll be using along with 3" hi-temp hoses, which @JRitt was so kind to put in the parcel
MSTiFK8R is offline   Reply With Quote
Old 03-26-2013, 10:27 AM   #688
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I did some google image searching and it appears that they just throw air in the general direction of the brakes? I'd rather have it forced (as much as possible) through the center of the rotor to the vanes.
The BRZ RA Racing Spec or whatever solution looks nice from the front, and could be modified to fit the eventual splitter I'll have, but I can't see how it directs the air to the discs either More pics needed
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
CSG David (03-26-2013)
Old 03-26-2013, 10:28 AM   #689
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Those damn things are just too expensive for me IMO. They need to offer them in plastic versions.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-26-2013, 10:31 AM   #690
OrbitalEllipses
Drives: Attitude
I guess it sorta does, but you could fab something to catch air and send it to the rotor vanes.
I haven't seen the underneath of the car, but if it's anything like the brake ducts I've seen on other Subarus...it's just slits at the front that channel under the bumper and terminate WAY before anywhere near being useful.
MSTiFK8R (03-26-2013)
Old 03-26-2013, 10:40 AM   #691
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
http://www.suncoastparts.com/mm5/gra...ar%20Ducts.jpg
That's the rear brake one, it actually looks better than the front brake one lol
Front GT3 "duct"
http://forums.rennlist.com/upload/duct1.jpg
Possible on the RA, that's mostly why I want to see one complete. It did make me consider just using zip ties to attach a NACA duct there and run hose from that to a Touge Factory backing plate (or spend the time making one) though...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-26-2013, 10:46 AM   #692
OrbitalEllipses
Drives: Attitude
You could try fabbing up a front diffuser that basically funneled air INTO the duct; sort of like a diverter that terminated in the openings to the brake ducts.
*shrug*
Old 03-26-2013, 12:21 PM   #693
CSG David
CSG David's Avatar
We would do the same on the CSG car too. Forcing air through the center of the rotor provides the best cooling.
Old 03-26-2013, 12:37 PM   #694
ICantAffordAnLFA
ICantAffordAnLFA's Avatar
Drives: Brz, Legacy
Fairly sure the RA cooling is an air guide, not fully ducted..... but I can't find the picture anymore.
Trackday ride with built motor
Mods: Going, Stopping, Handling
Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX
ICantAffordAnLFA is offline   Reply With Quote
Old 03-26-2013, 12:39 PM   #695
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
I really like the idea of the vents underneath, just want (like everyone else it seems) it to be fully ducted to the rotor. I wonder if it can be custom made...hmm...
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 03-27-2013, 03:18 AM   #696
evilconcarne999
My LFA
evilconcarne999's Avatar
Drives: No Boost
Wondering if someone could chime in and see if the sprint kit would fit ok on my wheel or if it is to close for comfort, Appologize for the abundance of pictures but i wanted to get a few angles. if anyone can say yes or no if they would fit i would appreciate it as i am trying to get these installed this weekend. to me it looks like it would fit but id like a 2nd opinion Thanks. Wheels are 17x7.5 45 offset.
evilconcarne999 is offline   Reply With Quote
Old 03-27-2013, 08:28 AM   #697
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Assuming that's centered in the center hole then it looks good to me.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-27-2013, 09:12 AM   #698
evilconcarne999
My LFA
Drives: No Boost
Yeah it is the only time it made contact with the rim was when I had it pushed all the way back but centered thats the clearance I had. Wasnt sure how much clearance it should have before it becomes danger close so I wanted to get a 2nd opinion appreciate the feedback
Old 03-27-2013, 10:53 AM   #699
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
It looks like you should be fine. You're looking for a roughly 2mm gap between the wheel and the template. Also, just make sure that you printed the template to the proper scale...measure one of the dimensions on the template with a ruler to make sure it matches what the paper says!
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 03-27-2013, 11:58 AM   #700
evilconcarne999
My LFA
Drives: No Boost
Cool appreciate it
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 10:34 AM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 02:36 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
