PROUD OF BOXER
Drives: Raven FR-S
autoX - first gear
So I just had my first autoX event this weekend and I think I did decent considering my skill level. However, once I got out of the gate and was in second, I stayed there the entire time and I feel like if I could have kept my revs above 5000 rpm in a few places, I could have easily shaved a few seconds off my time.
Does anyone actually use first gear while tracking for anything other than accelerating out of the gate? The dip in the torque band is killer. I dont know if I should be using first more or if it is frowned upon.
#2 |
No rice, no life
Drives: 2013 Asphalt FR-S
Depends on how tight the course is but I feel like it usually isn't worth it to try downshifting. TBH I don't think power supply is something you need to worry about for the time being. Instead try to focus on your line, as that is where you will see the biggest improvements. Shifting is really a more "advanced" technique in autox.
#3 |
Drives: BRZ and NA
I've seen some people in other cars drop down to 1st gear, but the time it takes to jam (and I do mean jam) the car in first gear and then re-shift back to 2nd gear takes more time than you'll gain.
Also, downshifting into first at speed is pretty hard. Unless you double clutch it will take decent amount of time to get the synchronizers spun up enough to allow first gear to engage. |
#4 |
Drives: MT WRB BRZ Limited, 2007 911s
I have a slightly related question. The course setup for me was a short straight leading into a tight left-hand turn and I would hit the limiter in first right in the middle of the turn. Is it better to ride out the limiter until I'm accelerating again, shift to second before the turn, or shift in the middle?
#5 |
Drives: Firestorm FR-S
Get in second and stay in second, going to first is never worth it. If your looking back at the run you did, and you find there was a corner where you had to consider it, very likely the line you're running could use some refinement, or in the worst case scenario, course designer built a stupid corner.
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
#6 | |
Drives: 2013 BRZ Ltd. MT
Sometimes trade-offs are required for the fastest lap time, not segment time. Does that make sense?
#7 |
The only people I've seen regular shift into 1st was with the old AP1 S2000 so they could stay in the VTEC RPM. On our cars it's just not worth it unless you are at a really really slow autocross with a 180 turnaround around a cone or something.
#8 | ||
![]() Quote:
#9 | |
#10 |
Conedancer
Drives: 2013 Subaru BRZ SWP
Everytime you shift...it costs you up to 2-3/10s... so the majority of folks get to 2nd gear and leave it there.. thats why the gearing and powerband is sooo important. most autocross courses don't much go over 60mph... but its nice to have the extra gearing to surpass that if possible, achieving it with A) taller tires... or B) With a raised rev-limit.. mine is set at 8k which renders 64.2 mph.. which should be plenty to be able to just leave it in 2nd gear.
![]() Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#11 |
Drives: 2013 Scion FR-S Firestorm
Of all the guys I auto-x with, it was typically the Honda guys that were concerned with staying in VTEC that would use 1st gear. I never did with my Miata.
| Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode | SteveH | Other Vehicles & General Automotive Discussions | 7 | 02-13-2013 12:08 AM |
| No more 1st gear thump or 2nd gear notchiness | kc4mne | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 09-06-2012 08:39 PM |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 07:44 PM |
| autox or autox school? | engee | Tracking / Autocross / HPDE / Drifting | 10 | 06-12-2012 06:31 PM |
| Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 01-29-2012 01:21 PM |
